Bug #462
openSandy Bridge Raminit failure, only half of the memory modules initialized.
sudo dmidecode -t 17
# dmidecode 3.4
Getting SMBIOS data from sysfs.
SMBIOS 3.3.0 present.
Handle 0x000A, DMI type 17, 40 bytes
Memory Device
Array Handle: 0x0009
Error Information Handle: Not Provided
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: Channel-0-DIMM-0
Bank Locator: BANK 0
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 800 MT/s
Manufacturer: Unknown (1383)
Serial Number: 000002a0
Asset Tag: Channel-0-DIMM-0-AssetTag
Part Number: CL11-11-11 D3-16
Rank: 2
Configured Memory Speed: 800 MT/s
Minimum Voltage: Unknown
Maximum Voltage: Unknown
Configured Voltage: Unknown
NOTE ] coreboot-4.19-424-geba1a35402-dirty Sun Feb 12 10:30:43 UTC 2023 x86_32 bootblock starting (log level: 7)...
[DEBUG] FMAP: Found "FLASH" version 1.1 at 0xe50000.
[DEBUG] FMAP: base = 0xff000000 size = 0x1000000 #areas = 5
[DEBUG] FMAP: area COREBOOT found @ e50200 (1768960 bytes)
[INFO ] CBFS: mcache @0xfeff0e00 built for 12 files, used 0x2ac of 0x4000 bytes
[INFO ] CBFS: Found 'fallback/romstage' @0x80 size 0x180f8 in mcache @0xfeff0e2c
[DEBUG] BS: bootblock times (exec / console): total (unknown) / 45 ms
[NOTE ] coreboot-4.19-424-geba1a35402-dirty Sun Feb 12 10:30:43 UTC 2023 x86_32 romstage starting (log level: 7)...
[DEBUG] SMBus controller enabled
[DEBUG] Setting up static northbridge registers... done
[DEBUG] Initializing Graphics...
[DEBUG] Back from systemagent_early_init()
[INFO ] Intel ME early init
[INFO ] Intel ME firmware is ready
[DEBUG] ME: Requested 0MB UMA
[DEBUG] Starting native Platform init
[DEBUG] DMI: Running at X4 @ 5000MT/s
[DEBUG] FMAP: area RW_MRC_CACHE found @ e00000 (65536 bytes)
[DEBUG] Trying stored timings.
[DEBUG] Starting Ivy Bridge RAM training (fast boot).
[DEBUG] 100MHz reference clock support: yes
[DEBUG] PLL_REF100_CFG value: 0x2
[DEBUG] Trying CAS 11, tCK 320.
[DEBUG] Found compatible clock, CAS pair.
[DEBUG] Selected DRAM frequency: 800 MHz
[DEBUG] Selected CAS latency : 11T
[DEBUG] MPLL busy... done in 10 us
[DEBUG] MPLL frequency is set at : 800 MHz
[DEBUG] XOVER CLK [c14] = 3000000
[DEBUG] XOVER CMD [320c] = 24000
[DEBUG] XOVER CLK [d14] = 0
[DEBUG] XOVER CMD [330c] = 4000
[DEBUG] DBP [4000] = 1cbbbb
[DEBUG] RAP [4004] = cc187476
[DEBUG] OTHP [400c] = 68b4
[DEBUG] REFI [4298] = 6cf01860
[DEBUG] SRFTP [42a4] = 41f88200
[DEBUG] DBP [4400] = 1cbbbb
[DEBUG] RAP [4404] = cc187476
[DEBUG] OTHP [440c] = 68b4
[DEBUG] REFI [4698] = 6cf01860
[DEBUG] SRFTP [46a4] = 41f88200
[DEBUG] Done dimm mapping
[DEBUG] Update PCI-E configuration space:
[DEBUG] PCI(0, 0, 0)[a0] = 0
[DEBUG] PCI(0, 0, 0)[a4] = 2
[DEBUG] PCI(0, 0, 0)[bc] = 82a00000
[DEBUG] PCI(0, 0, 0)[a8] = 7d600000
[DEBUG] PCI(0, 0, 0)[ac] = 2
[DEBUG] PCI(0, 0, 0)[b8] = 80000000
[DEBUG] PCI(0, 0, 0)[b0] = 80a00000
[DEBUG] PCI(0, 0, 0)[b4] = 80800000
[DEBUG] Done memory map
[DEBUG] RCOMP...done
[DEBUG] COMP2 done
[DEBUG] COMP1 done
[DEBUG] FORCE RCOMP and wait 20us...done
[DEBUG] Done io registers
[DEBUG] CPE
[DEBUG] CP5b
[DEBUG] CP5c
[DEBUG] t123: 1767, 6000, 7620
[NOTE ] ME: Wrong mode : 2
[NOTE ] ME: FWS2: 0x160a0140
[NOTE ] ME: Bist in progress: 0x0
[NOTE ] ME: ICC Status : 0x0
[NOTE ] ME: Invoke MEBx : 0x0
[NOTE ] ME: CPU replaced : 0x0
[NOTE ] ME: MBP ready : 0x0
[NOTE ] ME: MFS failure : 0x1
[NOTE ] ME: Warm reset req : 0x0
[NOTE ] ME: CPU repl valid : 0x1
[NOTE ] ME: (Reserved) : 0x0
[NOTE ] ME: FW update req : 0x0
[NOTE ] ME: Current state : 0xa
[NOTE ] ME: Current PM event: 0x6
[NOTE ] ME: Progress code : 0x1
[NOTE ] PASSED! Tell ME that DRAM is ready
[NOTE ] ME: ME is reporting as disabled, so not waiting for a response.
[NOTE ] ME: Requested BIOS Action: No DID Ack received
[DEBUG] ME: FW Partition Table : OK
[DEBUG] ME: Bringup Loader Failure : NO
[DEBUG] ME: Firmware Init Complete : NO
[DEBUG] ME: Manufacturing Mode : YES
[DEBUG] ME: Boot Options Present : NO
[DEBUG] ME: Update In Progress : NO
[DEBUG] ME: Current Working State : Initializing
[DEBUG] ME: Current Operation State : Bring up
[DEBUG] ME: Current Operation Mode : Debug or Disabled by AltDisableBit
[DEBUG] ME: Error Code : No Error
[DEBUG] ME: Progress Phase : BUP Phase
[DEBUG] ME: Power Management Event : Pseudo-global reset
[DEBUG] ME: Progress Phase State : Check to see if straps say ME DISABLED
[DEBUG] memcfg DDR3 ref clock 133 MHz
[DEBUG] memcfg DDR3 clock 1596 MHz
[DEBUG] memcfg channel assignment: A: 0, B 1, C 2
[DEBUG] memcfg channel[0] config (00620020):
[DEBUG] ECC inactive
[DEBUG] enhanced interleave mode on
[DEBUG] rank interleave on
[DEBUG] DIMMA 8192 MB width x8 dual rank, selected
[DEBUG] DIMMB 0 MB width x8 single rank
[DEBUG] memcfg channel[1] config (00000000):
[DEBUG] enhanced interleave mode off
[DEBUG] rank interleave off
[DEBUG] DIMMA 0 MB width x8 single rank, selected
[DEBUG] CBMEM:
[DEBUG] IMD: root @ 0x7ffff000 254 entries.
[DEBUG] IMD: root @ 0x7fffec00 62 entries.
[DEBUG] External stage cache:
[DEBUG] IMD: root @ 0x803ff000 254 entries.
[DEBUG] IMD: root @ 0x803fec00 62 entries.
[DEBUG] CBMEM entry for DIMM info: 0x7ffdc000
[DEBUG] SMM Memory Map
[DEBUG] SMRAM : 0x80000000 0x800000
[DEBUG] Subregion 0: 0x80000000 0x300000
[DEBUG] Subregion 1: 0x80300000 0x100000
[DEBUG] Subregion 2: 0x80400000 0x400000
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/postcar' @0x3e7c0 size 0x5ed0 in mcache @0xfeff0fd4
[DEBUG] Loading module at 0x7ffd0000 with entry 0x7ffd0031. filesize: 0x5ae0 memsize: 0xbe78
[DEBUG] Processing 236 relocs. Offset value of 0x7dfd0000
[DEBUG] BS: romstage times (exec / console): total (unknown) / 567 ms
[DEBUG] usbdebug: postcar starting...
[DEBUG] Normal boot
[INFO ] CBFS: Found 'fallback/ramstage' @0x1ea40 size 0x1c796 in mcache @0x7fffe9bc
[DEBUG] Loading module at 0x7ff83000 with entry 0x7ff83000. filesize: 0x39538 memsize: 0x4b6b0
[DEBUG] Processing 3842 relocs. Offset value of 0x7bf83000
[DEBUG] BS: postcar times (exec / console): total (unknown) / 48 ms
[DEBUG] usbdebug: ramstage starting...
[DEBUG] Normal boot
[INFO ] Enumerating buses...
[DEBUG] Root Device scanning...
[DEBUG] CPU_CLUSTER: 0 enabled
[DEBUG] DOMAIN: 0000 enabled
[DEBUG] DOMAIN: 0000 scanning...
[DEBUG] PCI: pci_scan_bus for bus 00
[DEBUG] PCI: 00:00.0 [8086/0150] enabled
[DEBUG] PCI: 00:01.0 [8086/0151] disabled
[DEBUG] PCI: 00:02.0 [8086/0152] enabled
[DEBUG] PCI: 00:14.0 [8086/1e31] enabled
[DEBUG] PCI: 00:16.0: Disabling device
[DEBUG] PCI: 00:16.0 [8086/1e3a] disabled
[DEBUG] PCI: 00:16.1: Disabling device
[DEBUG] PCI: 00:16.2: Disabling device
[DEBUG] PCI: 00:16.3: Disabling device
[DEBUG] PCI: 00:19.0: Disabling device
[DEBUG] PCI: 00:1a.0 [8086/1e2d] enabled
[DEBUG] PCI: 00:1b.0 [8086/1e20] enabled
[INFO ] PCH: PCIe Root Port coalescing is enabled
[DEBUG] PCI: 00:1c.0 [8086/1e10] enabled
[DEBUG] PCI: 00:1c.1 [8086/1e12] enabled
[DEBUG] PCI: 00:1c.2: Disabling device
[DEBUG] PCI: 00:1c.2 [8086/1e14] disabled
[DEBUG] PCI: 00:1c.3: Disabling device
[DEBUG] PCI: 00:1c.3 [8086/1e16] disabled
[DEBUG] PCI: 00:1c.4: Disabling device
[DEBUG] PCI: 00:1c.4: check set enabled
[DEBUG] PCI: 00:1c.5: Disabling device
[DEBUG] PCI: 00:1c.6: Disabling device
[DEBUG] PCI: 00:1c.7: Disabling device
[DEBUG] PCI: 00:1d.0 [8086/1e26] enabled
[DEBUG] PCI: 00:1e.0 [8086/244e] enabled
[DEBUG] PCI: 00:1f.0 [8086/1e49] enabled
[DEBUG] PCI: 00:1f.2 [8086/1e00] enabled
[DEBUG] PCI: 00:1f.3 [8086/1e22] enabled
[DEBUG] PCI: 00:1f.5: Disabling device
[DEBUG] PCI: 00:1f.5 [8086/1e08] disabled No operations
[DEBUG] PCI: 00:1f.6: Disabling device
[DEBUG] PCI: 00:1f.6 [8086/1e24] disabled No operations
[WARN ] PCI: Leftover static devices:
[WARN ] PCI: 00:01.1
[WARN ] PCI: 00:01.2
[WARN ] PCI: 00:04.0
[WARN ] PCI: 00:06.0
[WARN ] PCI: 00:16.1
[WARN ] PCI: 00:16.2
[WARN ] PCI: 00:16.3
[WARN ] PCI: 00:19.0
[WARN ] PCI: 00:1c.4
[WARN ] PCI: 00:1c.5
[WARN ] PCI: 00:1c.6
[WARN ] PCI: 00:1c.7
[WARN ] PCI: Check your devicetree.cb.
