Bug #169
closed
HA
`cbfstool coreboot.rom compact` moves bootblock
Bug #169: `cbfstool coreboot.rom compact` moves bootblock
Added by henry autistici about 8 years ago. Updated over 7 years ago.
Rejected
07/17/2018
The bootblock part of a coreboot rom file should always remain at the end of the flash chip. However, running cbfstool coreboot.rom compact on the rom file relocates the bootblock so that it is followed by the free space.
Expected/suggested behaviour: Keep the bootblock at the end of the flash and relocate all free space right before it.
AH Updated by Arthur Heymans about 8 years ago Actions #1
Some cbfsfiles need to be at a fixed offset, others need a certain alignment. compact could have some specific use cases but should generally not be used the main COREBOOT fmap region.
PG Updated by Patrick Georgi over 7 years ago Actions #2
  • Status changed from New to Rejected
Yes, there's little we can do about it unless we start adding alignment/positioning data to CBFS metadata so compact can do a real cleanup.
