Bug #579
closedMAC address programmed by coreboot to onboard RTL8111F does not persist
100%
I am producing a coreboot port on Asus P8Z77-V LE PLUS on which this issue is observed. It has a RTL8111F ethernet controller without EEPROM for vital product data.
I enabled the rtl8168 driver in coreboot so I can configure the LEDs and MAC address. Lights work great, but the MAC address always revert to 00:00:00:00:00:05 by the Linux r8169 kernel module. I would then have to reassign its proper MAC address using ip link change eno0 address <mac>.
The device appears to be taking the address I programmed, but r8169 reverts it both on init and teardown, insisting that 00:00:00:00:00:05 is its permanent MAC address.
Survival of coreboot programmed MAC address before r8169 driver is confirmed by a debug read back I inserted in the coreboot rtl81xx driver, as well as by temporarily blacklisting r8169.
Vendor firmware is unaffected.
MR Updated by Martin Roth over 1 year ago
Do you have any boot logs from the linux driver that you could post? My first guess is that the NIC is getting reset, but I think we need more information about what's going on.
Maybe remove the driver and get a dump of the IO and full PCI config space of the chip with both coreboot and the OEM firmwareware to compare.
Maybe also verify the MAC address is still configured right before we jump to the payload.
KH Updated by Keith Hui over 1 year ago
I didn't capture a boot log. Will have to try again.
But as I wrote in the initial issue, with r8169 kernel module blocked, the MAC address programmed by coreboot can survive the entire boot process - through payload, grub, kernel, to userspace. I got the I/O base of the device through lspci, then dumped the I/O port block via /dev/port and checked the contents.
- Assignee set to Keith Hui
- % Done changed from 0 to 90
- Estimated time set to 4.00 h
Fix submitted for review over two patches:
https://review.coreboot.org/c/coreboot/+/87436
https://review.coreboot.org/c/coreboot/+/87437
The MAC address needs to be programmed into a couple ERI registers as well.
- % Done changed from 90 to 100
Fix merged. Good to close.
MD Updated by Matt DeVillier over 1 year ago
- Status changed from New to Closed