[DEBUG] PCI: 00:1c.0 scanning...
[DEBUG] PCI: pci_scan_bus for bus 01
[DEBUG] scan_bus: bus PCI: 00:1c.0 finished in 4 msecs
[DEBUG] PCI: 00:1c.1 scanning...
[DEBUG] PCI: pci_scan_bus for bus 02
[DEBUG] PCI: 02:00.0 [10ec/8168] enabled
[INFO ] Enabling Common Clock Configuration
[INFO ] ASPM: Enabled L1
[INFO ] PCIe: Max_Payload_Size adjusted to 128
[DEBUG] PCI: 02:00.0: No LTR support
[DEBUG] scan_bus: bus PCI: 00:1c.1 finished in 25 msecs
[DEBUG] PCI: 00:1e.0 scanning...
[DEBUG] PCI: pci_scan_bus for bus 03
[DEBUG] scan_bus: bus PCI: 00:1e.0 finished in 4 msecs
[DEBUG] PCI: 00:1f.0 scanning...
[DEBUG] scan_bus: bus PCI: 00:1f.0 finished in 0 msecs
[DEBUG] PCI: 00:1f.3 scanning...
[DEBUG] scan_bus: bus PCI: 00:1f.3 finished in 0 msecs
[DEBUG] scan_bus: bus DOMAIN: 0000 finished in 273 msecs
[DEBUG] scan_bus: bus Root Device finished in 290 msecs
[INFO ] done
[DEBUG] BS: BS_DEV_ENUMERATE run times (exec / console): 0 / 305 ms
[DEBUG] found VGA at PCI: 00:02.0
[DEBUG] Setting up VGA for PCI: 00:02.0
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge DOMAIN: 0000
[DEBUG] Setting PCI_BRIDGE_CTL_VGA for bridge Root Device
[INFO ] Allocating resources...
[INFO ] Reading resources...
[DEBUG] Adding PCIe enhanced config space BAR 0xf0000000-0xf4000000.
[DEBUG] TOUUD 0x27d600000 TOLUD 0x82a00000 TOM 0x200000000
[DEBUG] MEBASE 0x7ffff00000
[DEBUG] IGD decoded, subtracting 32M UMA and 2M GTT
[DEBUG] TSEG base 0x80000000 size 8M
[INFO ] Available memory below 4GB: 2048M
[INFO ] Available memory above 4GB: 6102M
[DEBUG] PCI: 00:1a.0 EHCI BAR hook registered
[DEBUG] More than one caller of pci_ehci_read_resources from PCI: 00:1d.0
[INFO ] Done reading resources.
[INFO ] === Resource allocator: DOMAIN: 0000 - Pass 1 (gathering requirements) ===
[DEBUG] PCI: 00:1c.1 io: size: 0 align: 12 gran: 12 limit: ffff
[DEBUG] PCI: 02:00.0 10 * [0x0 - 0xff] io
[DEBUG] PCI: 00:1c.1 io: size: 1000 align: 12 gran: 12 limit: ffff done
[DEBUG] PCI: 00:1c.1 mem: size: 0 align: 20 gran: 20 limit: ffffffff
[DEBUG] PCI: 00:1c.1 mem: size: 0 align: 20 gran: 20 limit: ffffffff done
[DEBUG] PCI: 00:1c.1 prefmem: size: 0 align: 20 gran: 20 limit: ffffffffffffffff
[DEBUG] PCI: 02:00.0 20 * [0x0 - 0x3fff] prefmem
[DEBUG] PCI: 02:00.0 18 * [0x4000 - 0x4fff] prefmem
[DEBUG] PCI: 00:1c.1 prefmem: size: 100000 align: 20 gran: 20 limit: ffffffffffffffff done
[INFO ] === Resource allocator: DOMAIN: 0000 - Pass 2 (allocating resources) ===
[DEBUG] DOMAIN: 0000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff
[DEBUG] update_constraints: PCI: 00:1f.0 10000000 base 00000000 limit 00000fff io (fixed)
[DEBUG] update_constraints: PCI: 00:1f.3 20 base 00000400 limit 0000041f io (fixed)
[INFO ] DOMAIN: 0000: Resource ranges:
[INFO ] * Base: 1000, Size: f000, Tag: 100
[DEBUG] PCI: 00:1c.1 1c * [0x1000 - 0x1fff] limit: 1fff io
[DEBUG] PCI: 00:02.0 20 * [0x2000 - 0x203f] limit: 203f io
[DEBUG] PCI: 00:1f.2 20 * [0x2040 - 0x205f] limit: 205f io
[DEBUG] PCI: 00:1f.2 10 * [0x2060 - 0x2067] limit: 2067 io
[DEBUG] PCI: 00:1f.2 18 * [0x2068 - 0x206f] limit: 206f io
[DEBUG] PCI: 00:1f.2 14 * [0x2070 - 0x2073] limit: 2073 io
[DEBUG] PCI: 00:1f.2 1c * [0x2074 - 0x2077] limit: 2077 io
[DEBUG] DOMAIN: 0000 io: base: 0 size: 0 align: 0 gran: 0 limit: ffff done
[DEBUG] DOMAIN: 0000 mem: base: 0 size: 0 align: 0 gran: 0 limit: fffffffff
[DEBUG] update_constraints: PCI: 00:00.0 60 base f0000000 limit f3ffffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 03 base 00000000 limit 0009ffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 04 base 00100000 limit 7fffffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 05 base 100000000 limit 27d5fffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 06 base 80000000 limit 829fffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 07 base 000a0000 limit 000bffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:00.0 08 base 000c0000 limit 000fffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:1f.0 10000100 base ff000000 limit ffffffff mem (fixed)
[DEBUG] update_constraints: PCI: 00:1f.0 03 base fec00000 limit fec00fff mem (fixed)
[INFO ] * Base: 82a00000, Size: 6d600000, Tag: 200
[INFO ] * Base: f4000000, Size: ac00000, Tag: 200
[INFO ] * Base: fec01000, Size: 3ff000, Tag: 200
[INFO ] * Base: 27d600000, Size: d82a00000, Tag: 100200
[DEBUG] PCI: 00:02.0 18 * [0x90000000 - 0x9fffffff] limit: 9fffffff prefmem
[DEBUG] PCI: 00:02.0 10 * [0x82c00000 - 0x82ffffff] limit: 82ffffff mem
[DEBUG] PCI: 00:1c.1 24 * [0x82a00000 - 0x82afffff] limit: 82afffff prefmem
[DEBUG] PCI: 00:14.0 10 * [0x82b00000 - 0x82b0ffff] limit: 82b0ffff mem
[DEBUG] PCI: 00:1b.0 10 * [0x82b10000 - 0x82b13fff] limit: 82b13fff mem
[DEBUG] PCI: 00:1f.2 24 * [0x82b14000 - 0x82b147ff] limit: 82b147ff mem
[DEBUG] PCI: 00:1a.0 10 * [0x82b15000 - 0x82b153ff] limit: 82b153ff mem
[DEBUG] PCI: 00:1d.0 10 * [0x82b16000 - 0x82b163ff] limit: 82b163ff mem
[DEBUG] PCI: 00:1f.3 10 * [0x82b17000 - 0x82b170ff] limit: 82b170ff mem
[DEBUG] DOMAIN: 0000 mem: base: 0 size: 0 align: 0 gran: 0 limit: fffffffff done
[DEBUG] PCI: 00:1c.1 io: base: 1000 size: 1000 align: 12 gran: 12 limit: 1fff
[INFO ] PCI: 00:1c.1: Resource ranges:
[INFO ] * Base: 1000, Size: 1000, Tag: 100
[DEBUG] PCI: 02:00.0 10 * [0x1000 - 0x10ff] limit: 10ff io
[DEBUG] PCI: 00:1c.1 io: base: 1000 size: 1000 align: 12 gran: 12 limit: 1fff done
[DEBUG] PCI: 00:1c.1 prefmem: base: 82a00000 size: 100000 align: 20 gran: 20 limit: 82afffff
[INFO ] * Base: 82a00000, Size: 100000, Tag: 1200
[DEBUG] PCI: 02:00.0 20 * [0x82a00000 - 0x82a03fff] limit: 82a03fff prefmem
[DEBUG] PCI: 02:00.0 18 * [0x82a04000 - 0x82a04fff] limit: 82a04fff prefmem
[DEBUG] PCI: 00:1c.1 prefmem: base: 82a00000 size: 100000 align: 20 gran: 20 limit: 82afffff done
[INFO ] === Resource allocator: DOMAIN: 0000 - resource allocation complete ===
[DEBUG] PCI: 00:02.0 10 <- [0x0000000082c00000 - 0x0000000082ffffff] size 0x00400000 gran 0x16 mem64
[DEBUG] PCI: 00:02.0 18 <- [0x0000000090000000 - 0x000000009fffffff] size 0x10000000 gran 0x1c prefmem64
[DEBUG] PCI: 00:02.0 20 <- [0x0000000000002000 - 0x000000000000203f] size 0x00000040 gran 0x06 io
[DEBUG] PCI: 00:14.0 10 <- [0x0000000082b00000 - 0x0000000082b0ffff] size 0x00010000 gran 0x10 mem64
[DEBUG] PCI: 00:1a.0 EHCI Debug Port hook triggered
[DEBUG] PCI: 00:1a.0 10 <- [0x0000000082b15000 - 0x0000000082b153ff] size 0x00000400 gran 0x0a mem
[DEBUG] PCI: 00:1a.0 EHCI Debug Port relocated
[DEBUG] PCI: 00:1b.0 10 <- [0x0000000082b10000 - 0x0000000082b13fff] size 0x00004000 gran 0x0e mem64
[DEBUG] PCI: 00:1c.0 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c bus 01 io
[DEBUG] PCI: 00:1c.0 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 bus 01 prefmem
[DEBUG] PCI: 00:1c.0 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 bus 01 mem
[DEBUG] PCI: 00:1c.1 1c <- [0x0000000000001000 - 0x0000000000001fff] size 0x00001000 gran 0x0c bus 02 io
[DEBUG] PCI: 00:1c.1 24 <- [0x0000000082a00000 - 0x0000000082afffff] size 0x00100000 gran 0x14 bus 02 prefmem
[DEBUG] PCI: 00:1c.1 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 bus 02 mem
[DEBUG] PCI: 02:00.0 10 <- [0x0000000000001000 - 0x00000000000010ff] size 0x00000100 gran 0x08 io
[DEBUG] PCI: 02:00.0 18 <- [0x0000000082a04000 - 0x0000000082a04fff] size 0x00001000 gran 0x0c prefmem64
[DEBUG] PCI: 02:00.0 20 <- [0x0000000082a00000 - 0x0000000082a03fff] size 0x00004000 gran 0x0e prefmem64
[DEBUG] PCI: 00:1d.0 10 <- [0x0000000082b16000 - 0x0000000082b163ff] size 0x00000400 gran 0x0a mem
[DEBUG] PCI: 00:1e.0 1c <- [0x000000000000ffff - 0x000000000000fffe] size 0x00000000 gran 0x0c bus 03 io
[DEBUG] PCI: 00:1e.0 24 <- [0xffffffffffffffff - 0xfffffffffffffffe] size 0x00000000 gran 0x14 bus 03 prefmem
[DEBUG] PCI: 00:1e.0 20 <- [0x00000000ffffffff - 0x00000000fffffffe] size 0x00000000 gran 0x14 bus 03 mem
[DEBUG] PCI: 00:1f.2 10 <- [0x0000000000002060 - 0x0000000000002067] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:1f.2 14 <- [0x0000000000002070 - 0x0000000000002073] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:1f.2 18 <- [0x0000000000002068 - 0x000000000000206f] size 0x00000008 gran 0x03 io
[DEBUG] PCI: 00:1f.2 1c <- [0x0000000000002074 - 0x0000000000002077] size 0x00000004 gran 0x02 io
[DEBUG] PCI: 00:1f.2 20 <- [0x0000000000002040 - 0x000000000000205f] size 0x00000020 gran 0x05 io
[DEBUG] PCI: 00:1f.2 24 <- [0x0000000082b14000 - 0x0000000082b147ff] size 0x00000800 gran 0x0b mem
[DEBUG] PCI: 00:1f.3 10 <- [0x0000000082b17000 - 0x0000000082b170ff] size 0x00000100 gran 0x08 mem64
[INFO ] Done setting resources.
