Bug #537
closed
KF
build failed with successfully built edk2 payload?!?
Bug #537:
05/08/2024
Hi,
I get the following error when trying to build coreboot together with the edk2 payload. It looks like it is compiling the wrong version of edk2 and thereby missing payloads/external/edk2/workspace/Build/UefiPayloadPkgX64/UniversalPayload.elf even though edk2 itself built successfully.
Ran 303 tests in 2.593s
OK
make[3]: Leaving directory '/home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/BaseTools/Tests'
make[2]: Leaving directory '/home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/BaseTools'
##### edk2 Build Summary #####
Repository: https://github.com/tianocore/edk2
Branch: origin/master
Packages path: /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore
Option: BOOTLOADER=COREBOOT
Option: BOOTSPLASH_IMAGE=TRUE
Option: CPU_TIMER_LIB_ENABLE=FALSE
Option: DISABLE_SERIAL_TERMINAL=TRUE
Option: PLATFORM_BOOT_TIMEOUT=2
Option: PS2_KEYBOARD_ENABLE=TRUE
Option: SD_MMC_TIMEOUT=10000
Option: SIO_BUS_ENABLE=TRUE
Pcd: gEfiMdeModulePkgTokenSpaceGuid.PcdConOutColumn=0
Pcd: gEfiMdeModulePkgTokenSpaceGuid.PcdConOutRow=0
Pcd: gEfiMdeModulePkgTokenSpaceGuid.PcdMaxVariableSize=0x8000
Pcd: gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutColumn=0
Pcd: gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutRow=0
Pcd: gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseAddress=0xf0000000
Pcd: gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseSize=0x04000000
Build: Quiet
Toolchain: COREBOOT
Loading previous configuration from /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/Conf/BuildEnv.sh
Using EDK2 in-source Basetools
WORKSPACE: /home/user/fw_test/coreboot/payloads/external/edk2/workspace
EDK_TOOLS_PATH: /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/BaseTools
CONF_PATH: /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/Conf
EDK2: Building... python_exe=python3
build -p UefiPayloadPkg/UefiPayloadPkg.dsc -b RELEASE -a IA32 -a X64 -t COREBOOT -y /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UefiUniversalPayload.txt --quiet --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdMaxVariableSize=0x8000 --pcd gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseAddress=0xf0000000 --pcd gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseSize=0x04000000 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdConOutRow=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdConOutColumn=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutRow=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutColumn=0 -D BUILD_ARCH=IA32 -D UNIVERSAL_PAYLOAD=TRUE -D BOOTLOADER=COREBOOT -D BOOTSPLASH_IMAGE=TRUE -D CPU_TIMER_LIB_ENABLE=FALSE -D DISABLE_SERIAL_TERMINAL=TRUE -D PS2_KEYBOARD_ENABLE=TRUE -D PLATFORM_BOOT_TIMEOUT=2 -D SIO_BUS_ENABLE=TRUE -D SD_MMC_TIMEOUT=10000 -D UNIVERSAL_PAYLOAD_FORMAT=ELF
Build environment: Linux-6.8.8-arch1-1-x86_64-with-glibc2.39
Build start time: 03:06:31, May.08 2024
WORKSPACE = /home/user/fw_test/coreboot/payloads/external/edk2/workspace
PACKAGES_PATH = /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore
EDK_TOOLS_PATH = /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/BaseTools
CONF_PATH = /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/Conf
PYTHON_COMMAND = python3
Processing meta-data ........ done!
