Bug #638
open
AH
ACPI\LEN0068 (ThinkPad Extra Buttons) not detected by Windows 11 on ThinkPad T430
Bug #638: ACPI\LEN0068 (ThinkPad Extra Buttons) not detected by Windows 11 on ThinkPad T430
Added by Avraham Hollander 6 months ago. Updated 6 months ago.
New
board support
04/14/2026
ThinkPad T430
Windows 11
The device ACPI\LEN0068 (exposed as ThinkPad Extra Buttons on Linux via the thinkpad_acpi driver) is not detected at all by Windows 11. When installing the Lenovo Hotkey Features Integration driver, fn.inf shows up in Device Manager, but not bound to any device. As a result, the Fn special keys (mic mute, airplane mode, etc.) do not work under Windows 11 (25H2). On Linux, the thinkpad_acpi driver enumerates it just fine, and the buttons all work as expected.
I am using Coreboot 26.03-315-gec0d1946e7f3.
Files
config.txt (23.3 KB) config.txt Avraham Hollander, 04/14/2026 05:39 PM
t430-tables.tar.gz (35.2 KB) t430-tables.tar.gz ACPI tables Avraham Hollander, 04/19/2026 09:52 PM
AP Updated by Angel Pons 6 months ago Actions #1
Can you please post your coreboot config file?
AH Updated by Avraham Hollander 6 months ago Actions #2
Angel Pons wrote in #note-1:
I already did; it's attached as config.txt.
AP Updated by Angel Pons 6 months ago Actions #3
Avraham Hollander wrote in #note-2:
I completely missed that, apologies. I see that CONFIG_THINKPADEC_HKEY_EISAID="LEN0068" is set to the correct value so I wonder why Windows is not seeing the ACPI device. At this point I'd suggest checking the ACPI DSDT to make sure the device actually appears in there. It should: https://github.com/coreboot/coreboot/blob/5e0cf0e730cbe65b67533dc520de6618179a41f6/src/ec/lenovo/h8/acpi/thinkpad.asl#L11
AH Updated by Avraham Hollander 6 months ago Actions #4
Angel Pons wrote in #note-3:
It is indeed there:
Device (HKEY)
                        Name (_HID, EisaId ("LEN0068"))  // _HID: Hardware ID
                        Name (BTN, Zero)
                        Name (BTAB, Zero)
                        Name (DHKN, 0x080C)
                        Name (EMSK, Zero)
                        Name (ETAB, Zero)
                        Name (EN, Zero)
                        Method (_STA, 0, NotSerialized)  // _STA: Status
                            Return (0x0F)
I attached all of the ACPI tables, extracted with acpidump, if you want to look at them in more detail. I did
for i in *.dat
    do iasl -e *.dat -d $i
done
to ensure they were decompiled correctly, but I attached the binaries too just in case.
