Bug #475
closed
BX BX
mainboard_vbt_filename() in src/mainboard/lenovo/x200/blc.c does not work as intended
Bug #475: mainboard_vbt_filename() in src/mainboard/lenovo/x200/blc.c does not work as intended
Added by Bill XIE over 3 years ago. Updated almost 3 years ago.
Resolved
board support
03/30/2023
100%
x200
Date back to coreboot 4.9, mainboard_vbt_filename() in src/mainboard/lenovo/x200/blc.c calls get_blc_pwm_freq_value(NULL), making the following if condition always falling to the first, not to mention null dereference on strcmp() in get_blc_pwm_freq_value().
In order to determine the correct vbt filename at runtime, edid ascii string should be obtained first.
This issue may be distantly related to #474.
Related links
This is going to be fixed with https://review.coreboot.org/c/coreboot/+/74181 .
BX Updated by Bill XIE over 3 years ago Actions #1
  • Assignee changed from Arthur Heymans to Bill XIE
  • % Done changed from 0 to 90
  • Related links updated (diff)
BX Updated by Bill XIE over 3 years ago Actions #2
  • % Done changed from 90 to 100
MR Updated by Martin Roth over 3 years ago Actions #3
Can this be closed now?
BX Updated by Bill XIE over 3 years ago Actions #4
Martin Roth wrote in #note-3:
Sure.
MR Updated by Martin Roth almost 3 years ago Actions #5