[INFO ] Done allocating resources.
[DEBUG] BS: BS_DEV_RESOURCES run times (exec / console): 1 / 782 ms
[INFO ] Enabling resources...
[DEBUG] PCI: 00:00.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:00.0 cmd <- 06
[DEBUG] PCI: 00:02.0 subsystem <- 1462/2111
[DEBUG] PCI: 00:02.0 cmd <- 03
[DEBUG] PCI: 00:14.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:14.0 cmd <- 102
[DEBUG] PCI: 00:1a.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:1a.0 cmd <- 106
[DEBUG] PCI: 00:1b.0 subsystem <- 1462/d758
[DEBUG] PCI: 00:1b.0 cmd <- 102
[DEBUG] PCI: 00:1c.0 bridge ctrl <- 0013
[DEBUG] PCI: 00:1c.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:1c.0 cmd <- 100
[DEBUG] PCI: 00:1c.1 bridge ctrl <- 0013
[DEBUG] PCI: 00:1c.1 subsystem <- 1462/7758
[DEBUG] PCI: 00:1c.1 cmd <- 107
[DEBUG] PCI: 00:1d.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:1d.0 cmd <- 102
[DEBUG] PCI: 00:1e.0 bridge ctrl <- 0013
[DEBUG] PCI: 00:1e.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:1e.0 cmd <- 100
[DEBUG] PCI: 00:1f.0 subsystem <- 1462/7758
[DEBUG] PCI: 00:1f.0 cmd <- 107
[DEBUG] PCI: 00:1f.2 subsystem <- 1462/7758
[DEBUG] PCI: 00:1f.2 cmd <- 03
[DEBUG] PCI: 00:1f.3 subsystem <- 1462/7758
[DEBUG] PCI: 00:1f.3 cmd <- 103
[DEBUG] PCI: 02:00.0 cmd <- 03
[INFO ] done.
[DEBUG] BS: BS_DEV_ENABLE run times (exec / console): 0 / 122 ms
[INFO ] Initializing devices...
[DEBUG] CPU_CLUSTER: 0 init
[DEBUG] MTRR: Physical address space:
[DEBUG] 0x0000000000000000 - 0x000000000009ffff size 0x000a0000 type 6
[DEBUG] 0x00000000000a0000 - 0x00000000000bffff size 0x00020000 type 0
[DEBUG] 0x00000000000c0000 - 0x000000007fffffff size 0x7ff40000 type 6
[DEBUG] 0x0000000080000000 - 0x000000008fffffff size 0x10000000 type 0
[DEBUG] 0x0000000090000000 - 0x000000009fffffff size 0x10000000 type 1
[DEBUG] 0x00000000a0000000 - 0x00000000ffffffff size 0x60000000 type 0
[DEBUG] 0x0000000100000000 - 0x000000027d5fffff size 0x17d600000 type 6
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x250 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x258 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x259 0x0000000000000000
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x268 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x269 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26a 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26b 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26c 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26d 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26e 0x0606060606060606
[DEBUG] apic_id 0x0: MTRR: Fixed MSR 0x26f 0x0606060606060606
[DEBUG] apic_id 0x0 setup mtrr for CPU physical address size: 36 bits
[DEBUG] MTRR: default type WB/UC MTRR counts: 4/4.
[DEBUG] MTRR: UC selected as default type.
[DEBUG] MTRR: 0 base 0x0000000000000000 mask 0x0000000f80000000 type 6
[DEBUG] MTRR: 1 base 0x0000000090000000 mask 0x0000000ff0000000 type 1
[DEBUG] MTRR: 2 base 0x0000000100000000 mask 0x0000000f00000000 type 6
[DEBUG] MTRR: 3 base 0x0000000200000000 mask 0x0000000f80000000 type 6
[DEBUG] MTRR check
[DEBUG] Fixed MTRRs : Enabled
[DEBUG] Variable MTRRs: Enabled
[DEBUG] CPU has 2 cores, 4 threads enabled.
[DEBUG] Setting up SMI for CPU
[INFO ] Will perform SMM setup.
[INFO ] CBFS: Found 'cpu_microcode_blob.bin' @0x18200 size 0x6800 in mcache @0x7fffe98c
[DEBUG] microcode: sig=0x306a9 pf=0x2 revision=0x21
[INFO ] CPU: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz.
[INFO ] LAPIC 0x0 in XAPIC mode.
[DEBUG] CPU: APIC: 00 enabled
[DEBUG] CPU: APIC: 01 enabled
[DEBUG] CPU: APIC: 02 enabled
[DEBUG] CPU: APIC: 03 enabled
[DEBUG] Loading module at 0x00030000 with entry 0x00030000. filesize: 0x178 memsize: 0x178
[DEBUG] Processing 16 relocs. Offset value of 0x00030000
[DEBUG] Attempting to start 3 APs
[DEBUG] Waiting for 10ms after sending INIT.
[DEBUG] Waiting for SIPI to complete...
[INFO ] LAPIC 0x1 in XAPIC mode.
[DEBUG] done.
[INFO ] AP: slot 1 apic_id 1, MCU rev: 0x00000021
[INFO ] LAPIC 0x2 in XAPIC mode.
[INFO ] LAPIC 0x3 in XAPIC mode.
[INFO ] AP: slot 3 apic_id 2, MCU rev: 0x00000021
[DEBUG] done.
[INFO ] AP: slot 2 apic_id 3, MCU rev: 0x00000021
[DEBUG] Loading module at 0x00038000 with entry 0x00038000. filesize: 0x1e8 memsize: 0x1e8
[DEBUG] Processing 11 relocs. Offset value of 0x00038000
[DEBUG] smm_module_setup_stub: stack_top = 0x80001000
[DEBUG] smm_module_setup_stub: per cpu stack_size = 0x400
[DEBUG] smm_module_setup_stub: runtime.start32_offset = 0x4c
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x10000
[DEBUG] SMM Module: stub loaded at 38000. Will call 0x7ffa0131
[DEBUG] Installing permanent SMM handler to 0x80000000
[DEBUG] FX_SAVE [0x802ff800-0x80300000]
[DEBUG] HANDLER [0x802fb000-0x802ff268]
[DEBUG] CPU 0
[DEBUG] ss0 [0x802fac00-0x802fb000]
[DEBUG] stub0 [0x802f3000-0x802f31e8]
[DEBUG] CPU 1
[DEBUG] ss1 [0x802fa800-0x802fac00]
[DEBUG] stub1 [0x802f2c00-0x802f2de8]
[DEBUG] CPU 2
[DEBUG] ss2 [0x802fa400-0x802fa800]
[DEBUG] stub2 [0x802f2800-0x802f29e8]
[DEBUG] CPU 3
[DEBUG] ss3 [0x802fa000-0x802fa400]
[DEBUG] stub3 [0x802f2400-0x802f25e8]
[DEBUG] stacks [0x80000000-0x80001000]
[DEBUG] Loading module at 0x802fb000 with entry 0x802fbb88. filesize: 0x4150 memsize: 0x4268
[DEBUG] Processing 256 relocs. Offset value of 0x802fb000
[DEBUG] Loading module at 0x802f3000 with entry 0x802f3000. filesize: 0x1e8 memsize: 0x1e8
[DEBUG] Processing 11 relocs. Offset value of 0x802f3000
[DEBUG] smm_module_setup_stub: runtime.smm_size = 0x300000
[DEBUG] SMM Module: placing smm entry code at 802f2c00, cpu # 0x1
[DEBUG] SMM Module: placing smm entry code at 802f2800, cpu # 0x2
[DEBUG] SMM Module: placing smm entry code at 802f2400, cpu # 0x3
[DEBUG] SMM Module: stub loaded at 802f3000. Will call 0x802fbb88
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x802eb000, cpu = 0
[DEBUG] In relocation handler: cpu 0
[DEBUG] New SMBASE=0x802eb000 IEDBASE=0x80400000
[DEBUG] Writing SMRR. base = 0x80000006, mask=0xff800800
[DEBUG] Relocation complete.
[INFO ] microcode: Update skipped, already up-to-date
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x802eac00, cpu = 1
[DEBUG] In relocation handler: cpu 1
[DEBUG] New SMBASE=0x802eac00 IEDBASE=0x80400000
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x802ea800, cpu = 2
[DEBUG] In relocation handler: cpu 2
[DEBUG] New SMBASE=0x802ea800 IEDBASE=0x80400000
[INFO ] smm_do_relocation : curr_smbase 0x30000 perm_smbase 0x802ea400, cpu = 3
[DEBUG] In relocation handler: cpu 3
[DEBUG] New SMBASE=0x802ea400 IEDBASE=0x80400000
[INFO ] Initializing CPU #0
[DEBUG] CPU: vendor Intel device 306a9
[DEBUG] CPU: family 06, model 3a, stepping 09
[INFO ] CPU: platform id 1
[INFO ] CPU: cpuid(1) 0x306a9
[INFO ] CPU: AES NOT supported
[INFO ] CPU: TXT NOT supported
[INFO ] CPU: VT supported
[DEBUG] IA32_FEATURE_CONTROL already locked; VMX status: enabled
[DEBUG] cpu: energy policy set to 6
[DEBUG] model_x06ax: frequency set to 3300
[INFO ] Turbo is unavailable
[INFO ] CPU #0 initialized
[INFO ] Initializing CPU #1
[INFO ] Initializing CPU #3
[INFO ] Initializing CPU #2
[INFO ] CPU #3 initialized
[INFO ] CPU #2 initialized
[INFO ] CPU #1 initialized
[INFO ] bsp_do_flight_plan done after 558 msecs.
