Bug #8
closed
AC PD
FAQ in the wiki doesn't work
Bug #8: FAQ in the wiki doesn't work
Added by Alexander Couzens almost 11 years ago. Updated almost 11 years ago.
Closed
infrastructure
11/22/2015
https://www.coreboot.org/FAQ
will download the FAQ instead of showing it.
someone in the irc meant it's because of
Content-Type: application/octet-stream
AC Updated by Alexander Couzens almost 11 years ago Actions #1
  • Description updated (diff)
AC Updated by Alexander Couzens almost 11 years ago Actions #2
  • Assignee set to Philipp Deppenwiese
PD Updated by Philipp Deppenwiese almost 11 years ago Actions #3
HTTP root files are prioritised. A "FAQ" file could be found inside the http root. Maybe the file is written by a mediawiki update.
