Bug #268
open
PM
Building Chrome EC within coreboot requires libftdi for no good reason
Bug #268: Building Chrome EC within coreboot requires libftdi for no good reason
Added by Paul Menzel over 6 years ago. Updated over 6 years ago.
New
07/06/2020
$ uname -m
ppc64le
$ make crossgcc CPUS=100
Welcome to the coreboot cross toolchain builder v157851fdbb (2020-05-29)
$ make what-jenkins-does
GOOGLE_SAMUS build FAILED after 73s!
Log excerpt:
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:66: undefined reference to `ftdi_get_error_string'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:71: undefined reference to `ftdi_set_baudrate'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:79: undefined reference to `ftdi_setdtr'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:119: undefined reference to `ftdi_write_data'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:128: undefined reference to `ftdi_read_data'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:156: undefined reference to `ftdi_usb_close'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:157: undefined reference to `ftdi_deinit'
/usr/bin/ld: /dev/shm/coreboot/3rdparty/chromeec/util/ec_uartd.c:73: undefined reference to `ftdi_get_error_string'
collect2: error: ld returned 1 exit status
PG Updated by Patrick Georgi over 6 years ago Actions #1
  • Subject changed from chromeec fails to build with undefined references to `ftdi_*` to Building Chrome EC within coreboot requires libftdi for no good reason
I don't think the issue is architecture specific: these are libftdi symbols and that only depends on libusb which should be architecture independent as well.
The actionable task for this may be to not build EC utilities that aren't necessary for just building EC.
PM Updated by Paul Menzel over 6 years ago Actions #2
In Ubuntu 20.04
libftdi-dev/focal,now 0.20-4build8 ppc64el [installed]
wasn’t enough. After installing libftdi1-dev the build succeeded.