[DEBUG] SMI_STS:
[DEBUG] GPE0_STS: GPIO14 GPIO11 GPIO10 GPIO9 GPIO1 GPIO0
[DEBUG] ALT_GP_SMI_STS: GPI14 GPI13 GPI11 GPI10 GPI9 GPI5 GPI4 GPI3 GPI2 GPI1 GPI0
[DEBUG] TCO_STS:
[DEBUG] Locking SMM.
[DEBUG] CPU_CLUSTER: 0 init finished in 886 msecs
[DEBUG] PCI: 00:00.0 init
[DEBUG] Disabling PEG12.
[DEBUG] Disabling PEG11.
[DEBUG] Disabling PEG10.
[DEBUG] Disabling Device 4.
[DEBUG] Disabling PEG60.
[DEBUG] Disabling Device 7.
[DEBUG] Disabling PEG IO clock.
[DEBUG] Set BIOS_RESET_CPL
[DEBUG] CPU TDP: 55 Watts
[DEBUG] PCI: 00:00.0 init finished in 29 msecs
[DEBUG] PCI: 00:02.0 init
[WARN ] CBFS: 'vbt.bin' not found.
[WARN ] CBFS: 'pci8086,0152.rom' not found.
[WARN ] CBFS: 'pci8086,0106.rom' not found.
[DEBUG] PCI Option ROM loading disabled for PCI: 00:02.0
[DEBUG] GMA: locate_vbt_vbios: 76a2 280b 49 db 97
[7m[ERROR] GMA: VBT couldn't be found
[DEBUG] GT Power Management Init
[DEBUG] IVB GT1 Power Meter Weights
[DEBUG] GT Power Management Init (post VBIOS)
[INFO ] framebuffer_info: bytes_per_line: 5504, bits_per_pixel: 32
[INFO ] x_res x y_res: 1366 x 768, size: 4227072 at 0x90000000
[DEBUG] PCI: 00:02.0 init finished in 65 msecs
[DEBUG] PCI: 00:14.0 init
[DEBUG] XHCI: Setting up controller.. done.
[DEBUG] PCI: 00:14.0 init finished in 4 msecs
[DEBUG] PCI: 00:1a.0 init
[DEBUG] EHCI: Setting up controller.. done.
[DEBUG] PCI: 00:1a.0 init finished in 4 msecs
[DEBUG] PCI: 00:1b.0 init
[DEBUG] Azalia: base = 0x82b10000
[DEBUG] Azalia: codec_mask = 09
[DEBUG] azalia_audio: Initializing codec #3
[DEBUG] azalia_audio: codec viddid: 80862806
[DEBUG] azalia_audio: verb_size: 16
[DEBUG] azalia_audio: verb loaded.
[DEBUG] azalia_audio: Initializing codec #0
[DEBUG] azalia_audio: codec viddid: 10ec0887
[DEBUG] azalia_audio: verb_size: 60
[DEBUG] PCI: 00:1b.0 init finished in 46 msecs
[DEBUG] PCI: 00:1c.0 init
[DEBUG] Initializing PCH PCIe bridge.
[DEBUG] PCI: 00:1c.0 init finished in 4 msecs
[DEBUG] PCI: 00:1c.1 init
[DEBUG] PCI: 00:1c.1 init finished in 4 msecs
[DEBUG] PCI: 00:1d.0 init
[DEBUG] PCI: 00:1d.0 init finished in 4 msecs
[DEBUG] PCI: 00:1e.0 init
[DEBUG] PCI init.
[DEBUG] PCI: 00:1e.0 init finished in 2 msecs
[DEBUG] PCI: 00:1f.0 init
[DEBUG] pch: lpc_init
[INFO ] PCH: detected B75, device id: 0x1e49, rev id 0x4
[DEBUG] IOAPIC: Initializing IOAPIC at 0xfec00000
[DEBUG] IOAPIC: 24 interrupts
[DEBUG] IOAPIC: Clearing IOAPIC at 0xfec00000
[DEBUG] IOAPIC: Bootstrap Processor Local APIC = 0x00
[INFO ] Set power off after power failure.
[INFO ] NMI sources disabled.
[DEBUG] PantherPoint PM init
[DEBUG] RTC: failed = 0x0
[DEBUG] RTC Init
[DEBUG] apm_control: Disabling ACPI.
[DEBUG] APMC done.
[DEBUG] pch_spi_init
[DEBUG] PCI: 00:1f.0 init finished in 53 msecs
[DEBUG] PCI: 00:1f.2 init
[DEBUG] SATA: Initializing...
[DEBUG] SATA: Controller in AHCI mode.
[DEBUG] ABAR: 0x82b14000
[DEBUG] PCI: 00:1f.2 init finished in 10 msecs
[DEBUG] PCI: 00:1f.3 init
[DEBUG] PCI: 00:1f.3 init finished in 0 msecs
[DEBUG] PCI: 02:00.0 init
[DEBUG] PCI: 02:00.0 init finished in 0 msecs
[INFO ] Devices initialized
[DEBUG] BS: BS_DEV_INIT run times (exec / console): 324 / 912 ms
[DEBUG] FMAP: area SMMSTORE found @ e10000 (262144 bytes)
[INFO ] Manufacturer: c2
[INFO ] SF: Detected c2 2018 with sector size 0x1000, total 0x1000000
[DEBUG] smm store: 4 # blocks with size 0x10000
[INFO ] SMMSTORE: Setting up SMI handler
[DEBUG] BS: BS_DEV_INIT exit times (exec / console): 0 / 25 ms
[INFO ] Finalize devices...
[DEBUG] PCI: 00:1f.0 final
[DEBUG] apm_control: Finalizing SMM.
[DEBUG] APMC done.
[INFO ] Devices finalized
[DEBUG] BS: BS_POST_DEVICE run times (exec / console): 0 / 16 ms
[INFO ] CBFS: Found 'fallback/dsdt.aml' @0x3c280 size 0x24e7 in mcache @0x7fffea88
[WARN ] CBFS: 'fallback/slic' not found.
[INFO ] ACPI: Writing ACPI tables at 7ff36000.
[DEBUG] ACPI: * FACS
[DEBUG] ACPI: * DSDT
[DEBUG] ACPI: * FADT
[DEBUG] ACPI: added table 1/32, length now 40
[DEBUG] ACPI: * SSDT
[DEBUG] Found 1 CPU(s) with 4 core(s) each.
[DEBUG] PSS: 3300MHz power 55000 control 0x2100 status 0x2100
[DEBUG] PSS: 2800MHz power 43981 control 0x1c00 status 0x1c00
[DEBUG] PSS: 2400MHz power 35986 control 0x1800 status 0x1800
[DEBUG] PSS: 2000MHz power 28563 control 0x1400 status 0x1400
[DEBUG] PSS: 1600MHz power 21721 control 0x1000 status 0x1000
[DEBUG] PCI space above 4GB MMIO is at 0x27d600000, len = 0xd82a00000
[DEBUG] Generating ACPI PIRQ entries
[DEBUG] ACPI: added table 2/32, length now 44
[DEBUG] ACPI: * MCFG
[DEBUG] ACPI: added table 3/32, length now 48
[DEBUG] ACPI: * MADT
[DEBUG] ACPI: added table 4/32, length now 52
[DEBUG] current = 7ff39d40
[DEBUG] ACPI: * HPET
[DEBUG] ACPI: added table 5/32, length now 56
[INFO ] ACPI: done.
[DEBUG] ACPI tables: 15744 bytes.
[DEBUG] smbios_write_tables: 7ff2e000
[DEBUG] SMBIOS firmware version is set to coreboot_version: '4.19-424-geba1a35402-dirty'
[INFO ] Create SMBIOS type 16
[INFO ] Create SMBIOS type 17
[INFO ] Create SMBIOS type 20
[DEBUG] SMBIOS tables: 803 bytes.
[DEBUG] Writing table forward entry at 0x00000500
[DEBUG] Wrote coreboot table at: 0x00000500, 0x10 bytes, checksum dfe8
[DEBUG] Writing coreboot table at 0x7ff5a000
[DEBUG] 0. 0000000000000000-0000000000000fff: CONFIGURATION TABLES
[DEBUG] 1. 0000000000001000-000000000009ffff: RAM
[DEBUG] 2. 00000000000a0000-00000000000fffff: RESERVED
[DEBUG] 3. 0000000000100000-000000007ff2dfff: RAM
[DEBUG] 4. 000000007ff2e000-000000007ff82fff: CONFIGURATION TABLES
[DEBUG] 5. 000000007ff83000-000000007ffcefff: RAMSTAGE
[DEBUG] 6. 000000007ffcf000-000000007fffffff: CONFIGURATION TABLES
[DEBUG] 7. 0000000080000000-00000000829fffff: RESERVED
[DEBUG] 8. 00000000f0000000-00000000f3ffffff: RESERVED
[DEBUG] 9. 0000000100000000-000000027d5fffff: RAM
[DEBUG] Wrote coreboot table at: 0x7ff5a000, 0x3fc bytes, checksum a64c
[DEBUG] coreboot table: 1044 bytes.
[DEBUG] IMD ROOT 0. 0x7ffff000 0x00001000
[DEBUG] IMD SMALL 1. 0x7fffe000 0x00001000
[DEBUG] CONSOLE 2. 0x7ffde000 0x00020000
[DEBUG] TIME STAMP 3. 0x7ffdd000 0x00000910
[DEBUG] MEM INFO 4. 0x7ffdc000 0x000007a8
[DEBUG] AFTER CAR 5. 0x7ffcf000 0x0000d000
[DEBUG] RAMSTAGE 6. 0x7ff82000 0x0004d000
[DEBUG] SMM BACKUP 7. 0x7ff72000 0x00010000
[DEBUG] SMM COMBUFFER 8. 0x7ff62000 0x00010000
[DEBUG] COREBOOT 9. 0x7ff5a000 0x00008000
[DEBUG] ACPI 10. 0x7ff36000 0x00024000
[DEBUG] SMBIOS 11. 0x7ff2e000 0x00008000
[DEBUG] IMD small region:
[DEBUG] IMD ROOT 0. 0x7fffec00 0x00000400
[DEBUG] USBDEBUG 1. 0x7fffeba0 0x00000050
[DEBUG] RO MCACHE 2. 0x7fffe8e0 0x000002ac
[DEBUG] FMAP 3. 0x7fffe7c0 0x0000010a
[DEBUG] ROMSTAGE 4. 0x7fffe7a0 0x00000004
[DEBUG] ROMSTG STCK 5. 0x7fffe6e0 0x000000a8
[DEBUG] ACPI GNVS 6. 0x7fffe5e0 0x00000100
[DEBUG] BS: BS_WRITE_TABLES run times (exec / console): 2 / 424 ms
[INFO ] CBFS: Found 'fallback/payload' @0x44700 size 0xbed49 in mcache @0x7fffeaf8
[DEBUG] Checking segment from ROM address 0xffe9492c
[DEBUG] Checking segment from ROM address 0xffe94948
[DEBUG] Loading segment from ROM address 0xffe9492c
[DEBUG] code (compression=1)
[DEBUG] New segment dstaddr 0x00800000 memsize 0x590000 srcaddr 0xffe94964 filesize 0xbed11
[DEBUG] Loading Segment: addr: 0x00800000 memsz: 0x0000000000590000 filesz: 0x00000000000bed11
[DEBUG] using LZMA
[DEBUG] Loading segment from ROM address 0xffe94948
[DEBUG] Entry Point 0x00801626
[DEBUG] BS: BS_PAYLOAD_LOAD run times (exec / console): 209 / 57 ms
[DEBUG] ICH-NM10-PCH: watchdog disabled
[DEBUG] Jumping to boot code at 0x00801626(0x7ff5a000)
There are actually two identical memory modules.
