Bug #633
closed
SH
clang builds of v1.7.0 fail: time_start used uninitialized
Bug #633: clang builds of v1.7.0 fail: time_start used uninitialized
Added by Stuart Henderson 8 months ago. Updated 2 months ago.
Resolved
03/02/2026
recent clang -Wall includes -Wsometimes-uninitialized, which triggers on time_start in cli_classic.c. since flashrom uses -Werror by default, this results in build failure.
FAILED: flashrom.p/cli_classic.c.o
cc -Iflashrom.p -I. -I../flashrom-v1.7.0 -I../flashrom-v1.7.0/include -fdiagnostics-color=always -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -Wextra -Werror -std=c99 -Wshadow -Wmissing-prototypes -Wwrite-strings -Wno-unused-parameter -Wno-address-of-packed-member -Wno-enum-conversion -Wno-missing-braces -D_DEFAULT_SOURCE -D_POSIX_C_SOURCE=200809L -D_BSD_SOURCE -D__BSD_VISIBLE -D__XSI_VISIBLE -D_NETBSD_SOURCE -D_DARWIN_C_SOURCE '-DFLASHROM_VERSION="v1.7.0"' -DHAVE_CLOCK_GETTIME=1 -DHAVE_STRNLEN=1 -DHAVE_GETOPT_H=1 -DHAVE_UTSNAME=1 -DIS_WINDOWS=0 -DCONFIG_USE_LIBPCI_ECAM=0 -DCONFIG_RPMC_ENABLED=1 -D__FLASHROM_LITTLE_ENDIAN__=1 -O2 -pipe -DCONFIG_DELAY_MINIMUM_SLEEP_US=100 -DCONFIG_ASM106X=1 -DCONFIG_ATAVIA=1 -DCONFIG_BUSPIRATE_SPI=1 -DCONFIG_CH341A_SPI=1 -DCONFIG_CH347_SPI=1 -DCONFIG_DEDIPROG=1 -DCONFIG_DEVELOPERBOX_SPI=1 -DCONFIG_DIGILENT_SPI=1 -DCONFIG_DIRTYJTAG_SPI=1 -DCONFIG_DRKAISER=1 -DCONFIG_DUMMY=1 -DCONFIG_FT2232_SPI=1 -DCONFIG_GFXNVIDIA=1 -DCONFIG_INTERNAL=1 -DCONFIG_INTERNAL_DMI=1 -DCONFIG_IT8212=1 -DCONFIG_NIC3COM=1 -DCONFIG_NICINTEL=1 -DCONFIG_NICINTEL_EEPROM=1 -DCONFIG_NICINTEL_SPI=1 -DCONFIG_NICREALTEK=1 -DCONFIG_NV_SMA_SPI=1 -DCONFIG_OGP_SPI=1 -DCONFIG_PICKIT2_SPI=1 -DCONFIG_PONY_SPI=1 -DCONFIG_RAIDEN_DEBUG_SPI=1 -DCONFIG_RAYER_SPI=1 -DCONFIG_SATAMV=1 -DCONFIG_SATASII=1 -DCONFIG_SERPROG=1 -DCONFIG_SPIDRIVER=1 -DCONFIG_STLINKV3_SPI=1 -DCONFIG_USBBLASTER_SPI=1 -DCONFIG_DEFAULT_PROGRAMMER_NAME=NULL '-DCONFIG_DEFAULT_PROGRAMMER_ARGS=""' -DLOG_MESSAGE_LENGTH_LIMIT=256 -MD -MQ flashrom.p/cli_classic.c.o -MF flashrom.p/cli_classic.c.o.d -o flashrom.p/cli_classic.c.o -c ../flashrom-v1.7.0/cli_classic.c
../flashrom-v1.7.0/cli_classic.c:1188:6: error: variable 'time_start' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized]
 1188 |         if (options.prog == NULL) {
../flashrom-v1.7.0/cli_classic.c:1592:28: note: uninitialized use occurs here
 1592 |                 (int)(difftime(time_end, time_start) / 60), (int)(difftime(time_end, time_start)) % 60);
../flashrom-v1.7.0/include/flash.h:746:49: note: expanded from macro 'msg_gdbg'
  746 | #define msg_gdbg(...)   print(FLASHROM_MSG_DEBUG, __VA_ARGS__)  /* general debug */
../flashrom-v1.7.0/cli_classic.c:1188:2: note: remove the 'if' if its condition is always false
 1189 |                 const struct programmer_entry *const default_programmer = CONFIG_DEFAULT_PROGRAMMER_NAME;
 1190 |
 1191 |                 if (default_programmer) {
 1192 |                         options.prog = default_programmer;
 1193 |                         /* We need to strdup here because we free(pparam) unconditionally later. */
 1194 |                         options.pparam = strdup(CONFIG_DEFAULT_PROGRAMMER_ARGS);
 1195 |                         msg_pinfo("Using default programmer \"%s\" with arguments \"%s\".\n",
 1196 |                                   default_programmer->name, options.pparam);
 1197 |                 } else {
