Bug #89
closed
APU2 hang on boot with USB drive
Added by Rex Ching over 8 years ago. Updated about 8 years ago.
Rejected
01/20/2017
If I plug in a WD Element USB 3.0 external drive to the external port of APU2 PC Engine device, the device cannot boot and giving me no console log at all , the issue is not recoverable unless I do a power cycle and unplug the drive
Wonder if you are aware of this issue?
Actions #1
Updated by Nico Huber over 8 years ago
Please be more specific.
It's hard to guess, if you are facing a hardware / a coreboot / or a payload problem.
Which kind of console log do you mean, coreboot console (over serial?)? Or graphical output?
If you don't get any output over serial, it might be a hardware problem. In that case, check if your external drive requires an additional power supply. It's not uncommon that they try to draw more power than allowed over the USB port.
Actions #2
Updated by Nico Huber about 8 years ago
  • Status changed from New to Rejected
No response within months...
Also available in: Atom PDF