sudo ./inteltool -m
CPU: ID 0x306a9, Processor Type 0x0, Family 0x6, Model 0x3a, Stepping 0x9
Northbridge: 8086:0150 (3rd generation (Ivy Bridge family) Core Processor (Desktop))
Southbridge: 8086:1e49 (B75)
IGD: 8086:0152 (Intel(R) HD 2500 Graphics)
============= MCHBAR ============
MCHBAR = 0xfed10000 (MEM)
0x0004: 0x00001d70
0x0008: 0x00000206
0x000c: 0x00052a1b
0x0010: 0x0210222c
0x0014: 0x02002230
0x0020: 0x00018a25
0x0024: 0x00018a24
0x0030: 0x000000ff
0x0034: 0x00001011
0x0104: 0x00001d70
0x0108: 0x00000206
0x010c: 0x00052a1b
0x0110: 0x02502501
0x0114: 0x02402603
0x0120: 0x00018d25
0x0124: 0x00019029
0x0130: 0x000000ff
0x0134: 0x00001011
0x0204: 0x00001d70
0x0208: 0x00000206
0x020c: 0x00052a1b
0x0210: 0x0200233a
0x0214: 0x0200223b
0x0220: 0x00019c38
0x0224: 0x00019c3a
0x0230: 0x000000ff
0x0234: 0x00001011
0x0304: 0x00001d70
0x0308: 0x00000206
0x030c: 0x00052a1b
0x0310: 0x02202614
0x0314: 0x02402616
0x0320: 0x0001a03b
0x0324: 0x0001a33d
0x0330: 0x000000ff
0x0334: 0x00001011
0x0404: 0xffffffff
0x0408: 0x0000ffff
0x040c: 0x00052a1b
0x0410: 0x02012214
0x0414: 0x02012015
0x0420: 0x0009ae0b
0x0424: 0x0009b10e
0x0430: 0x000000ff
0x0434: 0x00001011
0x0504: 0xffffffff
0x0508: 0x0000ffff
0x050c: 0x00052a1b
0x0510: 0x02202525
0x0514: 0x02102628
0x0520: 0x0009b20c
0x0524: 0x0009b812
0x0530: 0x000000ff
0x0534: 0x00001011
0x0604: 0xffffffff
0x0608: 0x0000ffff
0x060c: 0x00052a1b
0x0610: 0x02212322
0x0614: 0x02112027
0x0620: 0x0009b712
0x0624: 0x0009b916
0x0630: 0x000000ff
0x0634: 0x00001011
0x0704: 0xffffffff
0x070c: 0x00052a1b
0x0710: 0x02402434
0x0714: 0x0230253b
0x0720: 0x0002031c
0x0724: 0x0002051f
0x0730: 0x000000ff
0x0734: 0x00001011
0x080c: 0x00052a1b
0x0830: 0x000000ff
0x0834: 0x00001011
0x090c: 0x00052a1b
0x0930: 0x000000ff
0x0934: 0x00001011
0x0a00: 0x00000003
0x0a04: 0x00064207
0x0a08: 0x00063a0e
0x0a0c: 0x01fe4048
0x0a10: 0x00003fff
0x0b00: 0x00000003
0x0b04: 0x00064207
0x0b08: 0x00063a0e
0x0b0c: 0x01fe4002
0x0b10: 0x00003fff
0x0c00: 0x00000003
0x0c04: 0x00063a10
0x0c14: 0x032cb30e
0x0c1c: 0x000002ff
0x0c20: 0x0000ff00
0x0c34: 0x00001011
0x0d00: 0x00000003
0x0d04: 0x00063a10
0x0d14: 0x032cb30c
0x0d1c: 0x000002ff
0x0d20: 0x0000ffff
0x0d34: 0x00001011
0x0e00: 0x00000003
0x0e04: 0x00064207
0x0e08: 0x00063a0e
0x0e0c: 0x01fe4048
0x0e10: 0x00003fff
0x0f00: 0x00000003
0x0f04: 0x00064207
0x0f08: 0x00063a0e
0x0f0c: 0x01fe4002
0x0f10: 0x00003fff
0x1004: 0xffffffff
0x100c: 0x00052a1b
0x1010: 0x02012036
0x1014: 0x01f12133
0x1020: 0x00020c29
0x1024: 0x00020d2a
0x1030: 0x000000ff
0x1034: 0x00001011
0x1104: 0xffffffff
0x110c: 0x00052a1b
0x1110: 0x02112406
0x1114: 0x0231230b
0x1120: 0x0002122e
0x1124: 0x00021835
0x1130: 0x000000ff
0x1134: 0x00001011
0x1204: 0xffffffff
0x120c: 0x00052a1b
0x1210: 0x01f1237e
0x1214: 0x0211233f
0x1220: 0x00021935
0x1224: 0x00021835
0x1230: 0x000000ff
0x1234: 0x00001011
0x1304: 0xffffffff
0x130c: 0x00052a1b
0x1310: 0x02312415
0x1314: 0x02412219
0x1320: 0x0002243d
0x1324: 0x0002253f
0x1330: 0x000000ff
0x1334: 0x00001011
0x1404: 0xffffffff
0x140c: 0x00052a1b
0x1410: 0x02022315
0x1414: 0x02022215
0x1420: 0x0002253f
0x1424: 0x000a2703
0x1430: 0x000000ff
0x1434: 0x00001011
0x1504: 0xffffffff
0x150c: 0x00052a1b
0x1510: 0x02312323
0x1514: 0x0211222a
0x1520: 0x000a2804
0x1524: 0x000a2f0a
0x1530: 0x000000ff
0x1534: 0x00001011
0x1604: 0xffffffff
0x160c: 0x00052a1b
0x1610: 0x02222122
0x1614: 0x02122221
0x1620: 0x000a2b05
0x1624: 0x000a2d0a
0x1630: 0x000000ff
0x1634: 0x00001011
0x1704: 0xffffffff
0x170c: 0x00052a1b
0x1710: 0x02112330
0x1714: 0x01e12633
0x1720: 0x000a3915
0x1724: 0x000a3b18
0x1730: 0x000000ff
0x1734: 0x00001011
0x1810: 0x24914924
0x1814: 0x0c6671e4
0x1818: 0x00000400
0x1910: 0x24914924
0x1914: 0x0c6671e4
0x1918: 0x00000400
0x4000: 0x001c8bbb
0x4004: 0x0c187476
0x4008: 0x0a042220
0x400c: 0x000058b4
0x401c: 0x00100000
0x4020: 0x00100005
0x4024: 0x20202828
0x4028: 0x000e0033
0x4034: 0x0000d7c9
0x4038: 0x8376a9fa
0x403c: 0x4e83c351
0x4044: 0x000000ff
0x4048: 0x00000000
0x4054: 0x000000ff
0x4058: 0x000000ff
0x405c: 0x000000ff
0x4060: 0x000000ff
0x40a8: 0x01000040
0x40ac: 0x00000040
0x40b0: 0x00000240
0x40b4: 0xffffffff
0x40b8: 0x00040000
0x40d4: 0x00000046
0x4160: 0x00000000
0x4200: 0x01460000
0x4204: 0x01000320
0x4208: 0x01000320
0x420c: 0x01060400
0x4210: 0x00000244
0x4214: 0x00000242
0x4218: 0x00000242
0x421c: 0x00000240
0x4220: 0x0001f006
0x4224: 0x0001f201
0x4228: 0x0001f105
0x422c: 0x0001f002
0x4230: 0x00282004
0x4234: 0x08281064
0x4238: 0x04281064
0x423c: 0x00280c01
0x4244: 0x000407e3
0x4248: 0x000407e3
0x4270: 0xeb19b77e
0x4274: 0xc40f374c
0x4284: 0x000c0000
0x428c: 0x00000044
0x4290: 0x00004080
0x4294: 0x0000980f
0x4298: 0x6cf01860
0x429c: 0x00004218
0x42a0: 0x00001003
0x42a4: 0x41f88200
0x42ac: 0x00000001
0x4364: 0x000ddfd2
0x4380: 0x00000aaa
0x4384: 0x009b6ea1
0x4388: 0x5f7003ff
0x438c: 0x551d1519
0x4400: 0x001c8bbb
0x4404: 0x0c187476
0x4408: 0x0a042220
0x440c: 0x000058b4
0x441c: 0x00100000
0x4420: 0x00100005
0x4424: 0x20202828
0x4428: 0x000e0022
0x4434: 0x0000f9f9
0x4438: 0x74c97d3d
0x443c: 0x58bc1fba
0x4448: 0x000000ff
0x444c: 0x000000ff
0x44a8: 0x01000040
0x44ac: 0x00000040
0x44b0: 0x00000240
0x44b4: 0xffffffff
0x44b8: 0x00040000
0x44d4: 0x00000046
0x4600: 0x01460000
0x4604: 0x01000320
0x4608: 0x01000320
0x460c: 0x01060400
0x4610: 0x00000244
0x4614: 0x00000242
0x4618: 0x00000242
0x461c: 0x00000240
0x4620: 0x0001f006
0x4624: 0x0001f201
0x4628: 0x0001f105
0x462c: 0x0001f002
0x4630: 0x00282004
0x4634: 0x08281064
0x4638: 0x04281064
0x463c: 0x00280c01
0x4644: 0x000407e3
0x4648: 0x000407e3
0x4670: 0xe389d4d6
0x4674: 0xb52d7f5e
0x4684: 0x000c0000
0x468c: 0x00000044
0x4690: 0x00004080
0x4694: 0x0000980f
0x4698: 0x6cf01860
0x469c: 0x00004218
0x46a0: 0x00001003
0x46a4: 0x41f88200
0x46ac: 0x00000002
0x4760: 0x000002bc
0x4764: 0x000c4e2a
0x4780: 0x00000aaa
0x4784: 0x009b6ea1
0x4788: 0x5f7003ff
0x478c: 0x551d1519
0x4c00: 0x001c8bbb
0x4c04: 0x0c187476
0x4c08: 0x0a042220
0x4c0c: 0x000058b4
0x4c1c: 0x00100000
0x4c20: 0x00100005
0x4c24: 0x20202828
0x4c28: 0x000e0033
0x4c34: 0x0000d7c9
0x4c38: 0x8376a9fa
0x4c3c: 0x4e83c351
0x4ca8: 0x01000040
0x4cac: 0x00000040
0x4cb0: 0x00000240
0x4cb4: 0xffffffff
0x4cb8: 0x00040000
0x4cd4: 0x00000046
0x4d48: 0x00000000
0x4e00: 0x01460000
0x4e04: 0x01000320
0x4e08: 0x01000320
0x4e0c: 0x01060400
0x4e10: 0x00000244
0x4e14: 0x00000242
0x4e18: 0x00000242
0x4e1c: 0x00000240
0x4e20: 0x0001f006
0x4e24: 0x0001f201
0x4e28: 0x0001f105
0x4e2c: 0x0001f002
0x4e30: 0x00282004
0x4e34: 0x08281064
0x4e38: 0x04281064
0x4e3c: 0x00280c01
0x4e44: 0x000407e3
0x4e48: 0x000407e3
0x4e70: 0xeb1ba423
0x4e74: 0xc41184af
0x4e84: 0x000c0000
0x4e8c: 0x00000044
0x4e90: 0x00004080
0x4e94: 0x0000980f
0x4e98: 0x6cf01860
0x4e9c: 0x00004218
0x4ea0: 0x00001003
0x4ea4: 0x41f88200
0x4eac: 0x00000001
