Bug #617
openMissing safeguard: CBFS_SIZE greater than BIOS region in the IFD
There are no effective safeguards to enforce that the CONFIG_CBFS_SIZE does not exceed the bios region as declared in the IFD.
Impact¶
- Downstream under Heads with a maximized bios region for the Haswell boards (T440p and W541) we could verify that this bug leads to an overflow when training the memory cache that makes it not work. This happens both with MRC blob and NRI and causes very slow boot times (20s) and S3 suspend/resume does not work.
- Effects on other boards have not been observed but are possible.
Expected behavior¶
Coreboot should not build successfully if the CBFS_SIZE exceeds the bios region in the IFD and error out reporting the problem that caused this.
Analysis¶
Full details are under the PR in Heads and in particular this comment by @tlaurion https://github.com/linuxboot/heads/pull/2025/#issuecomment-3524672338
Ifttool reports a bios region of 0xBDEFFF (BDEFFF).
However, the coreboot config contained:
CONFIG_CBFS_SIZE=0xBE4FFF
./build/x86/coreboot-25.09/util/ifdtool/ifdtool --platform ifd2 --layout w541_layout blobs/w541/ifd.bin && cat w541_layout
File blobs/w541/ifd.bin is 4096 bytes
Wrote layout to w541_layout
00000000:00000fff fd
00021000:00bfffff bios
00003000:00020fff me
00001000:00002fff gbe
After fixing the CONFIG_CBFS_SIZE the issues were fixed and fast boot with trained memory cache and S3 suspen/resume work again with NRI: https://github.com/linuxboot/heads/pull/2025/commits/9b8b9cacdcea4f67c95dcec10b3153fc8c016940
MB Updated by Maximilian Brune 12 months ago
Does this patch detect your issue? https://review.coreboot.org/c/coreboot/+/73470
GI Updated by gaspar ilom 12 months ago · Edited
Maximilian Brune wrote in #note-1:
Unfortunately no, it seems that this does not cause an error, as ifdtool does not find the regions in FMAP. Why is that?
Nov 15 18:25:27 printf " IFDTOOL validate IFD against FMAP\n"
Nov 15 18:25:27 IFDTOOL validate IFD against FMAP
Nov 15 18:25:27 EOL_w541-maximized/util/ifdtool/ifdtool \
Nov 15 18:25:27 \
Nov 15 18:25:27 -t EOL_w541-maximized/coreboot.pre
Nov 15 18:25:27 Warning: No platform specified. Output may be incomplete
Nov 15 18:25:27 Warning: Not a single IFD region found in FMAP
Nov 15 18:25:27 File EOL_w541-maximized/coreboot.pre is 12582912 bytes
EDIT:
Looked into the code and apart from analyzing why regions could not be found I think we should also question whether it is the right call to just print an error instead of calling exit:
https://review.coreboot.org/c/coreboot/+/73470/13/util/ifdtool/ifdtool.c#1256
What does your build/fmap.fmd file look like?
Maximilian Brune wrote in #note-3:
What does your
build/fmap.fmdfile look like?
cat ./build/x86/coreboot-25.09/EOL_w541-maximized/fmap.fmd
# layout for firmware residing at top of 4GB address space
# +-------------+ <-- 4GB - ROM_SIZE / start of flash
# | unspecified |
# +-------------+ <-- 4GB - BIOS_SIZE
# | FMAP |
# +-------------+ <-- 4GB - BIOS_SIZE + FMAP_SIZE
# | CBFS |
# +-------------+ <-- 4GB / end of flash
FLASH 0x00c00000 {
BIOS@131072 12451840 {
RW_MRC_CACHE@0 0x10000
FMAP@65536 0x200
COREBOOT(CBFS)@66048 12385792
MD Updated by Matt DeVillier 12 months ago
gaspar ilom wrote in #note-4:
# layout for firmware residing at top of 4GB address space # +-------------+ <-- 4GB - ROM_SIZE / start of flash # | unspecified | # +-------------+ <-- 4GB - BIOS_SIZE # | FMAP | # +-------------+ <-- 4GB - BIOS_SIZE + FMAP_SIZE # | CBFS | # +-------------+ <-- 4GB / end of flash FLASH 0x00c00000 { BIOS@131072 12451840 { RW_MRC_CACHE@0 0x10000 FMAP@65536 0x200 COREBOOT(CBFS)@66048 12385792 } }
there's something odd going on here, since the generated FMAP should have the IFD, ME, and GBE regions listed if you are including those blobs in the coreboot build.
