Feature #409
open
AK
If libusb system is too old, build system should not build the programmers which depend on newer libusb
Feature #409: If libusb system is too old, build system should not build the programmers which depend on newer libusb
Added by Anastasia Klimchuk about 4 years ago.
New
Build system
08/25/2022
For the programmers depending on libusb, they may assume some minimum version of the library (for example ch341a_spi.c , raiden_debug_spi.c etc)
Version checks on libraries should be done by the build system instead of in the flashrom code. When a library version is not supported by a programmer it shouldn't be even compiled in.
No data to display
