Bug #512
closed
BX PG
1MiB heap breaks TSEG stage cache resume on many platforms
Bug #512: 1MiB heap breaks TSEG stage cache resume on many platforms
Added by Bill XIE about 3 years ago. Updated about 3 years ago.
Resolved
High
coreboot common code
10/27/2023
GM45, Ivy Bridge
GNU/Linux
commit 44a48ce7a46c ("Kconfig: Bring HEAP_SIZE to a common, large value") proves to break S3 resume from TSEG stage cache on many platforms, including GM45 and Ivy Bridge.
coreboot-4.21-587-g9b230ae29557 Fri Oct 13 18:35:11 UTC 2023 x86_32 postcar starting (log level: 7)...
Timestamp - start of postcar: 248582576
Timestamp - end of postcar: 248589814
S3 Resume
Error: Can't find stage_cache 57a9e100 in imd
ramstage cache invalid.
board_reset() called!
system_reset() called!
It seems that the commit above has not experienced many test for S3 resume before getting merged.
The default heap size may have to be reconsidered.
AP Updated by Andrei Purdea about 3 years ago Actions #1
A number of libreboot users are also experiencing this, see here: https://codeberg.org/libreboot/lbmk/issues/140
Either disabling Stage Cache, or increasing SMM_RESERVED_SIZE makes the problem go away.
MR Updated by Martin Roth about 3 years ago Actions #2
  • Status changed from Needs Testing to Resolved
Issue should be fixed. The patch that caused the problems was reverted.
https://review.coreboot.org/c/coreboot/+/78850