 1198 |                         msg_perr("Please select a programmer with the --programmer parameter.\n"
 1199 | #if CONFIG_INTERNAL == 1
 1200 |                                  "To choose the mainboard of this computer use 'internal'. "
 1201 | #endif
 1202 |                                  "Valid choices are:\n");
 1203 |                         list_programmers_linebreak(0, 80, 0);
../flashrom-v1.7.0/cli_classic.c:1179:7: error: variable 'time_start' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized]
 1179 |                 if (!chip || !chip->name) {
../flashrom-v1.7.0/cli_classic.c:1179:3: note: remove the 'if' if its condition is always false
 1180 |                         msg_cerr("Error: Unknown chip '%s' specified.\n", options.chip_to_probe);
 1181 |                         msg_gerr("Run flashrom -L to view the hardware supported in this flashrom version.\n");
 1182 |                         ret = 1;
 1183 |                         goto out;
 1184 |                 }
../flashrom-v1.7.0/cli_classic.c:1179:7: error: variable 'time_start' is used uninitialized whenever '||' condition is true [-Werror,-Wsometimes-uninitialized]
../flashrom-v1.7.0/cli_classic.c:1179:7: note: remove the '||' if its condition is always false
../flashrom-v1.7.0/cli_classic.c:1170:6: error: variable 'time_start' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized]
 1170 |         if (!options.ifd && !options.fmap && process_include_args(options.layout, options.include_args)) {
../flashrom-v1.7.0/cli_classic.c:1170:2: note: remove the 'if' if its condition is always false
 1171 |                 ret = 1;
 1172 |                 goto out;
 1173 |         }
../flashrom-v1.7.0/cli_classic.c:1165:6: error: variable 'time_start' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized]
 1165 |         if (options.layoutfile && layout_from_file(&options.layout, options.layoutfile)) {
../flashrom-v1.7.0/cli_classic.c:1165:2: note: remove the 'if' if its condition is always false
 1166 |                 ret = 1;
 1167 |                 goto out;
 1168 |         }
../flashrom-v1.7.0/cli_classic.c:1150:6: error: variable 'time_start' is used uninitialized whenever 'if' condition is true [-Werror,-Wsometimes-uninitialized]
 1150 |         if (options.list_supported) {
../flashrom-v1.7.0/cli_classic.c:1150:2: note: remove the 'if' if its condition is always false
 1151 |                 if (print_supported())
 1152 |                         ret = 1;
 1153 |                 goto out;
 1154 |         }
../flashrom-v1.7.0/cli_classic.c:1058:19: note: initialize the variable 'time_start' to silence this warning
 1058 |         time_t time_start, time_end;
      |                           = 0
6 errors generated.
Files
BR Updated by Bhargav Rathod 8 months ago ยท Edited Actions #1
I can produce this issue locally when building flashrom v1.7.0
with clang and -Wsometimes-uninitialized enabled.
The warning occurs because time_start may be used before being
initialized in cli_classic.c.
A possible fix is to initializing the variable:
time_t time_start = 0, time_end = 0;
I prepared a patch.
AK Updated by Anastasia Klimchuk 2 months ago Actions #2
This has been fixed by https://review.coreboot.org/c/flashrom/+/91492 (in March)
It was a while ago, sorry I only recently saw the ticket, so updating it now.