0x4f64: 0x000ddfd2
0x4f80: 0x00000aaa
0x4f84: 0x009b6ea1
0x4f88: 0x5f7003ff
0x4f8c: 0x551d1519
0x5000: 0x00000024
0x5004: 0x00620020
0x5008: 0x00620020
0x500c: 0x00600000
0x5014: 0x20400000
0x5020: 0x00000006
0x5024: 0x00a030ce
0x5030: 0x0000019f
0x5034: 0x01070000
0x5040: 0x17160c9a
0x5044: 0x766caee7
0x5048: 0x24b543e2
0x5050: 0x7f0a5abb
0x5054: 0x32e68779
0x5058: 0x42b32512
0x5060: 0x000100ff
0x5064: 0x00073193
0x5074: 0x00000010
0x5080: 0x0000201a
0x5084: 0x00010898
0x5094: 0xffffffff
0x50fc: 0x0000008d
0x5418: 0x00000004
0x541c: 0x30000000
0x5500: 0x00100001
0x5880: 0xca9171e7
0x5888: 0x00e4dad0
0x5890: 0x003daf2c
0x5894: 0x003d98b8
0x5924: 0x00000010
0x5928: 0x02ab9264
0x592c: 0x0008636b
0x5930: 0x016001b8
0x5934: 0x000d0000
0x5938: 0x000a1003
0x593c: 0x0aad6c50
0x5940: 0x0008ab29
0x5944: 0x003ab8d8
0x5948: 0x00000700
0x5954: 0x00040000
0x5958: 0xe0012100
0x595c: 0x00081000
0x5960: 0x03c1a3dd
0x5964: 0x8f1d87f9
0x5968: 0x8f1d82e4
0x596c: 0x40cf5adf
0x5970: 0x12c27306
0x5974: 0x12c27304
0x5978: 0x00000017
0x597c: 0x00000017
0x5980: 0x00000016
0x5984: 0xd30f067a
0x5990: 0x000000ff
0x5994: 0x000000ff
0x5998: 0x00070d15
0x599c: 0x00691400
0x59a0: 0x001481b8
0x59a4: 0x00008220
0x59b0: 0x80001fff
0x59b4: 0x18141494
0x59b8: 0x80000190
0x59bc: 0x18141494
0x59c0: 0x88530000
0x5d10: 0x2010040c
0x5d14: 0x80000000
0x5d20: 0x00000005
0x5da8: 0x00000001
0x5e00: 0x00000006
0x5e04: 0x00000006
0x5efc: 0xffff0000
0x5f00: 0x8000270f
0x5f04: 0x7530001a
0x5f08: 0x0000001a
0x5f0c: 0x4e20001a
0x5f10: 0x1f425830
0x5f14: 0x801db100
0x5f18: 0x000000fa
0x5f20: 0x5dc20000
0x5f30: 0x00040001
0x5f38: 0xd2a84b03
0x5f3c: 0x00000021
0x5f44: 0x01600000
0x5f4c: 0x01600000
0x5f50: 0x80000000
0x6000: 0x00000004
0x6008: 0x800000d8
0x6010: 0xfff00000
0x6014: 0x0000007f
0x6020: 0x00000001
0x6030: 0x000700b0
0x6034: 0x000700b0
0x6200: 0x88520000
0x63fc: 0x00000001
0x6410: 0x00000c00
0x6430: 0x00fac688
0x6434: 0x00fac688
0x6800: 0x80000044
0x7000: 0x80444444
0x7030: 0x00000018
0x7400: 0x09249249
0x7404: 0x00120249
0x7408: 0x01ffffff
0x740c: 0xb1207851
0x7410: 0x00000019
0x7500: 0x000f0000
0x7504: 0x000000b0
0x77fc: 0x00000001
0x7800: 0x00444444
0x7804: 0x00004444
0x7ffc: 0x00000001
.tCK = TCK_MHZ800,
.rankmap = { 0x3, 0x3 },
.mad_dimm = { 0x620020, 0x620020 },
.mobile = 1,
.CAS = 11 /* 11 clocks = 13.750 ns */,
.tWR = 12 /* 12 clocks = 15.000 ns */,
.reg_4004_b30 = { 0, 0 },
.tFAW = 24 /* 24 clocks = 30.000 ns */,
.tWTR = 7 /* 7 clocks = 8.750 ns */,
.tCKE = 4 /* 4 clocks = 5.000 ns */,
.tRTP = 7 /* 7 clocks = 8.750 ns */,
.tRRD = 6 /* 6 clocks = 7.500 ns */,
.tRAS = 28 /* 28 clocks = 35.000 ns */,
.tCWL = 8 /* 8 clocks = 10.000 ns */,
.tRP = 11 /* 11 clocks = 13.750 ns */,
.tRCD = 11 /* 11 clocks = 13.750 ns */,
.tXPDLL = 20 /* 20 clocks = 25.000 ns */,
.tXP = 5 /* 5 clocks = 6.250 ns */,
.tAONPD = 8 /* 8 clocks = 10.000 ns */,
.tREFI = 6240 /* 6240 clocks = 7800.000 ns */,
.tRFC = 240 /* 240 clocks = 300.000 ns */,
.tMOD = 12 /* 12 clocks = 15.000 ns */,
.tXSOffset = 8 /* 8 clocks = 10.000 ns */,
.reg5064b0 = 0x193,
.channel_size_mb = { ?, 8192 },
/* CH0S0: 8192 MiBÂ */
/* CH1S0: 8192 MiBÂ */
/* SPD matching current mode:Â */
/* CH0S0Â */
00: 92 11 0b 03 04 00 00 09 03 52 01 08 0a 00 80 00
10: 6e 78 6e 3c 6e 11 18 81 60 09 46 46 00 f0 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 65 00
40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51 da
80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
/* CH1S0Â */
AA Updated by akjuxr3 akjuxr3 about 3 years ago
I can confirm this issue. The issue appears to my experience when you insert two equal DIMM's.
My experience is based on a Z77 chipset board (4 DIMM-slots) with a ivybridge CPU. When i insert two equal 8GiB DIMM's, i have the here reported issue. When i add for example one or two additional 4GiB DIMMs, the issue is gone.
So as a workaround, you can add some random DIMM additional to the two DIMM's you have already inserted if you have 4 DIMM-slots on your board.
In my case when i have the here reported issue and add two additional 4GiB DIMM's, i get full 24GiB usable RAM instead of the here reported issue.
The issue exist already since months. It does not seem to be a recent regression.
SL Updated by shen Liu about 3 years ago
akjuxr3 akjuxr3 wrote in #note-1:
My experience is based on a Z77 chipset board (4 DIMM-slots) with a ivybridge CPU. When i insert two equal 8GiB DIMM's, i have the here reported issue. When i add for example one or two additional 4GiB DIMMs, the issue is gone.So as a workaround, you can add some random DIMM additional to the two DIMM's you have already inserted if you have 4 DIMM-slots on your board.
In my case when i have the here reported issue and add two additional 4GiB DIMM's, i get full 24GiB usable RAM instead of the here reported issue.The issue exist already since months. It does not seem to be a recent regression.
There seems to be something different.
When I tested one of the memory modules individually, one of the memory modules failed to initialize properly.
USB
[NOTE ] coreboot-4.19-424-geba1a35402-dirty Sun Feb 12 10:30:43 UTC 2023 x86_32 bootblock starting (log level: 7)...
[NOTE ] MRC: no data in 'RW_MRC_CACHE'
[DEBUG] ECC supported: no ECC forced: no
[INFO ] ECC RAM unsupported.
[DEBUG] SPD probe channel0, slot0
[DEBUG] Revision : 11
[DEBUG] Type : b
[DEBUG] Key : 2
[DEBUG] Banks : 8
[DEBUG] Capacity : 4 Gb
[DEBUG] Supported voltages : 1.5V
[DEBUG] SDRAM width : 8
[DEBUG] Bus extension : 0 bits
[DEBUG] Bus width : 64
[DEBUG] FTB timings : yes
[DEBUG] Optional features : DLL-Off_mode RZQ/7 RZQ/6
[DEBUG] Thermal features : ASR ext_temp_range
[DEBUG] Thermal sensor : no
[DEBUG] Standard SDRAM : yes
[DEBUG] Rank1 Address bits : mirrored
[DEBUG] DIMM Reference card: B
[DEBUG] Manufacturer ID : 1383
[DEBUG] Part number : CL11-11-11 D3-16
[DEBUG] XMP Profile : 1
[DEBUG] Max DIMMs/channel : 1
[DEBUG] XMP Revision : 1.2
[DEBUG] Requested voltage : 1500 mV
[INFO ] Row addr bits : 16
[INFO ] Column addr bits : 10
[INFO ] Number of ranks : 2
[INFO ] DIMM Capacity : 8192 MB
[INFO ] CAS latencies : 11
[INFO ] tCKmin : 1.250 ns
[INFO ] tAAmin : 13.750 ns
[INFO ] tWRmin : 15.000 ns
[INFO ] tRCDmin : 13.750 ns
[INFO ] tRRDmin : 7.500 ns
[INFO ] tRPmin : 13.750 ns
[INFO ] tRASmin : 35.000 ns
[INFO ] tRCmin : 48.125 ns
[INFO ] tRFCmin : 300.000 ns
[INFO ] tWTRmin : 8.500 ns
[INFO ] tRTPmin : 8.500 ns
[INFO ] tFAWmin : 30.000 ns
[INFO ] tCWLmin : 13.750 ns
[INFO ] tCMDmin : 2
[DEBUG] channel[0] rankmap = 0x3
[DEBUG] SPD probe channel0, slot1
[DEBUG] Not a DDR3 SPD!
[DEBUG] No valid XMP profile found.
[DEBUG] SPD probe channel1, slot0
[DEBUG] SPD probe channel1, slot1
[DEBUG] ECC is disabled
[DEBUG] Starting Ivy Bridge RAM training (full initialization).