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiDriverEntryPoint/UefiDriverEntryPoint.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/RuntimeDxeReportStatusCodeLib/RuntimeDxeReportStatusCodeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiRuntimeLib/UefiRuntimeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiDevicePathLib/UefiDevicePathLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiRuntimeServicesTableLib/UefiRuntimeServicesTableLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiBootServicesTableLib/UefiBootServicesTableLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiMemoryAllocationLib/UefiMemoryAllocationLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePrintLib/BasePrintLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DxeHobListLib/DxeHobListLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/PeiDxeDebugLibReportStatusCode/PeiDxeDebugLibReportStatusCode.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseLib/BaseLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxePcdLib/DxePcdLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseMemoryLibRepStr/BaseMemoryLibRepStr.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/RegisterFilterLibNull/RegisterFilterLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DebugPrintErrorLevelLibHob/DebugPrintErrorLevelLibHob.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DxeHobLib/DxeHobLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BaseBmpSupportLib/BaseBmpSupportLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DxeSecurityManagementLib/DxeSecurityManagementLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PlatformBootManagerLib/PlatformBootManagerLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BootLogoLib/BootLogoLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/LzmaCustomDecompressLib/LzmaCustomDecompressLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/ImagePropertiesRecordLib/ImagePropertiesRecordLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePeCoffLib/BasePeCoffLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseUefiDecompressLib/BaseUefiDecompressLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxeExtractGuidedSectionLib/DxeExtractGuidedSectionLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePeCoffExtraActionLibNull/BasePeCoffExtraActionLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DxeHobListLibNull/DxeHobListLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxeCoreHobLib/DxeCoreHobLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxeCoreEntryPoint/DxeCoreEntryPoint.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DxeCoreMemoryAllocationLib/DxeCoreMemoryAllocationLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseCpuLib/BaseCpuLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePeCoffLib/BasePeCoffLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePeCoffExtraActionLibNull/BasePeCoffExtraActionLibNull.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseDebugLibSerialPort/BaseDebugLibSerialPort.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BaseSerialPortLib16550/BaseSerialPortLib16550.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePrintLib/BasePrintLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DebugPrintErrorLevelLibHob/DebugPrintErrorLevelLibHob.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PlatformHookLib/PlatformHookLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePciLibPciExpress/BasePciLibPciExpress.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PayloadEntryHobLib/HobLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/DxeHobListLibNull/DxeHobListLibNull.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePciExpressLib/BasePciExpressLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseIoLibIntrinsic/BaseIoLibIntrinsic.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseMemoryLibRepStr/BaseMemoryLibRepStr.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseLib/BaseLib.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/RegisterFilterLibNull/RegisterFilterLibNull.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePcdLibNull/BasePcdLibNull.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellNetwork1CommandsLib/UefiShellNetwork1CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellDebug1CommandsLib/UefiShellDebug1CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellInstall1CommandsLib/UefiShellInstall1CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellDriver1CommandsLib/UefiShellDriver1CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellLevel3CommandsLib/UefiShellLevel3CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellLevel2CommandsLib/UefiShellLevel2CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellLevel1CommandsLib/UefiShellLevel1CommandsLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellBcfgCommandLib/UefiShellBcfgCommandLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellCommandLib/UefiShellCommandLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiHandleParsingLib/UefiHandleParsingLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseOrderedCollectionRedBlackTreeLib/BaseOrderedCollectionRedBlackTreeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePcdLibNull/BasePcdLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/VariablePolicyLib/VariablePolicyLibRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BaseVariableFlashInfoLib/BaseVariableFlashInfoLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/VarCheckLib/VarCheckLