Feature #546
open
AK
Add support for SFDP for probing to differentiate between flash chips with same ID but different capabilities
Feature #546: Add support for SFDP for probing to differentiate between flash chips with same ID but different capabilities
Added by Anastasia Klimchuk over 2 years ago.
New
07/02/2024
Newer chips support SFDP (Serial Flash Discoverable Parameter), a
specification that allows (at least) SPI flash chips to self-document
themselves to software, and that nearly all flash chips from the last
decade or so support.
One can
even use whether the probed flash chip supports SFDP to rule out
entries (a flash chip that does not respond to SFDP should not be used
with a chip definition of a SFDP-capable chip).
https://mail.coreboot.org/hyperkitty/list/flashrom@flashrom.org/thread/UCCMBKV5O4JXX4XD5DLFFH5BKEUUXWX2/
No data to display
