Support #597
opensuccess mb/dell: OptiPlex 5040 SFF works with adjusted Optiplex 3050 Micro code port
Not sure to put this under support or refactoring, since adding this code to upstream coreboot using gerrit may look straight forward and easy to have a nice working optiplex_5040 port. My concern is however that the original dell/optiplex_3050 code might need to be refactored into a variant first before this code will be accepted and that refactoring may be to much for me as a newbie.
But it works... it works really well indeed.
By mostly reusing dell/optiplex_3050 port code which takes care of handling some variants 'SFF/MICRO' hinted by 'ramstage.c' for its own 3050 series itself, I just reused all of the code which I mostly don't understand and therefor may be wrong to put that as NEW board into the code tree. Although I have 'autoport logs' made for my 'optiplex_5040_sff' I don't know how to translate/apply correct that to my model(if needed). But since you have to start somewhere, and autoport only made logs I therefor just want to share this code and progress.
Specs: Dell Optiplex 5040 SFF
Motherboard: DP/N 0T7D40, CN-0T7D40-72200, 588-00HF-A00
OEM BIOS version: 1.22.0 03/16/2022
Reg Model: D11S
Reg Type: D11S001
Service tag: HPR6C92
CPU: i3-6100
This Optiplex 5040 SFF motherboard looks very similar to the 3050 SFF(shares the same OEM BIOS as the 3050 micro) except for the following visual differences:
4 DDR3L slots vs 2 DDR4 slots (DDR4-sodimm on the micro)
1 PCIe 4x length (open) black slot vs 1x length (closed), micro none
3 SATA connectors vs 2 SATA (black missing), micro one
4 USB3 back ports vs 2 USB3
2 DisplayPorts vs 1 DisplayPort
1 serial vs 0 serial port
1 VGA(using motherboard header) vs 0 VGA
2 PS2 vs 0 PS2 ports
Q170 chipset vs B250 chipset
First the initial deguard requirement was the same for my optiplex_5040 sff as for the optiplex_3050 micro, as well as flashing or recovery. A minor edit to the deguard code is necessary to complete the deguard instruction.
With the following crucial edits to the 'optiplex_3050' port its 'Kconfig', 'romstage.c' and minor edits to the existing 'devicetree.cb' almost everything started working:
First hang on RAM issue "[EMERG] FspMemoryInit error, status=0x80000007" was fixed by adjusting 'Kconfig' config DIMM_SPD_SIZE from default 512 # DDR4 to 256 # DDR3 and editing 'romstage.c' with additional addresses and changing CaVrefConfig 2 to 0 made all 4 DIMM slots work:
> struct spd_block blk = { .addr_map = { 0x50, 0x51, 0x52, 0x53 } };
mem_cfg->DqPinsInterleaved = 1;
> mem_cfg->CaVrefConfig = 0;
mem_cfg->MemorySpdDataLen = blk.len;
> mem_cfg->MemorySpdPtr00 = (uintptr_t)blk.spd_array[0];
> mem_cfg->MemorySpdPtr10 = (uintptr_t)blk.spd_array[2];
> mem_cfg->MemorySpdPtr01 = (uintptr_t)blk.spd_array[1];
> mem_cfg->MemorySpdPtr11 = (uintptr_t)blk.spd_array[3];
By some additional edits to 'devicetree.cb' all PCIe slots(16x,4x,M2-ssd), all USB2&3 ports, all SATA ports and both PS2 ports started to function. Only the USB OC values have my concern, don't know what they stand for.
