Bug #478
openX200 booting Linux takes a long time with TSC (`clocksource=hpet` works)
dmesg: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
After a period of time the boot finished by auto-switching to hpet. Setting kernel parameter directly to clocksource=hpet the system is booting fast.
Why is the faster clocksource tsc not working and tells coreboot is broken ?
Files
Related links
Thank you for reporting this issue. Does booting with 'tsc=unstable also work?
Please the coreboot log messages for example by running cbmem -1.
PM Updated by Paul Menzel over 3 years ago
- Subject changed from X200 booting takes a long time to X200 booting Linux takes a long time with TSC (`clocksource=hpet` works)
RG Updated by Robert Gruber over 3 years ago
- Target version changed from none to main
BX Updated by Bill XIE over 3 years ago
After a period of time the boot finished by auto-switching to hpet. Setting kernel parameter directly to clocksource=hpet the system is booting fast.Why is the faster clocksource tsc not working and tells coreboot is broken ?
As stated in https://www.chromium.org/chromium-os/how-tos-and-troubleshooting/tsc-resynchronization/ , there are 4 types of TSC, while a core 2 cpu only has Constant TSC, which may change on C state transitions.
Newer cpu like Ivy Bridge have nonstop_tsc and tsc_deadline in addition to constant_tsc. They can keep using tsc as clock source.
Does this issue remain on an x200 running vendor firmware?
- Affected OS set to xubuntu 22.04 LTS, Trisquel 11.0
Bill XIE wrote in #note-4:
Only coreboot is affected. On vendor firmware the system boots with kernel defaults and clocksource=hpet fast.
NH Updated by Nico Huber over 3 years ago
Can you provide a dmesg log? or even better, one with coreboot and one with vendor. It's probably just a flag somewhere that's telling Linux to use TSC. But that's easiest debugged in the OS.
- File dmesg_slow.log dmesg_slow.log added
- File dmesg_fast_with_clocksource_hpet.log dmesg_fast_with_clocksource_hpet.log added
Nico Huber wrote in #note-7:
The coreboot dmesg log files are in the attachment. I have seen that some disks on AHCI are not affected by this issue some disks are affected. NVMe disks in the express card slot are always affected. clocksource=hpet always solves the problem for AHCI and NVMe disks.
Robert Gruber wrote in #note-6:
Whether it boots fast is not so important. We want to know whether tsc is unstable under vendor firmware, so could you provide a dmesg log under vendor firmware, with kernel defaults?
Booting a Kali live on an x200 running vender firmware shows that the tsc seems stable enough, while on coreboot tsc becomes unstable.
- File dmesg-x200-cb-kali.log dmesg-x200-cb-kali.log added
4.19-1073-gcc5efa5c66 is https://review.coreboot.org/c/coreboot/+/74182/8
- File dmesg-x200-cb-kali-2.log dmesg-x200-cb-kali-2.log added
Bill XIE wrote in #note-12:
Bill XIE wrote in #note-10:
This dmesg log is collected on the same x200 from which dmesg-x200-vendor-kali.log is collected, running the same 4.19-1073-gcc5efa5c66 coreboot image. It may be a better comparable log.
- File dmesg_vendor_x200t_fast.log dmesg_vendor_x200t_fast.log added
- File dmesg_vendor_x200t_fast_without_clocksource_parameter.log dmesg_vendor_x200t_fast_without_clocksource_parameter.log added
Bill XIE wrote in #note-9:
I tested same AHCI disk on an X200T with vendor bios (please see attachments). tsc works fine and clocksource=hpet as well. Of course I can not test NVMe with vendor bios because there is no boot support.
In coreboot the system hangs for a while until it obviously autochanges to clocksource=hpet and boots normal.
Robert, thank you for providing all the information. As an update, on #coreboot@irc.libera.chat people suggested it might be the clockgen setup, and Arthur provided a patch. Unfortunately, it didn’t seem to help.
To collect some data points, could you please provide the output of the comment below with the vendor firmware and with coreboot?
$ sudo modprobe i2c-dev
$ sudo i2cdetect -l
i2c-7 smbus SMBus I801 adapter at f040 SMBus adapter
$ sudo i2cdump -y 7 0x69 s
Replace the bus 7 with the value X in i2c-X in the i2cdetect output.
Paul Menzel wrote in #note-15:
$ sudo modprobe i2c-dev $ sudo i2cdetect -l […] i2c-7 smbus SMBus I801 adapter at f040 SMBus adapter […] $ sudo i2cdump -y 7 0x69 sReplace the bus 7 with the value X in i2c-X in the i2cdetect output.
It's a pleasure for me to help. I got the following output on both coreboot and vendor bios:
$ apt-get install i2c-tools
$ sudo i2cdetect -l
i2c-0 smbus SMBus I801 adapter at 0400 SMBus adapter
i2c-1 i2c i915 gmbus ssc I2C adapter
i2c-2 i2c i915 gmbus vga I2C adapter
i2c-3 i2c i915 gmbus panel I2C adapter
i2c-4 i2c i915 gmbus dpc I2C adapter
i2c-5 i2c i915 gmbus dpb I2C adapter
i2c-6 i2c i915 gmbus dpd I2C adapter
i2c-7 i2c AUX B/DP B I2C adapter
i2c-8 i2c AUX C/DP C I2C adapter
i2c-9 i2c AUX D/DP D I2C adapter
$ sudo i2cdump -y 0 0x69 s
SMBus block mode is deprecated, please use i2cget instead
Error: Block read failed, return code -6
Btw: There is no loaded i2c-dev module:
$ lsmod |grep -i i2c
i2c_algo_bit 16384 1 i915
i2c_i801 36864 0
i2c_smbus 20480 1 i2c_i801
Is the output of i2cget still needed because of the deprecated i2cdump ? If yes, how do I get the required data with i2cget ?
Output from i2cget:
$ sudo i2cget -y 0 0x69 s
Error: Data address invalid!
Usage: i2cget [-f] [-y] [-a] I2CBUS CHIP-ADDRESS [DATA-ADDRESS [MODE [LENGTH]]]
I2CBUS is an integer or an I2C bus name
ADDRESS is an integer (0x08 - 0x77, or 0x00 - 0x7f if -a is given)
MODE is one of:
b (read byte data, default)
w (read word data)
c (write byte/read byte)
s (read SMBus block data)
i (read I2C block data)
Append p for SMBus PEC
LENGTH is the I2C block data length (between 1 and 32, default 32)
