Bug #150
closed
PM
payloads/external/SeaBIOS/seabios/.config:3:warning: symbol value '' invalid for DEBUG_SERIAL_MEM_ADDRESS
Bug #150:
Resolved
build system
12/22/2017
I had a AMD Kahlee configuration lying around, updating coreboot tree, and rebuild it, but couldn’t do to an error with the SeaBIOS configuration.
Switched to a new branch 'coreboot'
CONFIG SeaBIOS 63451fca13c75870e1703eb3e20584d91179aebc
/mnt/coreboot2/payloads/external/SeaBIOS/seabios/.config:3:warning: symbol value '' invalid for DEBUG_SERIAL_MEM_ADDRESS
# configuration written to /mnt/coreboot2/payloads/external/SeaBIOS/seabios/.config
MAKE SeaBIOS 63451fca13c75870e1703eb3e20584d91179aebc
Build Kconfig config file
/mnt/coreboot2/payloads/external/SeaBIOS/seabios/.config:93:warning: symbol value '' invalid for DEBUG_SERIAL_MEM_ADDRESS
* Restart config...
* Debugging
Debug level (DEBUG_LEVEL) [1] 1
Serial port debugging (DEBUG_SERIAL) [N/y/?] n
Serial port debugging via memory mapped IO (DEBUG_SERIAL_MMIO) [Y/n/?] y
Serial port memory mapped IO address (DEBUG_SERIAL_MEM_ADDRESS) [] (NEW)
Serial port memory mapped IO address (DEBUG_SERIAL_MEM_ADDRESS) [] (NEW) ^C/mnt/coreboot2/payloads/external/SeaBIOS/seabios/scripts/kconfig/Makefile:36: recipe for target 'silentoldconfig' failed
I disabled building the SeaBIOS payload for now.
AH Updated by Arthur Heymans over 8 years ago
https://review.coreboot.org/#/c/coreboot/+/23065/ should fix it
MR Updated by Martin Roth almost 8 years ago
- Assignee deleted (
Martin Roth)
