Cleanup #480
open
PM
amd/common/acpi/gpio_bank_lib.asl: IASL remarks: Creation of named objects within a method is highly inefficient, use globals or method local variables instead
Cleanup #480:
04/10/2023
Building AMD boards using AMD common code like google/kahlee (Careena) or google/myst, IASL show the remarks below:
$ git log --oneline --no-decorate -1
f2e8865d76 soc/amd/common/blk/pcie: Program LTR max latencies
$ make menuconfig
$ make -j4
Intel ACPI Component Architecture
ASL+ Optimizing Compiler/Disassembler version 20200925
Copyright (c) 2000 - 2020 Intel Corporation
dsdt.asl 49: Name(BUFF, Buffer(Local0) {})
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.S2BF)
dsdt.asl 117: OperationRegion (GPDW, SystemMemory, Local0, 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.GPRD)
dsdt.asl 126: OperationRegion (GPDW, SystemMemory, Local0, 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.GPWR)
dsdt.asl 134: OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.STXS)
dsdt.asl 143: OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.CTXS)
dsdt.asl 152: OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.GRXS)
dsdt.asl 162: OperationRegion (GPDW, SystemMemory, GPAD (Arg0), 4)
Remark 2173 - ^ Creation of named objects within a method is highly inefficient, use globals or method local variables instead (\_SB.GTXS)
ASL Input: dsdt.asl - 33891 bytes 1278 keywords 901 source lines
AML Output: dsdt.aml - 13412 bytes 909 opcodes 369 named objects
Compilation successful. 0 Errors, 0 Warnings, 7 Remarks, 295 Optimizations, 46 Constants Folded
IASL 3150 warning types were ignored!
IASL build/dsdt.aml disassembled correctly.
Moved to common in commit 251d305e73f7 (soc/amd/stoneyridge: Move GPIO support to common).
MR Updated by Martin Roth over 3 years ago
- Tracker changed from Bug to Cleanup
As these are remarks, it would certainly be nice if they were fixed, but I can't call this a bug, even if it isn't efficient.
Changing from Bug to Cleanup. Leaving priority as normal, because I agree with Paul that this should be addressed.
