Feature #544
open
AK
Make default probe_timing = TIMING_ZERO so that it doesn't need to be set for every flashchip
Feature #544: Make default probe_timing = TIMING_ZERO so that it doesn't need to be set for every flashchip
Added by Anastasia Klimchuk over 2 years ago.
New
06/27/2024
Most of the flashchips have probe_timing = TIMING_ZERO in flashchip definition. We can make it default and remove lots of those lines from flashchips.c file.
For those few chips which have other values, they can be set in flashchips.c
No data to display
