Feature #523
closed
ET AK
Add support for flash Winbond W25N01GV
Feature #523: Add support for flash Winbond W25N01GV
Added by E T almost 3 years ago. Updated over 2 years ago.
Closed
01/20/2024
I'd like to try this (https://www.winbond.com/hq/product/code-storage-flash-memory/qspinand-flash/?__locale=en&partNo=W25N01GV) flash but I saw that there is no flashrom support, is it possible to add it?
At the moment I don't physically have a flash, I should have one soon so I can try.
In the meantime I developed this patch for flashrom is it ok?
diff --git a/flashchips.c b/flashchips.c
index 663b01b2..7abb95b4 100644
--- a/flashchips.c
+++ b/flashchips.c
@@ -20317,6 +20317,50 @@ const struct flashchip flashchips[] = {
                .decode_range   = DECODE_RANGE_SPI25,
+               .vendor         = "Winbond",
+               .name           = "W25N01GV",
+               .bustype        = BUS_SPI,
+               .manufacture_id = WINBOND_NEX_ID,
+               .model_id       = WINBOND_NEX_W25N01GV,
+               .total_size     = 131072,
+               .page_size      = 256,
+               .feature_bits   = FEATURE_WRSR_WREN | FEATURE_OTP,
+               .tested         = TEST_UNTESTED,
+               .probe          = PROBE_SPI_RDID,
+               .probe_timing   = TIMING_ZERO,
+               .block_erasers  =
+                               .eraseblocks = { {4 * 1024, 32768} },
+                               .block_erase = SPI_BLOCK_ERASE_21,
+                               .block_erase = SPI_BLOCK_ERASE_20,
+                               .eraseblocks = { {32 * 1024, 4096} },
+                               .block_erase = SPI_BLOCK_ERASE_5C,
+                               .block_erase = SPI_BLOCK_ERASE_52,
+                               .eraseblocks = { {64 * 1024, 2048} },
+                               .block_erase = SPI_BLOCK_ERASE_DC,
+                               .block_erase = SPI_BLOCK_ERASE_D8,
+                               .eraseblocks = { {65536 * 1024, 2} },
+                               .block_erase = SPI_BLOCK_ERASE_C4,
+               .printlock      = SPI_PRETTYPRINT_STATUS_REGISTER_PLAIN,
+               .unlock         = SPI_DISABLE_BLOCKPROTECT,
+               .write          = SPI_CHIP_WRITE256, /* Multi I/O supported */
+               .read           = SPI_CHIP_READ,
+               .voltage        = {2700, 3600},
        /* W29EE011, W29EE012, W29C010M, W29C011A do not support probe_jedec according to the datasheet, but it works for newer(?) steppings. */
diff --git a/include/flashchips.h b/include/flashchips.h
index d676cda4..fb7abae6 100644
--- a/include/flashchips.h
+++ b/include/flashchips.h
@@ -1007,6 +1007,7 @@
 #define WINBOND_NEX_W25Q128_DTR        0x8018  /* W25Q128JW_DTR */
 #define WINBOND_NEX_W25Q256_DTR        0x8019  /* W25Q256JW_DTR aka W25Q256256JW-IM */
 #define WINBOND_NEX_W25Q512NW_IM       0x8020 /* W25Q512NW-IM */
+#define WINBOND_NEX_W25N01GV   0xAA21  /* W25N01GV */
 #define WINBOND_ID             0xDA    /* Winbond */
 #define WINBOND_W19B160BB      0x49
I didn't understand if the FEATURE_WRSR_WREN feature bit can be enabled for these flashes.
Do I need to set the reg_bits?
I don't want to be unprepared when I get to try this flash.
ET Updated by E T over 2 years ago Actions #1
  • Assignee set to Anastasia Klimchuk
ET Updated by E T over 2 years ago Actions #2
I tested my code and doesn't work, so I'll wait someone implement a better support for this flash.
AK Updated by Anastasia Klimchuk over 2 years ago Actions #3
Hello! Just to check, have you seen the guidelines how to add new chip?
https://www.flashrom.org/contrib_howtos/how_to_add_new_chip.html
Also, what exactly doesn't work?
You can try send your code as a patch (after following the guidelines of course) and give the info on what exactly doesn't work?
ET Updated by E T over 2 years ago Actions #4
Hello, thanks for the suggestion, I hadn't read the guidelines. I will study them and try to develop the patch better, but already looking at the "Model ID and vendor ID" part, this flash has 4 bytes to identify it and the PROBE_SPI_RDID4 method requires the first byte to be 0x7f and not 0x00.
AK Updated by Anastasia Klimchuk over 2 years ago Actions #5
Why do want to use PROBE_SPI_RDID4 ?
From the datasheet, the chip supports 9fh which the most common way and it corresponds to PROBE_SPI_RDID ? It should identify as AA21h (I saw it on pages 23-24 in datasheet).
ET Updated by E T over 2 years ago Actions #6
  • Related links updated (diff)
ET Updated by E T over 2 years ago Actions #7
Sorry for the big delay
yes support JEDEC ID 9Fh, but the first byte is dummy
Commands OpCode Byte2 Byte3 Byte4 Byte5
JEDEC ID 9Fh    Dummy EFh   AAh   21h
If I try to read with PROBE_SPI_RDID vendor is 0x00 while CHIP ID is 0xEF 0xAA
ET Updated by E T over 2 years ago Actions #8
I abbandoned flashrom I found this project https://github.com/sele-nium/flash_w25n which resolve my issue.
I think flashrom is too complex to do a simple thing.
Also for read JEDEC ID I had to apply a patch.
ET Updated by E T over 2 years ago Actions #9
ET Updated by E T over 2 years ago Actions #10
  • % Done changed from 100 to 0
ET Updated by E T over 2 years ago Actions #11
  • Status changed from New to Needs Testing
ET Updated by E T over 2 years ago Actions #12
  • Status changed from Needs Testing to Closed
AK Updated by Anastasia Klimchuk over 2 years ago Actions #13
Good to know you found something that works for you! That's good news.
