Bug #591
closed
O4
Build error on lenovo/m920q due to removal of ##ROM_BASE##
Bug #591: Build error on lenovo/m920q due to removal of ##ROM_BASE##
Added by Oberon 4071 over 1 year ago. Updated over 1 year ago.
Resolved
userspace utilities
04/11/2025
lenovo/m920q
The current coreboot sources (25.03-161-gf6d40a9564) will not build when specifying lenovo/m920q as the mainboard, regardless of which payload is used. The following error occurs during build:
   IFDTOOL
    IFDTOOL    -p cnl -F build/fmap-template.fmd 3rdparty/blobs/mainboard/lenovo/m920q/descriptor.bin
File 3rdparty/blobs/mainboard/lenovo/m920q/descriptor.bin is 4096 bytes
Wrote layout to build/fmap-template.fmd
    HOSTCC     cbfstool/fmaptool.o
    HOSTCC     cbfstool/cbfs_sections.o
    HOSTCC     cbfstool/fmap_from_fmd.o
    HOSTCC     cbfstool/fmd.o
    HOSTCC     cbfstool/fmd_parser.o
    HOSTCC     cbfstool/fmd_scanner.o
    HOSTCC     cbfstool/fmap.o
    HOSTCC     cbfstool/kv_pair.o
    HOSTCC     cbfstool/valstr.o
    HOSTCC     cbfstool/fmaptool (link)
    FMAP       build/util/cbfstool/fmaptool -h build/fmap_config.h build/fmap.fmd build/fmap.fmap
syntax error
FATAL: Failed while processing provided descriptor
make: *** [Makefile.mk:1263: build/fmap.fmap] Error 4
It appears that this error is the result of the commit a7eb390796ef4ba7baaffca741664b816de12256 (mb///*.fmd: Start flash at 0). This commit appears to remove all references to the token ##ROM_BASE##, but ifdtool has not been updated to reflect this change.
The following patch appears to fix the issue on my end and allow coreboot to build for lenovo/m920q:
diff --git a/util/ifdtool/ifdtool.c b/util/ifdtool/ifdtool.c
index 94105efe52..b21a89c0e1 100644
--- a/util/ifdtool/ifdtool.c
+++ b/util/ifdtool/ifdtool.c
@@ -1094,7 +1094,7 @@ static void create_fmap_template(char *image, int size, const char *layout_fname
                exit(EXIT_FAILURE);
-       char *bbuf = "FLASH@##ROM_BASE## ##ROM_SIZE## {\n";
+       char *bbuf = "FLASH ##ROM_SIZE## {\n";
        if (write(layout_fd, bbuf, strlen(bbuf)) < 0) {
                perror("Could not write to file");
                exit(EXIT_FAILURE);
In case it is needed, I have attached my .config settings.
Files
config_lenovo_m920q_20250411.txt (26.6 KB) config_lenovo_m920q_20250411.txt Oberon 4071, 04/11/2025 08:20 PM
MB Updated by Maximilian Brune over 1 year ago Actions #1
Thanks for adding a ticket.
You are right. I pushed a patch to: https://review.coreboot.org/c/coreboot/+/87288
O4 Updated by Oberon 4071 over 1 year ago Actions #2
Maximilian Brune wrote in #note-1:
Thank you for this change. After this change was merged, coreboot is now building successfully for lenovo/m920q on my end. This ticket can be closed.
MD Updated by Matt DeVillier over 1 year ago Actions #3