> # SLOT2 x16
> device ref peg0 on
> register "Peg0MaxLinkWidth" = "Peg0_x16"
> # Configure PCIe clockgen in PCH
> register "PcieRpClkReqSupport[0]" = "1"
> register "PcieRpClkReqNumber[0]" = "0"
> register "PcieRpClkSrcNumber[0]" = "0"
> end
> device ref south_xhci on
> register "usb2_ports" = "{
> [0] = USB2_PORT_MID(OC0), // Front panel (blue)
> [1] = USB2_PORT_MID(OC0), // Front panel (blue)
> [2] = USB2_PORT_MID(OC3), // Back panel (blue)
> [3] = USB2_PORT_MID(OC2), // Back panel (blue)
> [4] = USB2_PORT_MID(OC1), // Back panel (blue)
> [5] = USB2_PORT_MID(OC1), // Back panel rightup (black)
> [6] = USB2_PORT_MID(OC1), // Back panel (blue)
> [7] = USB2_PORT_MID(OC1), // Back panel rightlow (black)
> [8] = USB2_PORT_MID(OC_SKIP), // Front Panel rightlow (black)
> [9] = USB2_PORT_MID(OC_SKIP), // Front Panel rightup (black)
> register "usb3_ports" = "{
> [0] = USB3_PORT_DEFAULT(OC0), // Front panel (blue)
> [1] = USB3_PORT_DEFAULT(OC0), // Front panel (blue)
> [2] = USB3_PORT_DEFAULT(OC2), // Back panel (blue)
> [3] = USB3_PORT_DEFAULT(OC2), // Back panel (blue)
> [4] = USB3_PORT_DEFAULT(OC1), // Back panel (blue)
> [5] = USB3_PORT_DEFAULT(OC1), // Back panel (blue)
> end
> register "SataPortsEnable[1]" = "1"
> register "SataPortsEnable[2]" = "1"
< device ref pcie_rp21 on
< register "PcieRpClkReqSupport[20]" = "1"
< register "PcieRpClkReqNumber[20]" = "3"
< register "PcieRpAdvancedErrorReporting[20]" = "1"
< register "PcieRpLtrEnable[20]" = "true"
< register "PcieRpClkSrcNumber[20]" = "3"
< register "PcieRpHotPlug[20]" = "1"
< end
< # Realtek LAN
< device ref pcie_rp5 on
< register "PcieRpClkReqSupport[4]" = "0"
< register "PcieRpHotPlug[4]" = "0"
< end
< # M.2 WiFi
< device ref pcie_rp8 on
< register "PcieRpClkReqSupport[7]" = "0"
< register "PcieRpHotPlug[7]" = "1"
> # SLOT3_M.2
> device ref pcie_rp17 on
> register "PcieRpClkReqSupport[16]" = "1"
> register "PcieRpClkReqNumber[16]" = "3"
> register "PcieRpAdvancedErrorReporting[16]" = "1"
> register "PcieRpLtrEnable[16]" = "true"
> register "PcieRpClkSrcNumber[16]" = "3"
> register "PcieRpHotPlug[16]" = "1"
> end
> # SLOT1 x4
> device ref pcie_rp9 on
> register "PcieRpClkReqSupport[8]" = "0"
> register "PcieRpHotPlug[8]" = "1"
> end
> device pnp 2e.1 on # 8042
> io 0x60 = 0x60
> irq 0x0f = 0
> irq 0x70 = 1
> irq 0x72 = 12
> end
> chip drivers/pc80/tpm
> device pnp 0c31.0 on end
> end
> device ref gbe on end
Also TPM2 and onboard ethernet came alive with final edits to 'Kconfig':
> select MAINBOARD_HAS_TPM2
> select MEMORY_MAPPED_TPM
> select MAINBOARD_USES_IFD_GBE_REGION
All audio ports including chassis speaker(soundcard) work using unchanged optiplex_3050 code, however autoport logs ran on OEM show different codec(chipset) and parameters for the 5040_sff compared to 3050 micro this may need to be alterned for correctness?
Video output was unreliable until I replaced 'data.vbt' with the one extracted from original Dell Optiplex 5040 SFF 1.22 OEM bios (debugfs) and altered 'gma-mainboard.ads' to have HDMI and 2 DisplayPorts working perfectly. Only the VGA port, which is shown as 3rd DisplayPort (xrandr) uses the original motherboard breakout to the chassis VGA won't work at all (port not detected no BOOT nor OS).
ports : constant Port_List :=
(HDMI1, -- External HDMI
DP2, -- External DP (bottom)
DP1, -- External DP (top)
DP3, -- External VGA (opt. breakout cable)
others => Disabled);
Tested this on coreboot-25.03-519-ga2010cf5eeea both SeaBIOS 1.16.3 and EDK2 MrChromeBox 2502 payloads booting KDE NEON Linux 6.11 fine.
Besides the "VGA port" only "Wake for LAN" isn't working for me yet every other port/connection/slot does work even combined iGPU and dGPU, leds, and CPU Fan speed also varies boot/restart. My concern is with the USB OC values, allot of GPIO values copied from the 3050 port and not correct to autoport and other stuff I might overlook.
Feel free to check the added drop in optiplex_5040_sff.zip file with mostly a copy of 3050 micro port code to build a functional optiplex_5040_sff target or spin a variant into gerrit which I can assist and confirm testing.
