Feature #294
open
PG
Feature #290: Use clang-format for the entire tree
clang-format doesn't support wrapping single-statement conditional blocks in braces
Feature #294: clang-format doesn't support wrapping single-statement conditional blocks in braces
Added by Patrick Georgi over 5 years ago. Updated over 5 years ago.
New
02/18/2021
We want to normalize our code towards using braces for code blocks even where they're not strictly necessary in the standard (e.g. if (a) b; -> if (a) { b }, with proper newlines). clang-format doesn't support changing anything about this style at this time.
PM Updated by Paul Menzel over 5 years ago Actions #1
Also, in the case of https://review.coreboot.org/c/coreboot/+/50853/comment/8602e07a_f58119a3/, the braces are required by the coding style, as the other branches have braces.
