Bug #463
closed
FN
nvramtool: coreboot table not found on Starbook Mark VI
Bug #463: nvramtool: coreboot table not found on Starbook Mark VI
Added by Felix Niederwanger almost 4 years ago. Updated almost 4 years ago.
Resolved
02/18/2023
Starbook Mark VI
openSUSE Tumbleweed
The nvramtool on my Starbook Mark VI reports that it can't find the coreboot table:
# nvramtool -d
nvramtool: coreboot table not found.  coreboot does not appear to
        be installed on this system.  Scanning for the table produced the
        following results:
            0 valid signatures were found with bad header checksums.
            0 valid headers were found with bad table checksums.
I compiled the nvramtool freshly on my Laptop using the documentation from https://www.coreboot.org/Nvramtool
$ git clone http://review.coreboot.org/coreboot.git
$ cd coreboot/util/nvramtool
$ make
System info
  • openSUSE Tumbleweed
  • Kernel 6.1.12-1-default
Related links
It might be, that the coreboot image is built without USE_OPTION_TABLE selected.
FN Updated by Felix Niederwanger almost 4 years ago Actions #1
  • Description updated (diff)
  • Affected hardware set to Starbook Mark VI
  • Affected OS set to openSUSE Tumbleweed
  • Affected versions main added
SR Updated by Sean Rhodes almost 4 years ago Actions #2
That's one you'll want to get in touch with our support about -
FN Updated by Felix Niederwanger almost 4 years ago Actions #3
Will do - thank you!
PM Updated by Paul Menzel almost 4 years ago Actions #4
  • Related links updated (diff)
