Bug #483
closed
FL
`make iasl` can't fetch R10_20_22.tar.gz since it stores it under a different name
Bug #483: `make iasl` can't fetch R10_20_22.tar.gz since it stores it under a different name
Added by First name * Last name * over 3 years ago. Updated over 3 years ago.
Rejected
04/19/2023
Downloading and verifying tarballs ...
 * R10_20_22.tar.gz (downloading from https://github.com/acpica/acpica/archive/refs/tags/R10_20_22.tar.gz)..... Failed to download R10_20_22.tar.gz.
make[1]: *** [Makefile:24: build_iasl] Error 1
‰ cat ./util/crossgcc/sum/R10_20_22.tar.gz.cksum
560d9e43692e1957bcf24a9bdd663ffe77da88dd  tarballs/R10_20_22.tar.gz
‰ sha1sum util/crossgcc/tarballs/acpica-R10_20_22.tar.gz
560d9e43692e1957bcf24a9bdd663ffe77da88dd  util/crossgcc/tarballs/acpica-R10_20_22.tar.gz
MR Updated by Martin Roth over 3 years ago Actions #1
  • Status changed from New to Rejected
I can't reproduce this issue. It downloaded the tarball fine for me.
Going to the ACPICA site on github shows that this is the correct URL:
https://github.com/acpica/acpica/tags
Closing the issue as rejected.
FL Updated by First name * Last name * over 3 years ago Actions #2
Martin Roth wrote in #note-1:
The problem is not about the URL, but about the name wget saves the archive under. buildgcc doesn't request a specific name from wget, but expects it to store the downloaded file at a specific name. Apparently you don't have content-disposition = on in your /etc/wgetrc so it happens to work for you.
