Bug #549
open
coreboot 24.05: SeaBIOS Windows 10/11 BSOD "ACPI BIOS ERROR" (Thinkpad W530)
When using the latest coreboot (i.e. using command git clone https://review.coreboot.org/coreboot), which is currently 24.05, to build a rom for Thinkpad W530, I get BSOD with "ACPI BIOS ERROR" when trying to boot into Windows 10 or 11 from SeaBIOS. Even just booting from a Windows install usb will show this error.
This is even with incorporating the vga bios files (so i can external displays to work) - see my defconfig.
Did consider using EDK2 apparently Windows support is pretty solid, but could never make a successful build - not that make command had errors, but once flashing, would just having white underscore and have to recover with external flashing. A separate issue to write about in and of itself, but I prefer SeaBIOS so I'll be sticking with that.
I am quite new to coreboot - using for only about 2-3 months now. Let me know if there is further information I should provide.
Files
MD Updated by Matt DeVillier over 2 years ago
git clone https://review.coreboot.org/coreboot), which is currently 24.05, to build a rom for Thinkpad W530, I get BSOD with "ACPI BIOS ERROR" when trying to boot into Windows 10 or 11 from SeaBIOS. Even just booting from a Windows install usb will show this error.This is even with incorporating the vga bios files (so i can external displays to work) - see my defconfig.
makecommand had errors, but once flashing, would just having white underscore and have to recover with external flashing. A separate issue to write about in and of itself, but I prefer SeaBIOS so I'll be sticking with that.I am quite new to coreboot - using for only about 2-3 months now. Let me know if there is further information I should provide.
quite simply, coreboot's ACPI for your device booted in legacy BIOS mode isn't Windows compliant. Boot linux, install acpica-tools, run sudo acpidump -b then sudo iasl -d *.dat and zip/attach the resulting .dsl files here.
IMO edk2 is the better choice for running Win10/11, and is known to work well. A flashing cursor sounds like you changed the display mode to text vs graphical, or didn't reset your config when changing payloads. edk2 + libgfxinit with defaults should boot Windows on your device.
Updated by Anonymous over 2 years ago
- File dsl_files.zip dsl_files.zip added
Matt DeVillier wrote in #note-1:
You're talking about Devices --> Graphics initialization, right? That's probably it - I didn't touch that and by default is set to "Run VGA Option ROMS".
Btw, if I use the me_cleaner script to shrink the me, what should the size of cbfs be set to take up the free space?
MD Updated by Matt DeVillier over 2 years ago · Edited
Devices --> Graphics initialization, right? That's probably it - I didn't touch that and by default is set to "Run VGA Option ROMS".Btw, if I use the me_cleaner script to shrink the me, what should the size of cbfs be set to take up the free space?
edk2 requires a graphical framebuffer, either libgfxinit w/linear high-res framebuffer, or VGA BIOS with a VESA mode set. The latter is not recommended, nor the default when edk2 is selected as the payload from a clean config.
don't mess with ME cleaner until you have coreboot working properly, no need to add another variable to the mix. the CBFS size can be set plenty large enough for edk2 (2MB should suffice) without needed to shrink the ME region / enlarge the bios region.
here is a sane defconfig for W530 + edk2:
CONFIG_VENDOR_LENOVO=y
CONFIG_CBFS_SIZE=0x200000
CONFIG_BOARD_LENOVO_W530=y
CONFIG_PAYLOAD_EDK2=y
CONFIG_EDK2_BOOT_MANAGER_ESCAPE=y
CONFIG_EDK2_FOLLOW_BGRT_SPEC=y
# CONFIG_EDK2_FULL_SCREEN_SETUP is not set
obviously since no IFD/ME blobs are included, you would just flash the bios region (using --ifd -i bios)
What's your verdict on the .dsl files provided?
Simon Dominic wrote in #note-5:
nothing jumps out at me, but I also don't know what Windows in legacy boot vs Windows in UEFI boot wants differently -- just that they are
Simon Dominic wrote in #note-7:
Finally able to boot into edk2 - thanks a lot! Will test with Windows later.
The only problem is I can't boot into my existing (Debian) Linux drive encrypted with LUKS.