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/AuthVariableLibNull/AuthVariableLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/TpmMeasurementLibNull/TpmMeasurementLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseSafeIntLib/BaseSafeIntLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiScsiLib/UefiScsiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/FrameBufferBltLib/FrameBufferBltLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/MpInitLib/DxeMpInitLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/CpuExceptionHandlerLib/DxeCpuExceptionHandlerLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/MtrrLib/MtrrLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DebugAgentLibNull/DebugAgentLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/AmdSvsmLibNull/AmdSvsmLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/MicrocodeLib/MicrocodeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/CpuPageTableLib/CpuPageTableLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseSynchronizationLib/BaseSynchronizationLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/CcExitLibNull/CcExitLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PciHostBridgeLib/PciHostBridgeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/PciSegmentLibSegmentInfo/BasePciSegmentLibSegmentInfo.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PciSegmentInfoLibAcpiBoardInfo/PciSegmentInfoLibAcpiBoardInfo.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BootMaintenanceManagerUiLib/BootMaintenanceManagerUiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BootManagerUiLib/BootManagerUiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DeviceManagerUiLib/DeviceManagerUiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiApplicationEntryPoint/UefiApplicationEntryPoint.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/FileExplorerLib/FileExplorerLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/UefiBootManagerLib/UefiBootManagerLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePerformanceLibNull/BasePerformanceLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePeCoffGetEntryPointLib/BasePeCoffGetEntryPointLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxeServicesTableLib/DxeServicesTableLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/DxeServicesLib/DxeServicesLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/VariablePolicyHelperLib/VariablePolicyHelperLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/NetworkPkg/Library/DxeNetLib/DxeNetLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Library/UefiShellLib/UefiShellLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiFileHandleLib/UefiFileHandleLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/UefiSortLib/UefiSortLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/BaseSerialPortLib16550/BaseSerialPortLib16550.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/PlatformHookLib/PlatformHookLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePciLibPciExpress/BasePciLibPciExpress.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BasePciExpressLib/BasePciExpressLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiUsbLib/UefiUsbLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseCacheMaintenanceLib/BaseCacheMaintenanceLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DxeCapsuleLibNull/DxeCapsuleLibNull.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/PcAtChipsetPkg/Library/BaseIoApicLib/BaseIoApicLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/Library/BaseXApicX2ApicLib/BaseXApicX2ApicLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/AcpiTimerLib/AcpiTimerLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseCpuLib/BaseCpuLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/Library/ResetSystemLib/ResetSystemLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/BaseIoLibIntrinsic/BaseIoLibIntrinsic.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/CustomizedDisplayLib/CustomizedDisplayLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/UefiHiiLib/UefiHiiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/UefiHiiServicesLib/UefiHiiServicesLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdePkg/Library/UefiLib/UefiLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Library/DxeReportStatusCodeLib/DxeReportStatusCodeLib.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/UefiPayloadEntry/UniversalPayloadEntry.inf [IA32]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/StatusCodeHandler/RuntimeDxe/StatusCodeHandlerRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/MonotonicCounterRuntimeDxe/MonotonicCounterRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Metronome/Metronome.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Logo/LogoDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/EbcDxe/EbcDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/WatchdogTimerDxe/WatchdogTimer.