[DEBUG] Selected CWL latency : 11T
[DEBUG] Selected tRCD : 11T
[DEBUG] Selected tRP : 11T
[DEBUG] Selected tRAS : 28T
[DEBUG] Selected tWR : 12T
[DEBUG] Selected tFAW : 24T
[DEBUG] Selected tRRD : 6T
[DEBUG] Selected tRTP : 7T
[DEBUG] Selected tWTR : 7T
[DEBUG] Selected tRFC : 240T
[DEBUG] COMP2 done
[DEBUG] COMP1 done
[DEBUG] Done jedec reset
[DEBUG] Done MRS commands
[DEBUG] rcven: 0, 0, 0: 115- 17- 47
[DEBUG] rcven: 0, 0, 1: 4- 35- 67
[DEBUG] rcven: 0, 0, 2: 25- 55- 86
[DEBUG] rcven: 0, 0, 3: 43- 75- 108
[DEBUG] rcven: 0, 0, 4: 60- 91- 123
[DEBUG] rcven: 0, 0, 5: 72- 104- 9
[DEBUG] rcven: 0, 0, 6: 87- 116- 18
[DEBUG] rcven: 0, 0, 7: 104- 4- 33
[DEBUG] 4024++;
[DEBUG] 4028++;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4028 += 2;
[DEBUG] increment 0, 0, 7
[DEBUG] 4024 += 1;
[DEBUG] 4028 += 1;
[DEBUG] lane 0: -6, 2
[DEBUG] Aval: 0, 0, 0: 45
[DEBUG] lane 1: -7, 2
[DEBUG] Aval: 0, 0, 1: 65
[DEBUG] lane 2: -7, 4
[DEBUG] Aval: 0, 0, 2: 85
[DEBUG] lane 3: -8, 0
[DEBUG] Aval: 0, 0, 3: 104
[DEBUG] lane 4: -7, 2
[DEBUG] Aval: 0, 0, 4: 121
[DEBUG] lane 5: -8, 1
[DEBUG] Aval: 0, 0, 5: 134
[DEBUG] lane 6: -4, 5
[DEBUG] Aval: 0, 0, 6: 146
[DEBUG] lane 7: -2, 7
[DEBUG] Aval: 0, 0, 7: 163
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4028 -= 0;
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4/8: 0, 0, 49, 8
[DEBUG] final results:
[DEBUG] rcven: 0, 1, 0: 117- 19- 50
[DEBUG] rcven: 0, 1, 1: 9- 38- 68
[DEBUG] rcven: 0, 1, 2: 27- 59- 92
[DEBUG] rcven: 0, 1, 3: 51- 82- 114
[DEBUG] rcven: 0, 1, 4: 66- 95- 125
[DEBUG] rcven: 0, 1, 5: 77- 106- 8
[DEBUG] rcven: 0, 1, 6: 95- 123- 24
[DEBUG] rcven: 0, 1, 7: 106- 10- 42
[DEBUG] 4024++;
[DEBUG] 4028++;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4028 += 2;
[DEBUG] increment 0, 1, 7
[DEBUG] 4024 += 1;
[DEBUG] 4028 += 1;
[DEBUG] lane 0: -8, 4
[DEBUG] Aval: 0, 1, 0: 48
[DEBUG] lane 1: -6, 3
[DEBUG] Aval: 0, 1, 1: 67
[DEBUG] lane 2: -10, 0
[DEBUG] Aval: 0, 1, 2: 87
[DEBUG] lane 3: -7, 2
[DEBUG] Aval: 0, 1, 3: 112
[DEBUG] lane 4: -4, 4
[DEBUG] Aval: 0, 1, 4: 125
[DEBUG] lane 5: -3, 6
[DEBUG] Aval: 0, 1, 5: 137
[DEBUG] lane 6: -3, 6
[DEBUG] Aval: 0, 1, 6: 153
[DEBUG] lane 7: -8, 1
[DEBUG] Aval: 0, 1, 7: 167
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4028 -= 0;
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4/8: 0, 1, 49, 8
[DEBUG] discover falling edges:
[DEBUG] [4eb0] = 300
[DEBUG] eval 0, 0, 0: 38
[DEBUG] eval 0, 0, 1: 37
[DEBUG] eval 0, 0, 2: 38
[DEBUG] eval 0, 0, 3: 40
[DEBUG] eval 0, 0, 4: 37
[DEBUG] eval 0, 0, 5: 39
[DEBUG] eval 0, 0, 6: 41
[DEBUG] eval 0, 0, 7: 41
[DEBUG] eval 0, 1, 0: 37
[DEBUG] eval 0, 1, 1: 39
[DEBUG] eval 0, 1, 2: 37
[DEBUG] eval 0, 1, 3: 40
[DEBUG] eval 0, 1, 4: 41
[DEBUG] eval 0, 1, 5: 41
[DEBUG] eval 0, 1, 6: 40
[DEBUG] eval 0, 1, 7: 38
[DEBUG] discover rising edges:
[DEBUG] [4eb0] = 200
[DEBUG] eval 0, 0, 0: 39
[DEBUG] eval 0, 0, 1: 40
[DEBUG] eval 0, 0, 2: 39
[DEBUG] eval 0, 0, 3: 38
[DEBUG] eval 0, 0, 4: 38
[DEBUG] eval 0, 0, 5: 41
[DEBUG] eval 0, 0, 6: 40
[DEBUG] eval 0, 0, 7: 38
[DEBUG] eval 0, 1, 0: 40
[DEBUG] eval 0, 1, 2: 40
[DEBUG] eval 0, 1, 3: 39
[DEBUG] eval 0, 1, 4: 38
[DEBUG] eval 0, 1, 5: 38
[DEBUG] eval 0, 1, 6: 39
[DEBUG] eval 0, 1, 7: 41
[DEBUG] CPE
[DEBUG] tx_dqs: 0, 0, 0: 72- 105- 11
[DEBUG] tx_dqs: 0, 0, 1: 95- 127- 32
[DEBUG] tx_dqs: 0, 0, 2: 112- 17- 50
[DEBUG] tx_dqs: 0, 0, 3: 121- 26- 60
[DEBUG] tx_dqs: 0, 0, 4: 12- 45- 79
[DEBUG] tx_dqs: 0, 0, 5: 30- 62- 95
[DEBUG] tx_dqs: 0, 0, 6: 39- 71- 104
[DEBUG] tx_dqs: 0, 0, 7: 48- 80- 113
[DEBUG] tx_dqs: 0, 1, 0: 75- 109- 15
[DEBUG] tx_dqs: 0, 1, 1: 98- 3- 36
[DEBUG] tx_dqs: 0, 1, 2: 116- 21- 54
[DEBUG] tx_dqs: 0, 1, 3: 123- 28- 62
[DEBUG] tx_dqs: 0, 1, 4: 19- 50- 82
[DEBUG] tx_dqs: 0, 1, 5: 31- 63- 96
[DEBUG] tx_dqs: 0, 1, 6: 44- 75- 107
[DEBUG] tx_dqs: 0, 1, 7: 51- 84- 118
[DEBUG] CPF
[DEBUG] tx_dq: 0, 0, 0: 8- 37- 66
[DEBUG] tx_dq: 0, 0, 1: 33- 61- 89
[DEBUG] tx_dq: 0, 0, 2: 49- 77- 106
[DEBUG] tx_dq: 0, 0, 3: 58- 86- 114
[DEBUG] tx_dq: 0, 0, 4: 16- 43- 71
[DEBUG] tx_dq: 0, 0, 5: 32- 60- 88
[DEBUG] tx_dq: 0, 0, 6: 40- 68- 97
[DEBUG] tx_dq: 0, 0, 7: 49- 77- 106
[DEBUG] tx_dq: 0, 1, 0: 14- 42- 70
[DEBUG] tx_dq: 0, 1, 1: 37- 64- 92
[DEBUG] tx_dq: 0, 1, 2: 52- 81- 110
[DEBUG] tx_dq: 0, 1, 3: 61- 88- 115
[DEBUG] tx_dq: 0, 1, 4: 23- 50- 77
[DEBUG] tx_dq: 0, 1, 5: 34- 61- 89
[DEBUG] tx_dq: 0, 1, 6: 45- 74- 103
[DEBUG] tx_dq: 0, 1, 7: 53- 80- 108
[DEBUG] High adjust 0:ffff000000000000
[DEBUG] Bval+: 0, 0, 0, 72 -> 65224
[DEBUG] High adjust 1:ffff000000000000
[DEBUG] Bval+: 0, 0, 1, 95 -> 65247
[DEBUG] High adjust 2:ffff000000000000
[DEBUG] Bval+: 0, 0, 2, 112 -> 65264
[DEBUG] High adjust 3:ffff000000000000
[DEBUG] Bval+: 0, 0, 3, 121 -> 65273
[DEBUG] High adjust 4:ffffffff00000000
[DEBUG] Bval+: 0, 0, 4, 12 -> 65292
[DEBUG] High adjust 5:ffffffff00000000
[DEBUG] Bval+: 0, 0, 5, 30 -> 65310
[DEBUG] High adjust 6:ffffffff00000000
[DEBUG] Bval+: 0, 0, 6, 39 -> 65319
[DEBUG] High adjust 7:ffffffff00000000
[DEBUG] Bval+: 0, 0, 7, 48 -> 65328
[DEBUG] Bval+: 0, 1, 0, 75 -> 65227
[DEBUG] Bval+: 0, 1, 1, 98 -> 65250
[DEBUG] Bval+: 0, 1, 2, 116 -> 65268
[DEBUG] Bval+: 0, 1, 3, 123 -> 65275
[DEBUG] Bval+: 0, 1, 4, 19 -> 65299
[DEBUG] Bval+: 0, 1, 5, 31 -> 65311
[DEBUG] Bval+: 0, 1, 6, 44 -> 65324
[DEBUG] Bval+: 0, 1, 7, 51 -> 65331
[DEBUG] CP5a
[DEBUG] CP5b
[DEBUG] Trying cmd_stretch 2 on channel 0
[DEBUG] cmd_stretch: 0, 0: 0- 127- 255
[EMERG] Command training failed: 0
[ERROR] RAM training failed, trying fallback.
[DEBUG] Disable failing channel.
[DEBUG] Type : b
[DEBUG] Key : 2
[DEBUG] Banks : 8
[INFO ] tCMDmin : 2
[EMERG] No valid DIMMs
MR Updated by Martin Roth about 3 years ago
Are you sure the 2nd DIMM is working? Since one of the two DIMMs works and the other doesn't, it seems suspicious.
You might also want to try clearing the MRC Cache area. Your first boot log said that it was trying stored timings, and those might not work with the 2nd DIMM.
Martin Roth wrote in #note-3:
In fact, one of the memory modules has this fault, and the other memory module has no problem, but neither of the two memory modules has any fault under the OEM bios.
There is no problem with the DIMM socket. I have done some tests with other memory modules.
USB
[INFO ] full_reset() called!