Pictures of the errors provided.
well, if it's legacy installed, you need to migrate to a UEFI-compatible bootloader. Plenty of guides on adding an EFI partition and installing the bootloader
· Edited
Matt DeVillier wrote in #note-4:
With that defconfig confirmed to be working, I tried adding a few other things, including vga bios (to get external displays working):
CONFIG_VGA_BIOS_DGPU_ID="10de,0ffc"
CONFIG_VGA_BIOS=y
CONFIG_IFD_BIN_PATH="descriptor.bin"
CONFIG_ME_BIN_PATH="me.bin"
CONFIG_GBE_BIN_PATH="gbe.bin"
CONFIG_VGA_BIOS_FILE="vgabios/8086,0166.rom"
CONFIG_HAVE_IFD_BIN=y
CONFIG_H8_FN_CTRL_SWAP=y
CONFIG_HAVE_ME_BIN=y
CONFIG_USE_ME_CLEANER=y
CONFIG_HAVE_GBE_BIN=y
CONFIG_MAINBOARD_USE_LIBGFXINIT=y
CONFIG_VGA_BIOS_DGPU=y
CONFIG_VGA_BIOS_DGPU_FILE="vgabios/10de,0ffc.rom"
However, CBFS at 2MB (0x200000) is too small to have VGA BIOS. Thus, I get this error:
Image SIZE 12582912
CBFS cpu_microcode_blob.bin
CBFS fallback/ramstage
CBFS config
CBFS revision
CBFS build_info
CBFS fallback/dsdt.aml
CBFS vbt.bin
CBFS cmos_layout.bin
CBFS pci8086,0166.rom
CBFS pci10de,0ffc.rom
CBFS fallback/postcar
CBFS fallback/payload
E: Could not add [build/UEFIPAYLOAD.fd, 1308190 bytes (1277 KB)@0x0]; too big?
E: Failed to add 'build/UEFIPAYLOAD.fd' into ROM image.
E: Failed while operating on 'COREBOOT' region!
E: The image will be left unmodified.
make: *** [Makefile.mk:1214: build/coreboot.pre] Error 1
Changing it to 3MB (0x300000) creates a successful build. I assume CBFS at 3MB is acceptable/sane?
Btw, where do I find CONFIG_EDK2_FOLLOW_BGRT_SPEC=y in menuconfig?
I reinstalled Debian but I still get the same message (boot.jpg). However, I have to manually boot from file EFI/debian/grubx64.efi. How can this be fixed to boot from there automatically?
Also, when I use nvramtool to change hybrid_graphics_mode to "Discrete Only", I get black screen. But displays shows for "Integrated Only" and "Dual Graphics".
Simon Dominic wrote in #note-10:
Normally, the bootloader would add the boot entry to the bootorder list. Do you have SMMSTORE enabled? That's needed for UEFI NVRAM to work. If so, you can add a bootorder entry manually for that target
I have no experience with dGPUs or hybrid graphics unfortunately
- File ventoy-win11.jpg ventoy-win11.jpg added
When I try to boot Windows iso from ventoy usb, I get an error: "The Boot Configuration Data for your PC is missing or contains errors."
Simon Dominic wrote in #note-12:
no experience doing it that way, only via an ISO written to USB using MS' tool or Rufus.
- File rufus-win11.png rufus-win11.png added
Matt DeVillier wrote in #note-13:
Tried doing it with Rufus (keeping "Partition scheme" as GPT), but I get this.
Simon Dominic wrote in #note-14:
Rufus is breaking things by trying to unload the existing NTFS EFI driver and load its own. Version 4.5 added this new feature, anything earlier should work properly.
edit: the bug is in the UEFI-NTFS driver that Rufus is using, it's been fixed in the latest one but Rufus has yet to update.
- File vga_rom_display_1.png vga_rom_display_1.png added
- File vga_rom_display_2.png vga_rom_display_2.png added
- File vga_rom_display_3.png vga_rom_display_3.png added
- File vga_rom_display_4.png vga_rom_display_4.png added
I could be completely wrong, but I gather libgfxinit (as opposed to "VGA Option ROMS") is disabling (full) activation of the dGPU. If I wanted to go that latter not-recommended route, how should display mode be set up?
Attached is what menuconfig shows if I look through some of the settings for "Display" (if I choose "VGA Option ROMS" as "Graphics initialization"):
- Screenshot 1 is what "Display" looks like without touching anything (Here, "Framebuffer mode" can only be set to "Legacy VGA text mode").
- 2 is ticking "Set framebuffer graphics resolution" and touching nothing else.
- 3 shows the options for "Framebuffer mode" after doing 2.
- 4 shows what it looks like after setting "Framebuffer mode" to "VESA framebuffer".
Simon Dominic wrote in #note-16:
Any thoughts?