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/CpuIo2Dxe/CpuIo2Dxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/SerialDxe/SerialDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/DevicePathDxe/DevicePathDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Disk/UnicodeCollation/EnglishDxe/EnglishDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/PcAtChipsetPkg/HpetTimerDxe/HpetTimerDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Console/ConSplitterDxe/ConSplitterDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/SdMmcPciHcDxe/SdMmcPciHcDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/XhciDxe/XhciDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Acpi/BootGraphicsResourceTableDxe/BootGraphicsResourceTableDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Acpi/AcpiPlatformDxe/AcpiPlatformDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/SecurityStubDxe/SecurityStubDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/SetupBrowserDxe/SetupBrowserDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/PcAtChipsetPkg/PcatRealTimeClockRuntimeDxe/PcatRealTimeClockRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Core/RuntimeDxe/RuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Scsi/ScsiDiskDxe/ScsiDiskDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Disk/PartitionDxe/PartitionDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Ata/AtaBusDxe/AtaBusDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/BdsDxe/BdsDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Console/GraphicsConsoleDxe/GraphicsConsoleDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/UhciDxe/UhciDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/PciBusDxe/PciBusDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Acpi/AcpiTableDxe/AcpiTableDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Core/Dxe/DxeMain.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/SmbiosDxe/SmbiosDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/BlSupportDxe/BlSupportDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Ata/AtaAtapiPassThru/AtaAtapiPassThru.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/PlatformDriOverrideDxe/PlatformDriOverrideDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/ReportStatusCodeRouter/RuntimeDxe/ReportStatusCodeRouterRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Disk/DiskIoDxe/DiskIoDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Usb/UsbMassStorageDxe/UsbMassStorageDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/Application/Shell/Shell.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Sd/SdDxe/SdDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/EhciDxe/EhciDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Application/BootManagerMenuApp/BootManagerMenuApp.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/PCD/Dxe/Pcd.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/NvmExpressDxe/NvmExpressDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Variable/RuntimeDxe/VariableRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Scsi/ScsiBusDxe/ScsiBusDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Usb/UsbBusDxe/UsbBusDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiPayloadPkg/GraphicsOutputDxe/GraphicsOutputDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/Console/ConPlatformDxe/ConPlatformDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/MemoryTest/NullMemoryTestDxe/NullMemoryTestDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/UefiCpuPkg/CpuDxe/CpuDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Isa/Ps2MouseDxe/Ps2MouseDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/PciHostBridgeDxe/PciHostBridgeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/FatPkg/EnhancedFatDxe/Fat.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/OvmfPkg/SioBusDxe/SioBusDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Application/UiApp/UiApp.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/ShellPkg/DynamicCommand/TftpDynamicCommand/TftpDynamicCommand.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Isa/Ps2KeyboardDxe/Ps2KeyboardDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Usb/UsbMouseDxe/UsbMouseDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/HiiDatabaseDxe/HiiDatabaseDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Usb/UsbKbDxe/UsbKbDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/CapsuleRuntimeDxe/CapsuleRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Pci/SataControllerDxe/SataControllerDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/ResetSystemRuntimeDxe/ResetSystemRuntimeDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Universal/DisplayEngineDxe/DisplayEngineDxe.inf [X64]
Building ... /home/user/fw_test/coreboot/payloads/external/edk2/workspace/tianocore/MdeModulePkg/Bus/Sd/EmmcDxe/EmmcDxe.inf [X64]
###########Build report can be found at /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UefiUniversalPayload.txt
- Done -
Build end time: 03:08:21, May.08 2024
Build total time: 00:01:49
build -p UefiPayloadPkg/UefiPayloadPkg.dsc -b RELEASE -a IA32 -a X64 -m UefiPayloadPkg/UefiPayloadEntry/UniversalPayloadEntry.inf -t CLANGDWARF -y /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UefiUniversalPayloadEntry.txt --quiet --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdMaxVariableSize=0x8000 --pcd gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseAddress=0xf0000000 --pcd gEfiMdePkgTokenSpaceGuid.PcdPciExpressBaseSize=0x04000000 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdConOutRow=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdConOutColumn=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutRow=0 --pcd gEfiMdeModulePkgTokenSpaceGuid.PcdSetupConOutColumn=0 -D BUILD_ARCH=IA32 -D UNIVERSAL_PAYLOAD=TRUE -D BOOTLOADER=COREBOOT -D BOOTSPLASH_IMAGE=TRUE -D CPU_TIMER_LIB_ENABLE=FALSE -D DISABLE_SERIAL_TERMINAL=TRUE -D PS2_KEYBOARD_ENABLE=TRUE -D PLATFORM_BOOT_TIMEOUT=2 -D SIO_BUS_ENABLE=TRUE -D SD_MMC_TIMEOUT=10000 -D UNIVERSAL_PAYLOAD_FORMAT=ELF
Build start time: 03:08:21, May.08 2024
Processing meta-data .. done!
Generating code . done!
Generating makefile . done!
