Bug #474
openX200s crashes after graphic init with 8GB RAM
My X200s with panel LTD121EQ3B and 2x4GB identical RAM running a coreboot-4.19-937-g0b192d3238 built for X200, configured with the attached x200s.cfg, having the following contents, crashed with beeping after graphic init (screen lights), and before booting from the grub-based payload.
FMAP REGION: COREBOOT
Name Offset Type Size Comp
cbfs_master_header 0x0 cbfs header 32 none
fallback/romstage 0x80 stage 69240 none
cpu_microcode_blob.bin 0x10f80 microcode 49152 none
fallback/ramstage 0x1cfc0 stage 130413 LZMA (297648 decompressed)
config 0x3cdc0 raw 3019 LZMA (9596 decompressed)
revision 0x3d9c0 raw 716 none
build_info 0x3dcc0 raw 101 none
fallback/dsdt.aml 0x3dd80 raw 14999 none
cmos.default 0x41880 cmos_default 256 none
cmos_layout.bin 0x419c0 cmos_layout 1696 none
fallback/postcar 0x420c0 stage 33912 none
data_ccfl.vbt 0x4a580 raw 1501 LZMA (3854 decompressed)
data_led.vbt 0x4abc0 raw 1439 LZMA (3863 decompressed)
(empty) 0x4b1c0 null 7140 none
fallback/payload 0x4cdc0 simple elf 7123033 none
(empty) 0x717e80 null 853028 none
bootblock 0x7e82c0 bootblock 31488 none
This problem will disappear if I remove one DIMM, remove vbt files from CBFS, or enable EHCI debug with FT232H, which makes me unable to catch it.
Files
BX Updated by Bill XIE over 3 years ago
To ease previewing, the attached config file has been renamed to config-x200s.txt.
The problem disappears if only ehci debug is enabled, even if no ft232h is plugged in.
This bug may also occur on ordinary X200. The detailed effect may vary, though.
Other payloads (including grub payload built via ordinary way) will not trigger this bug.
Disabling unnecessary PS/2 keyboard init can also make this problem disappear.