USB
[DEBUG] Type : b
[DEBUG] Key : 2
[DEBUG] Banks : 8
[INFO ] tCMDmin : 2
[DEBUG] channel[1] rankmap = 0x3
[DEBUG] XOVER CLK [c14] = 0
[DEBUG] XOVER CMD [320c] = 4000
[DEBUG] XOVER CLK [d14] = 3000000
[DEBUG] XOVER CMD [330c] = 24000
[DEBUG] COMP2 done
[DEBUG] COMP1 done
[DEBUG] rcven: 1, 0, 0: 2- 32- 63
[DEBUG] rcven: 1, 0, 1: 21- 53- 85
[DEBUG] rcven: 1, 0, 2: 35- 68- 102
[DEBUG] rcven: 1, 0, 3: 56- 86- 116
[DEBUG] rcven: 1, 0, 4: 72- 104- 8
[DEBUG] rcven: 1, 0, 5: 88- 119- 23
[DEBUG] rcven: 1, 0, 6: 103- 3- 32
[DEBUG] rcven: 1, 0, 7: 114- 17- 49
[DEBUG] 4024++;
[DEBUG] 4028++;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4028 += 2;
[DEBUG] increment 1, 0, 6
[DEBUG] increment 1, 0, 7
[DEBUG] 4024 += 1;
[DEBUG] 4028 += 1;
[DEBUG] lane 0: -4, 6
[DEBUG] Aval: 1, 0, 0: 64
[DEBUG] lane 1: -6, 4
[DEBUG] Aval: 1, 0, 1: 84
[DEBUG] Aval: 1, 0, 2: 101
[DEBUG] lane 3: -5, 5
[DEBUG] Aval: 1, 0, 3: 116
[DEBUG] lane 4: -8, 4
[DEBUG] Aval: 1, 0, 4: 134
[DEBUG] lane 5: -7, 3
[DEBUG] Aval: 1, 0, 5: 149
[DEBUG] lane 6: -4, 7
[DEBUG] Aval: 1, 0, 6: 161
[DEBUG] lane 7: -6, 3
[DEBUG] Aval: 1, 0, 7: 176
[DEBUG] 4024 += -1;
[DEBUG] 4028 += -1;
[DEBUG] 4028 -= 1;
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4/8: 1, 0, 48, 6
[DEBUG] Aval: 1, 0, 0: 0
[DEBUG] Aval: 1, 0, 1: 20
[DEBUG] Aval: 1, 0, 2: 37
[DEBUG] Aval: 1, 0, 3: 52
[DEBUG] Aval: 1, 0, 4: 70
[DEBUG] Aval: 1, 0, 5: 85
[DEBUG] Aval: 1, 0, 6: 97
[DEBUG] Aval: 1, 0, 7: 112
[DEBUG] rcven: 1, 1, 0: 3- 34- 65
[DEBUG] rcven: 1, 1, 1: 25- 55- 86
[DEBUG] rcven: 1, 1, 2: 40- 72- 104
[DEBUG] rcven: 1, 1, 3: 60- 92- 125
[DEBUG] rcven: 1, 1, 4: 78- 107- 8
[DEBUG] rcven: 1, 1, 5: 91- 121- 24
[DEBUG] rcven: 1, 1, 6: 113- 13- 41
[DEBUG] rcven: 1, 1, 7: 116- 22- 56
[DEBUG] 4024++;
[DEBUG] 4028++;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4024 -= 2;
[DEBUG] 4028 += 2;
[DEBUG] increment 1, 1, 6
[DEBUG] increment 1, 1, 7
[DEBUG] 4024 += 1;
[DEBUG] 4028 += 1;
[DEBUG] lane 0: -3, 5
[DEBUG] Aval: 1, 1, 0: 66
[DEBUG] lane 1: -6, 5
[DEBUG] Aval: 1, 1, 1: 86
[DEBUG] lane 2: -6, 3
[DEBUG] Aval: 1, 1, 2: 103
[DEBUG] lane 3: -6, 3
[DEBUG] Aval: 1, 1, 3: 124
[DEBUG] lane 4: -3, 8
[DEBUG] Aval: 1, 1, 4: 138
[DEBUG] lane 5: -5, 5
[DEBUG] Aval: 1, 1, 5: 152
[DEBUG] lane 6: -3, 7
[DEBUG] Aval: 1, 1, 6: 171
[DEBUG] lane 7: -10, 0
[DEBUG] Aval: 1, 1, 7: 179
[DEBUG] 4024 += -1;
[DEBUG] 4028 += -1;
[DEBUG] 4028 -= 1;
[DEBUG] 4024 += 0;
[DEBUG] 4028 += 0;
[DEBUG] 4/8: 1, 1, 48, 6
[DEBUG] Aval: 1, 1, 0: 2
[DEBUG] Aval: 1, 1, 1: 22
[DEBUG] Aval: 1, 1, 2: 39
[DEBUG] Aval: 1, 1, 3: 60
[DEBUG] Aval: 1, 1, 4: 74
[DEBUG] Aval: 1, 1, 5: 88
[DEBUG] Aval: 1, 1, 6: 107
[DEBUG] Aval: 1, 1, 7: 115
[DEBUG] eval 1, 0, 0: 43
[DEBUG] eval 1, 0, 1: 41
[DEBUG] eval 1, 0, 2: 41
[DEBUG] eval 1, 0, 3: 42
[DEBUG] eval 1, 0, 4: 39
[DEBUG] eval 1, 0, 5: 41
[DEBUG] eval 1, 0, 6: 41
[DEBUG] eval 1, 0, 7: 41
[DEBUG] eval 1, 1, 0: 40
[DEBUG] eval 1, 1, 1: 43
[DEBUG] eval 1, 1, 2: 41
[DEBUG] eval 1, 1, 3: 41
[DEBUG] eval 1, 1, 4: 41
[DEBUG] eval 1, 1, 5: 41
[DEBUG] eval 1, 1, 6: 41
[DEBUG] eval 1, 1, 7: 37
[DEBUG] eval 1, 0, 0: 41
[DEBUG] eval 1, 0, 1: 43
[DEBUG] eval 1, 0, 2: 43
[DEBUG] eval 1, 0, 3: 41
[DEBUG] eval 1, 0, 4: 40
[DEBUG] eval 1, 0, 5: 42
[DEBUG] eval 1, 0, 6: 40
[DEBUG] eval 1, 1, 0: 41
[DEBUG] eval 1, 1, 1: 44
[DEBUG] eval 1, 1, 2: 43
[DEBUG] eval 1, 1, 3: 42
[DEBUG] eval 1, 1, 4: 40
[DEBUG] eval 1, 1, 5: 39
[DEBUG] eval 1, 1, 6: 40
[DEBUG] eval 1, 1, 7: 42
[DEBUG] CPE
[DEBUG] tx_dqs: 1, 0, 0: 72- 104- 9
[DEBUG] tx_dqs: 1, 0, 1: 92- 124- 28
[DEBUG] tx_dqs: 1, 0, 2: 110- 15- 48
[DEBUG] tx_dqs: 1, 0, 3: 128- 31- 64
[DEBUG] tx_dqs: 1, 0, 4: 14- 47- 80
[DEBUG] tx_dqs: 1, 0, 5: 31- 63- 96
[DEBUG] tx_dqs: 1, 0, 6: 35- 68- 101
[DEBUG] tx_dqs: 1, 0, 7: 50- 82- 114
[DEBUG] tx_dqs: 1, 1, 0: 75- 108- 14
[DEBUG] tx_dqs: 1, 1, 1: 94- 126- 31
[DEBUG] tx_dqs: 1, 1, 2: 114- 18- 51
[DEBUG] tx_dqs: 1, 1, 3: 0- 33- 67
[DEBUG] tx_dqs: 1, 1, 4: 20- 51- 83
[DEBUG] tx_dqs: 1, 1, 5: 32- 64- 96
[DEBUG] tx_dqs: 1, 1, 6: 41- 72- 103
[DEBUG] tx_dqs: 1, 1, 7: 53- 86- 119
[DEBUG] CPF
[DEBUG] tx_dq: 1, 0, 0: 8- 37- 66
[DEBUG] tx_dq: 1, 0, 1: 32- 58- 84
[DEBUG] tx_dq: 1, 0, 2: 47- 74- 102
[DEBUG] tx_dq: 1, 0, 3: 0- 28- 56
[DEBUG] tx_dq: 1, 0, 4: 16- 42- 69
[DEBUG] tx_dq: 1, 0, 5: 33- 58- 83
[DEBUG] tx_dq: 1, 0, 6: 39- 67- 96
[DEBUG] tx_dq: 1, 0, 7: 52- 79- 107
[DEBUG] tx_dq: 1, 1, 0: 13- 41- 70
[DEBUG] tx_dq: 1, 1, 1: 33- 60- 87
[DEBUG] tx_dq: 1, 1, 2: 51- 78- 106
[DEBUG] tx_dq: 1, 1, 3: 0- 27- 55
[DEBUG] tx_dq: 1, 1, 4: 21- 48- 76
[DEBUG] tx_dq: 1, 1, 5: 34- 59- 84
[DEBUG] tx_dq: 1, 1, 6: 44- 72- 101
[DEBUG] tx_dq: 1, 1, 7: 55- 82- 110
[DEBUG] Bval+: 1, 0, 0, 72 -> 65224
[DEBUG] Bval+: 1, 0, 1, 92 -> 65244
[DEBUG] Bval+: 1, 0, 2, 110 -> 65262
[DEBUG] Bval+: 1, 0, 3, 128 -> 65280
[DEBUG] Bval+: 1, 0, 4, 14 -> 65294
[DEBUG] Bval+: 1, 0, 5, 31 -> 65311
[DEBUG] Bval+: 1, 0, 6, 35 -> 65315
[DEBUG] Bval+: 1, 0, 7, 50 -> 65330
[DEBUG] Bval+: 1, 1, 0, 75 -> 65227
[DEBUG] Bval+: 1, 1, 1, 94 -> 65246
[DEBUG] Bval+: 1, 1, 2, 114 -> 65266
[DEBUG] High adjust 3:ffffffff00000000
[DEBUG] Bval+: 1, 1, 3, 0 -> 65280
[DEBUG] Bval+: 1, 1, 4, 20 -> 65300
[DEBUG] Bval+: 1, 1, 5, 32 -> 65312
[DEBUG] Bval+: 1, 1, 6, 41 -> 65321
[DEBUG] Bval+: 1, 1, 7, 53 -> 65333
[DEBUG] CP5a
[DEBUG] CP5b
[DEBUG] Trying cmd_stretch 2 on channel 1
[DEBUG] cmd_stretch: 1, 0: 0- 127- 255
[EMERG] Command training failed: 1
[DEBUG] Type : b
[DEBUG] Key : 2
[DEBUG] Banks : 8
[INFO ] tCMDmin : 2
[EMERG] No valid DIMMs foun
I used Memtest86+ on the OEM BIOS for memory fault testing, and I found that this memory module does have three errors, did the Sandy Bridge Raminit of coreboot find these memory errors, so that the memory initialization failed?
But honestly the logs don't seem to exhibit this failure.
https://gist.github.com/daiaji/37dd447b39b5446d1c023242611125e5
https://gist.github.com/daiaji/46bebdd55477c185614b92a54955bab1
I found a memory module that did not have errors in the MEMTEST86+test, but when I used this memory module with another memory module that did not have faults, there was still a failure that only half of the memory modules could be initialized. The only scenario that can initialize all memory modules is to use two Kingston HyperX FURY.
Regarding the slots, it seems that all the slots are good. If only one memory module is inserted, no matter which slot the memory module is inserted into, coreboot can boot, except for the damaged memory module, only the damaged one The memory module cannot be initialized and booted. This seems to prove that the memory is damaged and the memory initialization cannot be completed. Coreboot uses a more stringent memory test than OEM BIOS?
https://gist.github.com/daiaji/79c848757de5e8aadb89e9e2d992a40e
There are some differences between gpio and OEM BIOS, will there be any problems?