Files
WS Updated by Walter Sonius over 1 year ago
WS Updated by Walter Sonius over 1 year ago · Edited
The irony... its VGA port works in Windows 11 (offline install) after installing the official Intel g7-g10 driver version 31.0.101.2.135 on a Intel G4900T Coffeelake CPU. Also tried Fedora42 kernel 6.14 besides KDE NEON 6.11 and EDK2 neither outputs nor detect VGA. Didn't know libgfxinit was compatible with Windows its drivers?
The DP/VGA breakout cable is labeled DP/N 06XHN0 77161-645-M1C1-A00, and its board MGE-873 RFV:2.2 also contains a realtek chip RTD2168 F7C24P2 GF48E which is the same as dell optiplex 3050 vga-board part number 0PKGGG.
Also TPM2 and secureboot activates a bitlocker protected Windows 11 install.
Onboard speaker(outputs left channel only also in linux) and backpanel audio plug also works out of the box in Windows 11 but front panel jack isn't detected nor doesn't output audio(works in linux).
edit: 2025-05-24
Sleep/Wake also works on Windows 11
PS2 ports both Keyboard nor Mouse are not detected nor working in Windows 11.
WakeOnLan only works for separate PCIe intel NIC in SLOT1 x4 port, SLOT2 x16 doesn't nor the onboard NIC still won't wake the system.
Following additional edits to 'devicetree.cb' will make both ports on internal USB2.0 header near PSU and the SATA port inside SLOT3_M.2 slot working:
> [11] = USB2_PORT_MID(OC_SKIP), // int USB2 header
> [12] = USB2_PORT_MID(OC_SKIP), // int USB2 header
> register "SataPortsEnable[4]" = "1"
The internal USB3 header for the front panel "Dell TT15C Card Reader" won't show any connected USB3 nor USB2 devices neither in with OEM 1.22 BIOS while its enabled as a BIOS option. Since I don't have the TT15C card reader to test I used a default USB3 breakout cable...
To also get Displayport++ to HDMI displays working in Coreboot/Linux I had to add/restore the following HDMI interfaces to 'gma-mainboard.ads', DP3 to VGA still doesn't work:
> HDMI3, -- DP++ to HDMI-A-3
> HDMI2, -- DP++ to HDMI-A-2
Also these 'gma-mainboard.ads' edits won't affect the Windows 11 outputs in anyway. Only enabling a single HDMI1 output will still let Windows 11 output (after loading the intel gma driver) to all other DP and VGA ports. It even works on the i3-6100 with older gen graphics in Windows 11.
Although the Dell 3050 micro port shows the same chipset ALC3234 comment in the 'hda_verb.c' it used a different Subsystem ID 0x102807a3, after booting coreboot it was detected as a ALC255. However changing it to the Dell OptiPlex 5040 its native Subsystem ID 0x102806ba still let the card identify as ALC255 after coreboot port and still all audio outputs speaker and front&back still work. Not sure how to modifiy the pinHW from the 5040 to the 3050 'hda_verb.c' so I kept it the same.
Still trying to find a way how to differentiate the DMI System Information "Product Name" vs Base Board Information "Product Name" as in "OptiPlex 5040" vs "0T7D40". Memtest 7.20 shows the Base Board Product Name on the original OEM BIOS 1.22, but a coreboot install shows OptiPlex 5040 or SFF as in my code.
edit: 2025-07-05
PS2 ports both Keyboard and Mouse work in Windows 10&11 after adding the following line #include <drivers/pc80/pc/ps2_controller.asl> to acpi/superio.asl. This was hinted from a dating Lenovo X201 which did work with its onboard PS2 keyboard/trackpad in Windows 10/11, the EISA references weren't needed.
Possible hint to make analogue VGA output over de DP3 connected onboard RTD2168 converter work related to bifurcation and DDI-E.
Interesting link for Lenovo M900/M700 similar skylake platforms, which were able to get coffeelake cpu's working.
As hinted by Angel Pons his HP 280 G2 patch I verified that the VGA port connected to DP3 using RTD2168 converter on this Dell Optiplex 5040 SFF can output in Linux by only adding the following line to Kconfig:
select SOC_INTEL_GFX_ENABLE_DDI_E_BIFURCATION
Update:
All video ports work now except VGA on boot, must have been wrong gma-mainboard.ads or picking a lose HDMI/DP cable for testing but the bifurcation setting is correct!
Without setting this bifurcation, dmesg i915 module spits errors about not having correct lanes so the tip was there all the time. Funny note even for cases the board doesn't have a VGA interface for instance Asrock H110 Pro BTC+ also shows this i915 lane error in dmesg but is also fixed when adding the bifurcation option.
Upstream Review:
Both the "create variant for optiplex 3050" and "optiplix 5040 sff variant" code has been posted.
