Bug #498
open
VV AK
DediProg SF600Plus unable to flash W25Q512JV chip
Bug #498: DediProg SF600Plus unable to flash W25Q512JV chip
Added by Vojtech Vesely over 3 years ago. Updated about 3 years ago.
New
Programmer
06/29/2023
DediProg SF600Plus
I am working on adding support for chip Winbond W25Q512JV-FIM, which should be quite similar to existing W25Q512JV. Writing to the chip is a problem, reading is fine.
$ ./flashrom -p dediprog -w random.bin
flashrom 1.4.0-devel (git:v1.2-1310-g1ee04cd5) on Linux 6.3.9-arch1-1 (x86_64)
flashrom is free software, get the source code at https://flashrom.org
Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
Using dediprog id SF000000.
Found Generic flash chip "unknown SPI chip (REMS)" (0 kB, SPI) on dediprog.
This flash part has status NOT WORKING for operations: PROBE READ ERASE WRITE
This flash part has status UNTESTED for operations: WP
The test status of this chip may have been updated in the latest development
version of flashrom. If you are running the latest development version,
please email a report to flashrom@flashrom.org if any of the above operations
work correctly for you with this flash chip. Please include the flashrom log
file for all operations you tested (see the man page for details), and mention
which mainboard or programmer you tested in the subject line.
Thanks for your help!
Error: Image size (67108864 B) doesn't match the expected size (0 B)!
This problem does not appear in v1.3, only in master branch.
Used hardware:
  • Programmer: DediProg SF600Plus, Firmware version : 7.3.08, Hardware version : 2.3
  • Chip: W25Q512JV-FIM
VV Updated by Vojtech Vesely over 3 years ago Actions #1
  • Description updated (diff)
AK Updated by Anastasia Klimchuk about 3 years ago Actions #2
  • Assignee set to Anastasia Klimchuk
