Bug #624
closed
RN AP
Memory speed in SMBIOS is incorrectly doubled on Haswell
Bug #624: Memory speed in SMBIOS is incorrectly doubled on Haswell
Added by Ron Nazarov 10 months ago. Updated 7 months ago.
Resolved
chipset configuration
01/21/2026
100%
1.00 h
Haswell
Tested on a Dell Precision T1700 SFF with NRI, my 1600 MT/s (800 MHz) RAM is reported by dmidecode -t 17 as running at 3200 MT/s.
This bug was introduced in https://review.coreboot.org/c/coreboot/+/89598/6. The frequency is doubled in dimm->ddr_frequency = ddr_freq_mhz * 2; /* In MT/s */, however (at least on NRI, I did not test MRC), ddr_freq_mhz (defined as (mchbar_read32(MC_BIOS_DATA) * 13333 * 2 + 50) / 100) is actually in MT/s, and so already doubled.
I also see this in coreboot logs: [DEBUG] memcfg DDR3 clock 1600 MHz. This debug print (added in https://review.coreboot.org/c/coreboot/+/89599/4) is printing DIV_ROUND_CLOSEST(mchbar_read32(MC_BIOS_DATA) * 13333 * 2, 100), which is pretty much the same as ddr_freq_mhz (except using DIV_ROUND_CLOSEST).
Related links
Change that introduced the regression: https://review.coreboot.org/89598
Change that fixes the regression: https://review.coreboot.org/91375
AP Updated by Angel Pons 9 months ago Actions #1
  • Related links updated (diff)
AP Updated by Angel Pons 9 months ago ยท Edited Actions #2
Looking back at that code, I should also check if forcing a 100 MHz ref clock results in the wrong speed being reported.
Also, "related links" having such a giant text box tricked me.
AP Updated by Angel Pons 9 months ago Actions #3
  • Category set to chipset configuration
  • Estimated time set to 1.00 h
Looking at https://review.coreboot.org/89598 again, it seems that the bug already existed in the Haswell MRC codepath. The Broadwell MRC codepath did not have this issue, and NRI was N/A since it did not set up memory info until https://review.coreboot.org/89600 landed (which used the code factored out in the change that introduced the regression).
Well, https://review.coreboot.org/91375 fixes this, and also fixes memory frequency reporting when using the 100 MHz reference clock (the code assumed a fixed 133 MHz reference clock). This is the same for all three raminit codepaths (Haswell MRC, Broadwell MRC, NRI), since the encoding of the MC_BIOS_REQ and MC_BIOS_DATA registers is the same.
Will close once the change gets submitted. If I don't forget, heh.
PR Updated by Patrick Rudolph 7 months ago Actions #4
  • Status changed from In Progress to Resolved