Build report can be found at /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UefiUniversalPayloadEntry.txt
- Done -
Build end time: 03:08:39, May.08 2024
Build total time: 00:00:18
Patch uefi_fv=/home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/RELEASE_COREBOOT/FV/DXEFV.Fv into /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UniversalPayload.elf
Patch bds_fv=/home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/RELEASE_COREBOOT/FV/BDSFV.Fv into /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgIA32/UniversalPayload.elf
Successfully build Universal Payload
Failed!
make[1]: *** [Makefile:292: /home/user/fw_test/coreboot/payloads/external/edk2/workspace/Build/UefiPayloadPkgX64/UniversalPayload.elf] Error 1
make: *** [payloads/external/Makefile.mk:212: build/ShimmedUniversalPayload.elf] Error 2
My .config:
CONFIG_LOCALVERSION=""
CONFIG_CBFS_PREFIX="fallback"
CONFIG_COMPILER_GCC=y
CONFIG_ARCH_SUPPORTS_CLANG=y
CONFIG_CCACHE=y
CONFIG_USE_OPTION_TABLE=y
CONFIG_COMPRESS_RAMSTAGE_LZMA=y
CONFIG_SEPARATE_ROMSTAGE=y
CONFIG_INCLUDE_CONFIG_FILE=y
CONFIG_COLLECT_TIMESTAMPS=y
CONFIG_USE_BLOBS=y
CONFIG_HAVE_ASAN_IN_RAMSTAGE=y
CONFIG_NO_STAGE_CACHE=y
CONFIG_VENDOR_LENOVO=y
CONFIG_BOARD_SPECIFIC_OPTIONS=y
CONFIG_MAINBOARD_FAMILY="ThinkPad X200s"
CONFIG_MAINBOARD_PART_NUMBER="ThinkPad X200s"
CONFIG_MAINBOARD_VERSION="1.0"
CONFIG_MAINBOARD_DIR="lenovo/x200"
CONFIG_VGA_BIOS_ID="8086,2a42"
CONFIG_DIMM_MAX=4
CONFIG_DIMM_SPD_SIZE=256
CONFIG_FMDFILE=""
CONFIG_MAINBOARD_VENDOR="LENOVO"
CONFIG_CBFS_SIZE=0x200000
CONFIG_MAX_CPUS=2
CONFIG_POST_DEVICE=y
CONFIG_POST_IO=y
CONFIG_DEVICETREE="devicetree.cb"
CONFIG_VARIANT_DIR="x200"
CONFIG_OVERRIDE_DEVICETREE="variants/$(CONFIG_VARIANT_DIR)/overridetree.cb"
CONFIG_MAINBOARD_SMBIOS_MANUFACTURER="LENOVO"
CONFIG_INTEL_GMA_VBT_FILE=""
CONFIG_PRERAM_CBMEM_CONSOLE_SIZE=0xc00
CONFIG_CMOS_DEFAULT_FILE="src/mainboard/$(MAINBOARDDIR)/cmos.default"
CONFIG_CMOS_LAYOUT_FILE="src/mainboard/$(MAINBOARDDIR)/cmos.layout"
CONFIG_USBDEBUG_HCD_INDEX=2
CONFIG_BOOT_DEVICE_SPI_FLASH_BUS=0
CONFIG_CONSOLE_POST=y
CONFIG_ECAM_MMCONF_BASE_ADDRESS=0xf0000000
CONFIG_ECAM_MMCONF_BUS_NUMBER=64
CONFIG_MEMLAYOUT_LD_FILE="src/arch/x86/memlayout.ld"
CONFIG_VBOOT_SLOTS_RW_A=y
