Bug #26
closed
WZ
cbfstool do not add compression attribute to ramstage
Bug #26:
Rejected
01/27/2016
Even if the ramstage is compressed and cbfstool add-stage is called with -c LZMA,
no compression attribute will be added to fallback/ramstage
in the resulting image.
PG Updated by Patrick Georgi almost 11 years ago
- Status changed from New to Rejected
Stages are compressed internally: It's an uncompressed SELF header and each section is then compressed (and provides the necessary metadata to detect this). The compression attribute is for full-file compression. This is working as intended (but maybe could be documented better)
