Support #369
open
AK
LF
Check Spansion chips definitions
Support #369:
04/28/2022
50%
Chips to check:
- S25FL128S
- S25FL129P
- S25FL256S
- S25FS128S
- {F,S,V}29C51001B
For example what does it mean.total_size = 16384, /* This is just half the size.... */
AK Updated by Anastasia Klimchuk over 4 years ago
- Assignee set to Nikolai Artemiev
FS Updated by Felix Singer about 4 years ago
- Tracker changed from Feature to Support
- Target version changed from 1.3 to main
LF Updated by Liam Flaherty about 4 years ago
- Assignee changed from Nikolai Artemiev to Liam Flaherty
AK Updated by Anastasia Klimchuk almost 4 years ago
- % Done changed from 0 to 50
- Parent task deleted (
#353)
LF Updated by Liam Flaherty almost 4 years ago
S25FL128S: Appears OK. 20h command is ignored for 256-bit sectors. For other sector sizes: It appears there is a limitation in flashrom as this is for parameter sector erases only, so it is omitted entirely. The other erasers are present.
S25FL129P: Appears OK. 20h also missing for similar reasons.
S25FL256S: Mostly OK*. 20h also missing for similar reasons.
S25FS128S: Appears OK. 20h also missing for similar reasons.
{F,S,V}29C51001B: Appears OK.
- All the 32MB chips are only declared as 16MB. I haven't been able to identify any reason for this limitation - I am still checking this detail.
