Feature #572
open
AM AM
Add GD25B127D Chip
Feature #572: Add GD25B127D Chip
Added by Arthur Moore almost 2 years ago. Updated over 1 year ago.
Needs Testing
11/30/2024
Please add the "GD25B127D" chip by updating "GD25Q127C/GD25Q128C" To "GD25Q127C/GD25Q128C/GD25B127D"
The GD25B127D chip is almost identical to the GD25Q127C. With the difference that the "Q" variant has an extra feature allowing the Reset pin to be repurposed as a low power "Hold" pin. The bits associated with this function in the status register are not even read by flashrom.
This chip is found on the Dell Latitude 7490 laptop.
Confirmed Working
Read
Erase
Write
Verify
Related links
Device Info / Datasheets
https://www.gigadevice.com/flash-memory/gd25b127d/
https://www.gigadevice.com/flash-memory/gd25q127c/
Tried posting this on GitHub a while ago, but just got around to creating my account here. https://github.com/flashrom/flashrom/issues/275
AK Updated by Anastasia Klimchuk over 1 year ago Actions #1
Hello Arthur,
That was a good idea to create the ticket here! (we don't do development in GitHub).
Would it be possible for you to test a patch? https://review.coreboot.org/c/flashrom/+/86996 Do you still have the chip?
Just in case, here are instructions how to download a patch: https://flashrom.org/dev_guide/development_guide.html#downloading-patch-from-gerrit
If you also could add Tested-by tag in commit message for yourself, that would be ideal!
Tell me how it goes, I certainly can help with updating commit message.
Thank you!
AK Updated by Anastasia Klimchuk over 1 year ago Actions #2
  • Status changed from New to Needs Testing
  • Assignee set to Anastasia Klimchuk
AK Updated by Anastasia Klimchuk over 1 year ago Actions #3
  • Assignee changed from Anastasia Klimchuk to Arthur Moore