CONFIG_DCACHE_RAM_BASE=0xfefc0000
CONFIG_DCACHE_RAM_SIZE=0x10000
CONFIG_C_ENV_BOOTBLOCK_SIZE=0x40000
CONFIG_DCACHE_BSP_STACK_SIZE=0x2000
CONFIG_MAX_ACPI_TABLE_SIZE_KB=144
CONFIG_HAVE_INTEL_FIRMWARE=y
CONFIG_SPI_FLASH_INCLUDE_ALL_DRIVERS=y
CONFIG_SPI_FLASH_WINBOND=y
CONFIG_DRIVERS_INTEL_WIFI=y
CONFIG_CONSOLE_CBMEM_BUFFER_SIZE=0x20000
CONFIG_EDK2_BOOT_TIMEOUT=2
CONFIG_ACPI_FNKEY_GEN_SCANCODE=0
CONFIG_CARDBUS_PLUGIN_SUPPORT=y
CONFIG_SPI_FLASH_GIGADEVICE=y
CONFIG_SPI_FLASH_STMICRO=y
CONFIG_MAINBOARD_SMBIOS_PRODUCT_NAME="ThinkPad X200s"
CONFIG_PCIEXP_HOTPLUG_BUSES=8
CONFIG_PCIEXP_HOTPLUG_MEM=0x800000
CONFIG_PCIEXP_HOTPLUG_PREFETCH_MEM=0x10000000
CONFIG_BOARD_LENOVO_X200=y
CONFIG_DRIVER_LENOVO_SERIALS=y
CONFIG_PS2K_EISAID="LEN0010"
CONFIG_PS2M_EISAID="IBM3780"
CONFIG_THINKPADEC_HKEY_EISAID="IBM0068"
CONFIG_GFX_GMA_PANEL_1_PORT="LVDS"
CONFIG_D3COLD_SUPPORT=y
CONFIG_PC_CMOS_BASE_PORT_BANK1=0x72
CONFIG_HEAP_SIZE=0x100000
CONFIG_EC_GPE_SCI=0x50
CONFIG_EDK2_BOOTSPLASH_FILE="Documentation/coreboot_logo.bmp"
CONFIG_BOARD_ROMSIZE_KB_8192=y
CONFIG_COREBOOT_ROMSIZE_KB_8192=y
CONFIG_COREBOOT_ROMSIZE_KB=8192
CONFIG_ROM_SIZE=0x00800000
CONFIG_HAVE_POWER_STATE_AFTER_FAILURE=y
CONFIG_HAVE_POWER_STATE_PREVIOUS_AFTER_FAILURE=y
CONFIG_POWER_STATE_OFF_AFTER_FAILURE=y
CONFIG_MAINBOARD_POWER_FAILURE_STATE=0
CONFIG_SYSTEM_TYPE_LAPTOP=y
CONFIG_CHIPSET_DEVICETREE=""
CONFIG_CBFS_MCACHE_SIZE=0x4000
CONFIG_ROMSTAGE_ADDR=0x2000000
CONFIG_VERSTAGE_ADDR=0x2000000
CONFIG_SMM_RESERVED_SIZE=0x100000
CONFIG_SMM_MODULE_STACK_SIZE=0x800
CONFIG_USE_X86_64_SUPPORT=y
CONFIG_PRERAM_CBFS_CACHE_SIZE=0x0
CONFIG_DOMAIN_RESOURCE_32BIT_LIMIT=0xfe000000
CONFIG_EHCI_BAR=0xfef00000
CONFIG_ACPI_CPU_STRING="CP%02X"
CONFIG_STACK_SIZE=0x2000
CONFIG_INTEL_GMA_BCLV_OFFSET=0x61254
CONFIG_INTEL_GMA_BCLV_WIDTH=16
CONFIG_INTEL_GMA_BCLM_OFFSET=0x61256
CONFIG_INTEL_GMA_BCLM_WIDTH=16
CONFIG_BOOTBLOCK_IN_CBFS=y
CONFIG_HPET_MIN_TICKS=0x80
CONFIG_FIXED_MCHBAR_MMIO_BASE=0xfed14000
CONFIG_FIXED_DMIBAR_MMIO_BASE=0xfed18000
CONFIG_FIXED_EPBAR_MMIO_BASE=0xfed19000
CONFIG_SOC_PHYSICAL_ADDRESS_WIDTH=0
CONFIG_FIXED_SMBUS_IO_BASE=0x400
CONFIG_CBFS_CACHE_ALIGN=8
CONFIG_CPU_INTEL_MODEL_1067X=y
CONFIG_CPU_INTEL_SOCKET_BGA956=y
CONFIG_CPU_INTEL_COMMON=y
CONFIG_ENABLE_VMX=y