gaspar ilom wrote in #note-2:
Nov 15 18:25:27 printf " IFDTOOL validate IFD against FMAP\n" Nov 15 18:25:27 IFDTOOL validate IFD against FMAP Nov 15 18:25:27 EOL_w541-maximized/util/ifdtool/ifdtool \ Nov 15 18:25:27 \ Nov 15 18:25:27 -t EOL_w541-maximized/coreboot.pre Nov 15 18:25:27 Warning: No platform specified. Output may be incomplete Nov 15 18:25:27 Warning: Not a single IFD region found in FMAP Nov 15 18:25:27 File EOL_w541-maximized/coreboot.pre is 12582912 bytesEDIT:
Looked into the code and apart from analyzing why regions could not be found I think we should also question whether it is the right call to just print an error instead of calling exit:https://review.coreboot.org/c/coreboot/+/73470/13/util/ifdtool/ifdtool.c#1256
your manual invocation of ifdtool lacks the platform parameter, so all bets are off. But as above, since the IFD layout is not reflected in the FMAP as it should, then there is nothing to compare against.
here's what you should be seeing (plus the GBE region)
FLASH 0x1000000 {
SI_DESC@0x0 0x1000
SI_ME@0x1000 0x1FF000
SI_BIOS@0xbb0000 0x450000 {
RW_MRC_CACHE@0x0 0x10000
SMMSTORE@0x10000 0x40000
RO_VPD@0x50000 0x4000
FMAP@0x54000 0x200
COREBOOT(CBFS)@0x55000 0x3fb000
Thanks Matt DeVillier!
The mentioned blobs are included. Here's my coreboot config: https://github.com/gaspar-ilom/heads/blob/try-cbfs-sanity-check-patch/config/coreboot-w541.config
This was not a manual invocation but an excerpt from the logs when building heads with CircleCI. It seems that for haswell CONFIG_IFD_CHIPSET is not set, which means that some special handling does not apply in the main makefile: https://github.com/coreboot/coreboot/blob/main/Makefile.mk#L1087-L1096
This looks very much like the culprit to me or am I missing something? Question is: What would be the right way to make this work?
- Should we set
CONFIG_IFD_CHIPSETfor this board?- If so to what?
- Or should we strip the platform parameter from
$(IFDTOOL) -p $(CONFIG_IFD_CHIPSET) -F $@ $<in the referenced code in case it is not there?- That would mean calling without the platform parameter if the ifd blob is used and the param is not explicitly selected. Maybe this is an option at least for some boards?
By the way, here's a manual invocation, that shows that it should work if this was stored in DEFAULT_FLASHMAP before the fmap.fmd target is built https://github.com/coreboot/coreboot/blob/main/Makefile.mk#L1231-L1246:
./build/x86/coreboot-25.09/util/ifdtool/ifdtool -p ifd2 -F w541_fmap.fmd blobs/w541/ifd.bin && cat w541_fmap.fmd
Wrote layout to w541_fmap.fmd
FLASH ##ROM_SIZE## {
SI_DESC@0x0 0x1000
SI_GBE@0x1000 0x2000
SI_ME@0x3000 0x1E000
SI_BIOS@##BIOS_BASE## ##BIOS_SIZE## {
##CONSOLE_ENTRY##
##MRC_CACHE_ENTRY##
##SMMSTORE_ENTRY##
##SPD_CACHE_ENTRY##
##VPD_ENTRY##
FMAP@##FMAP_BASE## ##FMAP_SIZE##
COREBOOT(CBFS)@##CBFS_BASE## ##CBFS_SIZE##
I didn't really test it yet, but this should cover it:
https://review.coreboot.org/c/coreboot/+/90107
Lets see if many boards fail the validation after jenkins is done.
Maximilian Brune wrote in #note-7:
Thanks for your patch. Seems like passing no platform is not the correct approach. All the pre soc boards in heads fail the build with your patch: https://app.circleci.com/pipelines/github/gaspar-ilom/heads/43/workflows/40c359ba-cd32-4b40-8171-92ebc0a099c2 The reason is the generic fmap-template.fmd contains SI_PDR@0xFFF000 0x0 which causes an error:
FMAP EOL_w541-maximized/util/cbfstool/fmaptool -h EOL_w541-maximized/fmap_config.h EOL_w541-maximized/fmap.fmd EOL_w541-maximized/fmap.fmap
E: Section 'SI_ME' too big
FATAL: Failed while processing provided descriptor
make[1]: *** [Makefile.mk:1262: EOL_w541-maximized/fmap.fmap] Error 4
cat ./build/x86/coreboot-25.09/EOL_w541-maximized/fmap-template.fmd
SI_DESC@0x0 0x1000
SI_PDR@0xFFF000 0x0
##CONSOLE_ENTRY##
##MRC_CACHE_ENTRY##
##SMMSTORE_ENTRY##
##SPD_CACHE_ENTRY##
##VPD_ENTRY##
It is not replaced:
FLASH 0x00c00000 {
SI_DESC@0x0 0x1000
SI_PDR@0xFFF000 0x0
SI_BIOS@131072 12451840 {
FMAP@65536 0x200
I tried building with hacking ifdtool_platform_param:=-p ifd2 in an else block for the W541 which creates an fmap file without SI_PDR but then the error changes to:
MAKE
Not sure how to move on from here.
I updated the change and it at least now passes jenkins.
