Bug #131
closed
PM SR
Renaming `__attribute__((packed))` to `__packed` broke coreinfo build
Bug #131: Renaming `__attribute__((packed))` to `__packed` broke coreinfo build
Added by Paul Menzel over 9 years ago. Updated over 9 years ago.
Closed
07/17/2017
Commit 6a00113d (Rename attribute((packed)) --> __packed) [1] broke building the payload coreinfo.
[1] https://review.coreboot.org/15921
PM Updated by Paul Menzel over 9 years ago Actions #1
  • Subject changed from Renaming *__attribute__((packed))` to `__packed` broke coreinfo build to Renaming `__attribute__((packed))` to `__packed` broke coreinfo build
SR Updated by Stefan Reinauer over 9 years ago Actions #2
Do you have an error message I can look at? I just tried to reproduce the issue, and compiling coreinfo worked fine here.
PM Updated by Paul Menzel over 9 years ago Actions #3
The error I pasted in # is below.
/src/coreboot/payloads/coreinfo/cbfs_module.c:56:3: error: conflicting types for '__packed'
But I am unable to reproduce in a new environment building coreinfo as secondary payload either. Maybe libpayload needs to be rebuild or so?
SR Updated by Stefan Reinauer over 9 years ago Actions #4
Ah, yes. That is definitely the case. You will have to rebuild (or rather re-install) libpayload, or you will get the old include files from libpayload before the change.
PM Updated by Paul Menzel over 9 years ago Actions #5
  • Status changed from Resolved to Closed
Rebuilding libpayload fixed this indeed. Thank you.
