Bug #300
open
WB
Error building coreboot for t440p
Bug #300: Error building coreboot for t440p
Added by wi be over 5 years ago. Updated about 5 years ago.
New
03/17/2021
GenFv: ERROR 3000: Invalid
the required fv image size 0x51e400 exceeds the set fv image size 0x3e0000
full error log:
https://termbin.com/t134
defconfig:
https://termbin.com/80qv
full config:
https://termbin.com/oovf
PM Updated by Paul Menzel over 5 years ago Actions #1
This is a TianoCore issue. Please try a different payload as a workaround.
WB Updated by wi be over 5 years ago Actions #2
i have tried now selecting the tianocore edk2 build from coreboot.
which resulted in UefiPayloadPkgIa32x64.dsc not to be found in
./payloads/external/tianocore/tianocore/UefiPayloadPkg/.*
as soon as i reverted my configuration back to the original as stated above
the build worked.~~
it was a custom bootsplash img that exceeded the size limits
PM Updated by Paul Menzel over 5 years ago Actions #3
How big is /tmp/build/t440p/splash/bootsplash.bmp?
WB Updated by wi be over 5 years ago Actions #4
i am not sure, as i deleted it.
I managed to create a buildable splash image, as described in this
tutorial: https://www.garyhawkins.me.uk/custom-logo-on-uefi-boot-screen/
JW Updated by Jamal Wright over 5 years ago Actions #5
You can make more space using ME cleaner. I left the FD unlocked and was able to flash an image that spans both chips. Maybe adding a bootsplash is what grew tianocore? My file was only 24kb.
The vendor bios will ignore the changed ME chip.
DK Updated by Daniel Kulesz about 5 years ago Actions #6
Did you try increasing the CBFS size? The default is pretty small and doesn't even fit GRUB.
I recommend trying to increase it to 0x2A0000 or 0x7A0000 and trying again.
