Feature #108
open
LR
AC
thinkpad x1 carbon gen 1 remaining tasks
Feature #108:
Response Needed
board support
04/25/2017
50%
SPD based on inteltool for elpidamissing samsung memory (missing a model or find spd data in uefi)missing hynix memory (missing a model or find spd data in uefi)- test msata port if soldered (missing msata disk)
use pins to differ 4gb and 8gb (prepare, but missing a model to verify)- check why device consumes more power (+ 3W while idle)
- do another test run how much is the difference, see if
powertop --auto-tuneworks - check if thermal/power/freq MSR are different
- check if it's display backlight
- check how big is the consumption when turning display off
- enable pci/sata link power save
LR Updated by lx r over 9 years ago
- Assignee changed from lx r to Alexander Couzens
LR Updated by lx r about 8 years ago
- Description updated (diff)
Use pins to differ 4gb and 8gb (prepare, but missing a model to verify)
So far the pins are not needed to define if 4gb or 8gb is required.
AC Updated by Alexander Couzens about 8 years ago
- % Done changed from 0 to 50
LR Updated by lx r over 4 years ago
I don't have this laptop anymore.
LR Updated by lx r over 3 years ago
- Status changed from In Progress to Response Needed
