Feature #476
open
BX
Add option to convert coreboot-inited linear frame buffer to efifb directly
Feature #476: Add option to convert coreboot-inited linear frame buffer to efifb directly
Added by Bill XIE over 3 years ago. Updated over 2 years ago.
New
coreboot common code
03/30/2023
70%
GNU/Linux
Currently, the linear frame buffer that coreboot initializes should be handled by Linux kernel with dedicated driver "simplefb", but most installer of GNU/Linux distributions only enables "efifb" support, which causes a GNU/Linux installer kexec-ed from a Linux payload running atop simplefb unable to output graphics.
Currently, Grub payload could turn coreboot-initialized simplefb to efifb, which can be easily examined from the dmesg log of GNU/Linux booted from Grub payload running atop coreboot-inited linear frame buffer (simplefb). Chainloading a Linux payload with a minimal Grub payload only containing module "linux" and "cbfs" could make the Linux payload running atop efifb, of which GNU/Linux installers can make use, but the related code could be ported to coreboot to make things easier.
BX Updated by Bill XIE over 3 years ago Actions #1
"Grub payload could turn coreboot-initialized simplefb to efifb" turns out that grub payload can read video mode info from the coreboot table and fill them into a struct linux_kernel_params in include/grub/i386/linux.h (corresponding to struct linux_params of util/cbfstool/linux.h and struct screen_info in include/uapi/linux/screen_info.h of Linux kernel) to boot the Linux kernel, and set the member have_vga (corresponding to orig_video_isVGA of struct linux_params and struct screen_info) to GRUB_VIDEO_LINUX_TYPE_SIMPLE (0x70, corresponding to VIDEO_TYPE_EFI in Linux kernel), allowing the driver efifb to take over the framebuffer.
To copy this behavior in coreboot, features to identify a linux payload at runtime and to modify the linux_params at runtime may have to be added.
PM Updated by Paul Menzel over 3 years ago Actions #2
  • Related links updated (diff)
persmule proposes lib: Hook the FB setting function for Linux to payload loading routine.
One comment from #: AFAICS, we have avoided payload-specific code in coreboot so far
BX Updated by Bill XIE over 3 years ago Actions #4
  • % Done changed from 0 to 70
