Feature #411
open
AK
AK
Fix unit tests to run on all supported environments (non-Linux, clang vs gcc, etc)
Feature #411:
09/01/2022
70%
The list of issues to fix below (can be updated if new issues found).
- DONE Mocks for
_fprintf_chkare missing (needed for clang on Linux) - DONE I/O mock functions need to be renamed so that they do not have name clash with standard I/O, because the latter are allowed to be macros
Current idea is to addiom_prefix for all functions members ofstruct io_mock - DONE Refactor the code so that
linux/spidev.hheader is only included when building for Linux - DONE Fix failing tests on FreeBSD (4 tests in chip.c: 2 write chip and 2 verify chip)
- DONE BSD family
- MacOS needs verifying
AK Updated by Anastasia Klimchuk about 4 years ago
- Description updated (diff)
FS Updated by Felix Singer about 4 years ago
What's the status here? Any progress? Is it resolved?
- % Done changed from 0 to 50
Oh yes there is progress! 3 and 4 done, and those were the challenging part. So I am marking 50% done.
1 and 2 left, which needs more code than 3 and 4, but that is way more straightforward task.
AK Updated by Anastasia Klimchuk almost 4 years ago
- and 2) done as well.
- % Done changed from 50 to 70
I added 5) to the description
- Parent task deleted (
#353)
- Category changed from Release prep to Build system
AK Updated by Anastasia Klimchuk over 3 years ago
