Bug #33
closed
MR
cbmem utility fails on newer linux kernels "Failed to mmap /dev/mem: Resource temporarily unavailable"
Bug #33: cbmem utility fails on newer linux kernels "Failed to mmap /dev/mem: Resource temporarily unavailable"
Added by Martin Roth almost 11 years ago. Updated almost 4 years ago.
Closed
02/05/2016
This has been going on for a while. Paul mentioned it here:
https://www.coreboot.org/pipermail/coreboot/2015-September/080383.html
AD Updated by Aaron Durbin over 10 years ago Actions #1
This has a little more succinct issue as to what is going on:
https://www.coreboot.org/pipermail/coreboot/2015-October/080568.html
In short, smbios and ACPI memory both live in cbmem. However, the two drivers use 2 different map() attributes covering sub regions within cbmem. The cbmem utility currently assumes a cacheable mapping attribute which is in conflict w/ the persistent uncacheable smbios mapping.
MR Updated by Martin Roth almost 4 years ago Actions #2
Closing as fixed.
