Support #636
closed
AO AO
Building GCC v14.2.0 for target ... failed. Check 'build-i386-elf-GCC/build.log'.
Support #636: Building GCC v14.2.0 for target ... failed. Check 'build-i386-elf-GCC/build.log'.
Added by Ahmet Ozkesek 8 months ago. Updated 6 months ago.
Closed
Low
build system
03/22/2026
100%
Hi all,
Thank you for coreboot, first of all.
I am looking for building coreboot with u-boot payload.
I started from scratch as documented on my Fedora 44 beta system.
I hit the error below, -please scroll-down for it- and hoping that
someone already either fixed or done a workaround for this making
crossgcc-i386.
I somewhat did workaround for -V command-line argument error for
gnatgcc and g++, and got version info out there, but no lock for
this error: no matching function for call to 'S2C(const char8_t [2]) .
I attached config&build log from util/crossgcc/build-i386-elf-GCC.
Welcome to the coreboot cross toolchain builder v2026-01-30_235bb1e617
Building toolchain using 10 thread(s).
Target architecture is i386-elf
Found compatible Ada compiler, enabling Ada support by default.
Downloading and verifying tarballs ...
  • gmp-6.3.0.tar.xz (cached)... hash verified (b4043dd2964ab1a858109da85c44de224384f352)
  • mpfr-4.2.2.tar.xz (cached)... hash verified (a63a264b273a652e27518443640e69567da498ce)
  • mpc-1.3.1.tar.gz (cached)... hash verified (bac1c1fa79f5602df1e29e4684e103ad55714e02)
  • binutils-2.45.tar.xz (cached)... hash verified (09fd8a50a95be4a94412fe3847d16280996679c5)
  • gcc-14.2.0.tar.xz (cached)... hash verified (d91ecc3d20ce6298bd95f9b09cc51dc6d3c73ae3)
    Downloaded tarballs ... ok
    Unpacking and patching ...
  • gmp-6.3.0.tar.xz
    o gmp-6.3.0_fix-c23-prototypes.patch
    o gmp-6.3.0_generic-build.patch
  • mpfr-4.2.2.tar.xz
  • mpc-1.3.1.tar.gz
    o binutils-2.45_as-ipxe.patch
    o binutils-2.45_no-makeinfo.patch
  • gcc-14.2.0.tar.xz
    o gcc-14.2.0_asan_shadow_offset_callback.patch
    o gcc-14.2.0_gnat.patch
    o gcc-14.2.0_libcpp.patch
    o gcc-14.2.0_libgcc.patch
    o gcc-14.2.0_musl_poisoned_calloc.patch
    o gcc-14.2.0_rv32iafc.patch
    Unpacked and patched ... ok
    Building packages ...
    Building GMP v6.3.0 for host ... ok
    Building MPFR v4.2.2 for host ... ok
    Building MPC v1.3.1 for host ... ok
    Building BINUTILS v2.45 for target ... ok
    make[2]: *** [Makefile:20: build_gcc] Error 1
    make[1]: *** [Makefile:36: build-i386] Error 2
    make: *** [util/crossgcc/Makefile.mk:32: crossgcc-i386] Error 2
Files
config.log (39.2 KB) config.log Ahmet Ozkesek, 03/22/2026 10:35 AM
build.log (284 KB) build.log Ahmet Ozkesek, 03/22/2026 10:35 AM
AO Updated by Ahmet Ozkesek 8 months ago Actions #1
Update-1:
I managed to make clang instead of crossgcc-i386.
  • In case of a backup plan-b I got coreboot-sdk container. -
    Made nconfig, then only changed u-boot as payload other then
    defaults. Now I got error you can see below. I am digging
    from here now, if I missed some elf-tools.
Some help still much appreciated.
MAKE       U-Boot v2025.07
objcopy: lib/efi_loader/helloworld_efi.so: file format not recognized
make[5]: *** [scripts/Makefile.lib:494: lib/efi_loader/helloworld.efi] Error 1
make[4]: *** [/home/aozkesek/fw/coreboot/payloads/external/U-Boot/u-boot/scripts/Makefile.build:398: lib/efi_loader] Error 2
make[3]: *** [/home/aozkesek/fw/coreboot/payloads/external/U-Boot/u-boot/Makefile:1919: lib] Error 2
make[2]: *** [Makefile:177: sub-make] Error 2
make[1]: *** [Makefile:49: build] Error 2
make: *** [payloads/external/Makefile.mk:341: payloads/external/U-Boot/build/u-boot.bin] Error 2
AO Updated by Ahmet Ozkesek 8 months ago ยท Edited Actions #2
Looks like backup plan-b, coreboot-sdk container, solves the pain-in-the-neck.
You may now ignore this, as I will go for full container.
Update : coreboot-sdk container is still lets me down, built my own container instead.
Hope this help out for someone.
Update-2 : finally I managed to compile coreboot with u-boot it's payload, then
saw it's booting with qemu. I deleted previous update, add this one instead.
Here are the steps I followed;
  1. this is the container I built first, named it as "cross-compile:d13" ;
--- copy starts here --------------
FROM debian:13
VOLUME /home/cross-compile
WORKDIR /home/cross-compile
RUN <<EOT
set -e
apt update
apt upgrade -y
apt install -y bison flex gettext git m4 make bzip2 curl bc wget patch python3
crossbuild-essential-armhf crossbuild-essential-arm64 device-tree-compiler
autoconf automake autopoint autoconf-archive pkg-config unifont golang
libelf-dev libssl-dev python3-dev libnss3-dev libncurses-dev zlib1g-dev
libfreetype-dev libcmocka-dev libgnutls28-dev u-boot-tools gnat
EOT
CMD /bin/bash
---copy ends here------
  1. created a container volume, named it cross-compile as well.
  2. ran the container, used the volume, so all the next steps things are permanent.
  3. inside the container, cloned the coreboot source, from it's repo, then,
    4.1. made the crossgcc-i386 first, -I used BUILD_LANGUAGES=c -
    4.2. followed the guideline, with one exemption, that was configured u-boot as payload
    4.3. made it, then got it coreboot.rom that can I used as bios for qemu.
So I will close this issue, as it is not an issue anymore.
AO Updated by Ahmet Ozkesek 7 months ago Actions #3
  • Status changed from New to Needs Testing
  • Assignee set to Ahmet Ozkesek
AO Updated by Ahmet Ozkesek 7 months ago Actions #4
  • Status changed from Needs Testing to Closed
RA Updated by Rahul Arasikere 6 months ago Actions #5
I managed to get it to build by patching util/crossgcc/buildgcc and adding -fno-char8_t to CXX_FOR_BUILD variables in the script.
This is due to how char vs char8_t is handled with GCC >= 16.
AP Updated by Angel Pons 6 months ago Actions #6
Rahul Arasikere wrote in #note-5:
Did you mean CXXFLAGS_FOR_BUILD?