Does it by any chance also fix your SI_ME too big issue?
Maximilian Brune wrote in #note-9:
Thanks for the update. SI_PDR is gone as expected but the SI_ME issue has remained as this excerpt from the logs shows:
IFDTOOL -F EOL_w541-maximized/fmap-template.fmd ../../../blobs/w541/ifd.bin
CC romstage/arch/x86/gdt_init.o
File ../../../blobs/w541/ifd.bin is 4096 bytes
Wrote layout to EOL_w541-maximized/fmap-template.fmd
CC firmware/lib/cgptlib/cgptlib.o
HOSTCC util/sconfig/sconfig (link)
HOSTCC cbfstool/fmaptool (link)
GEN build.h
MAKE
MAKE
MAKE
CC firmware/lib/cgptlib/cgptlib_internal.o
CC firmware/lib/cgptlib/crc32.o
CC firmware/lib/gpt_misc.o
CC firmware/lib20/api_kernel.o
CC firmware/lib20/kernel.o
RM vboot_fw.a
AR vboot_fw.a
SCONFIG mainboard/lenovo/haswell/variants/w541/devicetree.cb
make[1]: *** [Makefile.mk:1260: EOL_w541-maximized/fmap.fmap] Error 4
Did you set CBFS_SIZE too high?
Maximilian Brune wrote in #note-11:
Yes, the fix mentioned in the OP https://github.com/linuxboot/heads/pull/2025/commits/9b8b9cacdcea4f67c95dcec10b3153fc8c016940#diff-1146a022e2f557c41a3dc6d3b64c91c0891197c91163f30d80095f4d64ecab19 is not included so CBFS_SIZE is 0xBE4FFF where it should be 0xBDF000. However, this an incorrect size was also set for the sandy/ivy bridge boards (all 4+8MB SPI boards). The build only fails for the haswell boards as can be seen here, though: https://app.circleci.com/pipelines/circleci/MHXxJnuGL1oVD9jaDwEAGo/Kguuk4Rjpkd7hBpYBWhVuN/127/workflows/01a6f970-8d76-4e24-bb5c-b000109a4cbf
I have cherry-picked https://github.com/linuxboot/heads/pull/2025/commits/9b8b9cacdcea4f67c95dcec10b3153fc8c016940 to fix the size and build again. Build is happening here. Let's see if the boards build now: https://app.circleci.com/pipelines/github/gaspar-ilom/heads/58/workflows/94de47ac-a749-4dde-ac15-5b5e87341271
gaspar ilom wrote in #note-12:
CBFS_SIZEis 0xBE4FFF where it should be 0xBDF000. However, this an incorrect size was also set for the sandy/ivy bridge boards (all 4+8MB SPI boards). The build only fails for the haswell boards as can be seen here, though: https://app.circleci.com/pipelines/circleci/MHXxJnuGL1oVD9jaDwEAGo/Kguuk4Rjpkd7hBpYBWhVuN/127/workflows/01a6f970-8d76-4e24-bb5c-b000109a4cbfI have cherry-picked https://github.com/linuxboot/heads/pull/2025/commits/9b8b9cacdcea4f67c95dcec10b3153fc8c016940 to fix the size and build again. Build is happening here. Let's see if the boards build now: https://app.circleci.com/pipelines/github/gaspar-ilom/heads/58/workflows/94de47ac-a749-4dde-ac15-5b5e87341271
I updated the link to the CI run as the original run failed (it is flaky) and the rerun succeeded: https://app.circleci.com/pipelines/github/gaspar-ilom/heads/58/workflows/94de47ac-a749-4dde-ac15-5b5e87341271
The result is that with the correct CBFS_SIZE the boards build successfully. So the main remaining issues now are:
- The error message could be improved to make it clear what is going wrong.
- The code for validating the IFD that is run by default with your original patch is never reached: https://review.coreboot.org/c/coreboot/+/73470 This is also why the error message is not as helpful as it could be.
- For some reason only older boards (Intel 4th Gen) pass validation even if CBFS_SIZE does not match the size in the IFD. This happens even when explicitly selecting
VALIDATE_INTEL_DESCRIPTOR.
Here's another (force-pushed) run on my branch: https://app.circleci.com/pipelines/github/gaspar-ilom/heads/59/workflows/2ab3cc00-0fed-40a8-a325-ae6cb0b99c3c
- All boards with 4+8MB chips have a CBFS_SIZE greater than the bios region in the IFD
- T430 and W541 have
VALIDATE_INTEL_DESCRIPTORselected. - Seems like both haswell boards (T440p and W541) fail with the SI_ME region error.
- However, older boars T430 and X230 both succeed. Although, both have an invalid CBFS_SIZE and t430 has
VALIDATE_INTEL_DESCRIPTORset
To me all of this seems really inconsistent.
Why does the t430 succeed with a too high CBFS_SIZE? and why does the t440p fail even though validation should not happen? What are the platform specific differences that cause this? sizes of the blobs paylod etc?
