Bug #497
open
FS
coreboot 4.21 release schedule
Bug #497:
New
06/29/2023
Overview schedule¶
| Time | Affects | Events | |
| ✘ | T-6 weeks | b: master |
Sending announcement & starting with release preparations |
| ✘ | T-4 weeks | b: master |
Freezing of toolchain |
| ✘ | T-2 weeks | b: master |
Fixing release date & sending reminders |
| ✘ | T-1 week | b: master |
Finalizing release preparations |
| ✘ | T-1 day | b: master |
Double checking everything is fine |
| ✘ | T-0 (TBD) |
b: master, b: 4.21_branch, t: 4.21
Release! |
| ✘ | T+1 day |
Post-release steps & last minute fixes |
| ✘ | T+1 week | Announcement & publishing |
Task list¶
~6 weeks prior to release¶
- [_] Announce upcoming release to mailing list, ask people to test and to update release notes.
- [_] Start marking patches that should to go into the release with a tag
coreboot_release_4.21
~4 weeks prior to release¶
- [_] Freezing toolchain state. Only relevant fixes are allowed from this point on.
~2 weeks prior to release¶
- [_] Send reminder email to mailing list, ask for people to test, and to update the release notes.
- [_] Update the topic in the IRC channel with the date of the upcoming release.
~1 week prior to release¶
- [_] If there are any deprecations announced for the following release, make sure that a list of currently affected boards and chipsets is part of the release notes.
- [_] Finalize release notes as much as possible
- [_] Prepare release notes template for following release
- [_] Update
Documentation/releases/index.md - [_] Check which branches need to be released. Any branch with changes should get a new release. Announce these branch releases and prepare release notes.
Day before release¶
- [_] Make sure patches with tags for the release are merged.
- [_] Announce to IRC that the release will be tomorrow and ask for testing.
- [_] Run
util/vboot_list/vboot_list.shscript to update the list of boards supported by vboot.
Day of release¶
- [_] Review the full documentation about doing the release below.
- [_] Select a commit ID to base the release upon.
- [_] Test the commit selected for release.
- [_] Submit last pre-release release notes.
- [_] Run the release script.
- [_] Test the release from the actual release tarballs.
- [_] Push signed Tag to repo. This is the actual release step. Once this patch is pushed, the release itself has been done. everything after this step is packaging and delivering the release.
- [_] Announce that the release tag is done on IRC.
- [_] Update the topic in the IRC channel that the release is done.
- [_] Do the final release notes - Fill in the release date, remove "Upcoming release" and other filler from the current release notes.
- [_] ADMIN: Upload release files to web server.
- [_] ADMIN: Upload the final release notes to the web server.
- [_] ADMIN: Upload crossgcc sources to web server.
- [_] Create coreboot-sdk and coreboot-jenkins-node docker images based on the release ID and push them to dockerhub. These can be used as release builders.
Week following the release¶
- [_] Update download page to point to files, push to repo.
- [_] Write and publish blog post with release final notes. Branch releases notes should be included in the same post.
- [_] Remove code that was announced it was going to be removed.
- [_] Update
Documentation/releases/boards_supported_on_branches.md
FS Updated by Felix Singer over 3 years ago
- Description updated (diff)
- Subject changed from coreboot release 4.21 checklist to [TEST] coreboot release 4.21 checklist
- Subject changed from [TEST] coreboot release 4.21 checklist to coreboot release 4.21 checklist
- Subject changed from coreboot release 4.21 checklist to coreboot 4.21 release schedule
