Bug #246
closed
AB
Remove Jasperlake Preprod device IDs when Jasperlake Production SKU is available
Bug #246: Remove Jasperlake Preprod device IDs when Jasperlake Production SKU is available
Added by Aamir Bohra almost 7 years ago. Updated over 4 years ago.
Closed
chipset configuration
12/10/2019
Initial Jasperlake develeopement code is adding Jasperlake Pre-Production SKU device IDs.
Once the production SOC SKU is available these IDs would become obsolete and needs to cleaned up.
This Bug is intended to track the clean up once the Production SKU is available and Pre-Prod SKU phases out.
https://review.coreboot.org/c/coreboot/+/37434
FS Updated by Felix Singer over 4 years ago Actions #1
