Feature #20
open
TP MR
Add make target to check if toolchain is up to date
Feature #20: Add make target to check if toolchain is up to date
Added by Timothy Pearson almost 11 years ago. Updated almost 4 years ago.
In Progress
build system
12/30/2015
Various automated build/test services use a specific toolchain build for all tests, and have no way to know if the toolchain has been updated and requires a rebuild. This, in turn, means manual intervention is needed for these services every time the toolchain version changes. (unless various hacks involving searching the output text are used, but these are highly suboptimal).
A new make target to check if the built toolchain is completely up to date with the current coreboot versions would be very useful.
MR Updated by Martin Roth almost 11 years ago Actions #1
This patch is the start:
It checks gcc, clang, buildtools, and iasl.
MR Updated by Martin Roth almost 4 years ago Actions #2
  • Affected versions 4.18 added
This was completed, but seems like it may now be broken again.
The command 'make test-toolchain' should tell you if the toolchain version you are using is current, but currently reports that the toolchain is up-to-date even when that's not the case.
