Bug #620
closed
HO
X230(t) does not work since commit 97dbfd3098ae12ef3f51e5f95cd6d66c25214205 was merged
Bug #620: X230(t) does not work since commit 97dbfd3098ae12ef3f51e5f95cd6d66c25214205 was merged
Added by Hustler One 10 months ago. Updated about 1 month ago.
Rejected
High
coreboot common code
12/31/2025
x230t
Releases 25.09, 25.12 are affected. 25.06 works.
The commit 97dbfd3098ae12ef3f51e5f95cd6d66c25214205 prevents the x230t from going past the postcar stage, hence it being inoperable since it won't load into the main payload.
I have attempted to debug using flashconsole but the trail runs cold after postcar.
Credit to iam_tj for finding the commit.
Also, Libreboot is somehow unaffected by this. I don't know if lbmk undoes this commit or not at this time.
PR Updated by Patrick Rudolph 10 months ago Actions #1
The referenced commit seems to work fine on google/link (IVB) and lenovo/X220 (SNB).
Any ideas why there's a different behaviour?
Are microcode updates properly loaded?
Does it work with unstripped Intel ME?
TT Updated by Teej Tj 10 months ago Actions #2
Tj here (identified the problem commit). I've been working with hustlerone in #coreboot:matrix.org for a few days on this and other issues.
Rudolf: your comment in commit 97dbfd309 "TODO: Test on platforms that have FSRM (Ivy Bridge and newer)." cued me in as this possibly being the cause of the Lenovo X230 regression.
I'm currently writing a patch for hustlerone to figure out the cause that conditionally reverts parts of the commit. The most obvious changes are:
  1. MTRR
  2. splitting of cache fill/clear
  3. possibly the rep stosl using ERSM in Ivy Bridge influenced by the 64-byte stride for the modification loop
PR Updated by Patrick Rudolph 10 months ago Actions #3
The original X230 firmware uses the same assembly code as introduced by 97dbfd3098ae12ef3f51e5f95cd6d66c25214205.
It's possible that it uncovered a different issue, since it now boots much faster. With cleaned ME it also skips some
spots where it would usually slow down the boot.
Figuring out where it actually hangs might shed some light on the real problem.
OA Updated by Olli Asikainen 8 months ago Actions #4
FWIW I flashed 26.03 onto my x230 today and it works, using the same config I had for 25.06.
PR Updated by Patrick Rudolph about 1 month ago Actions #5
  • Status changed from New to Rejected
Closing since X230 and X220 are reported working, issue cannot be reproduced and wasn't further investigated by original author.
