Bug #592
closedLenovo M920q can't use DIMM2 RAM slot
100%
Building the current coreboot source, as well as commits 497298708c330deb479fbf3ee6a3acc8bff2a102, 640a41f3ee938b794b140218921e0fd63b1d9235 and 7945a31e9172ec2939cc1abc6036962a6efb601b, produces the firmware, that allows to initialize the motherboard if only DIMM1 RAM slot is filled. It fails to initialize, if DIMM1 RAM slot is empty and DIMM2 is filled, as well as if both DIMM1 and DIMM2 are filled.
The issue is reproducible with different RAM sticks. I tried every possible combination with Kingston 32GB (2666MHz, CL 19-19-19-43) and Samsung 8GB (2400MHz, CL 17-17-17-39) -- the motherboard recognizes RAM sticks correctly, but still fails when the DIMM2 is filled with any RAM stick.
I have also attached the build config file, which uses most of the default options.
Files
Related links
https://github.com/Thrilleratplay/coreboot-builder-scripts/issues/33
Also, it looks like a similar issue to https://ticket.coreboot.org/issues/462
TH Updated by Tom Hiller over 1 year ago
In case it is missed in the linked github issue, the cause seems to related to this commit https://review.coreboot.org/c/coreboot/+/85161
MD Updated by Matt DeVillier over 1 year ago
Tom Hiller wrote in #note-1:
the check there was relaxed in https://review.coreboot.org/c/coreboot/+/86164 so that boards which don't configure in devicetree don't assert
DW Updated by Dawid Wrobel over 1 year ago
I believe this issue remains unfixed, see:
https://ticket.coreboot.org/issues/598?issue_count=281&issue_position=1&next_issue_id=597
TH Updated by Tom Hiller about 1 year ago
- File tio_ttyUSB0_2025-10-11T19_59_14.log tio_ttyUSB0_2025-10-11T19_59_14.log added
- File defconfig defconfig added
Sorry, I've just gotten around to trying this again.
Build from scratch from commit c7e4ef822d149c0f5cec6d1fa7251e054c5467e6, any RAM inserted into DIMM 2 will end with [EMERG] FspMemoryInit error, status=0x80000007, the full log and defconfig are attached.
CE Updated by Coreboot Enjoyer 7 months ago
- Status changed from New to Needs Testing
- Assignee set to Coreboot Enjoyer
- Status changed from Needs Testing to Resolved
Resolved by https://review.coreboot.org/c/coreboot/+/92014