CONFIG_SET_IA32_FC_LOCK_BIT=y
CONFIG_SET_MSR_AESNI_LOCK_BIT=y
CONFIG_CPU_INTEL_COMMON_TIMEBASE=y
CONFIG_CPU_INTEL_COMMON_SMM=y
CONFIG_MICROCODE_UPDATE_PRE_RAM=y
CONFIG_PARALLEL_MP=y
CONFIG_XAPIC_ONLY=y
CONFIG_UDELAY_TSC=y
CONFIG_TSC_MONOTONIC_TIMER=y
CONFIG_TSC_SYNC_MFENCE=y
CONFIG_SETUP_XIP_CACHE=y
CONFIG_HAVE_SMI_HANDLER=y
CONFIG_SMM_TSEG=y
CONFIG_SMM_LAPIC_REMAP_MITIGATION=y
CONFIG_SMM_PCI_RESOURCE_STORE_NUM_SLOTS=8
CONFIG_AP_STACK_SIZE=0x800
CONFIG_SMP=y
CONFIG_SSE=y
CONFIG_SSE2=y
CONFIG_SUPPORT_CPU_UCODE_IN_CBFS=y
CONFIG_USE_CPU_MICROCODE_CBFS_BINS=y
CONFIG_CPU_MICROCODE_CBFS_DEFAULT_BINS=y
CONFIG_NORTHBRIDGE_INTEL_GM45=y
CONFIG_PCIEXP_HOTPLUG=y
CONFIG_SOUTHBRIDGE_INTEL_I82801IX=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_RESET=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_RTC=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_PMCLIB=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_PMBASE=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_GPIO=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_EARLY_SMBUS=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_SMBUS=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_SPI=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_SPI_ICH9=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_PIRQ_ACPI_GEN=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_RCBA_PIRQ=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_SMM=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_USB_DEBUG=y
CONFIG_INTEL_DESCRIPTOR_MODE_CAPABLE=y
CONFIG_TCO_SPACE_NOT_YET_SPLIT=y
CONFIG_SOUTHBRIDGE_INTEL_COMMON_WATCHDOG=y
CONFIG_FIXED_RCBA_MMIO_BASE=0xfed1c000
CONFIG_RCBA_LENGTH=0x4000
CONFIG_SUPERIO_NSC_PC87382=y
CONFIG_EC_ACPI=y
CONFIG_EC_LENOVO_H8=y
CONFIG_H8_BEEP_ON_DEATH=y
CONFIG_H8_FLASH_LEDS_ON_DEATH=y
CONFIG_H8_HAS_BAT_THRESHOLDS_IMPL=y
CONFIG_EC_LENOVO_PMH7=y
CONFIG_MAINBOARD_USES_IFD_GBE_REGION=y
CONFIG_ARCH_X86=y
CONFIG_ARCH_BOOTBLOCK_X86_64=y
CONFIG_ARCH_VERSTAGE_X86_64=y
CONFIG_ARCH_ROMSTAGE_X86_64=y
CONFIG_ARCH_POSTCAR_X86_64=y
CONFIG_ARCH_RAMSTAGE_X86_64=y
CONFIG_ARCH_ALL_STAGES_X86_64=y
CONFIG_HAVE_X86_64_SUPPORT=y
CONFIG_RESERVED_PHYSICAL_ADDRESS_BITS_SUPPORT=y
CONFIG_X86_TOP4G_BOOTMEDIA_MAP=y
CONFIG_POSTRAM_CBFS_CACHE_IN_BSS=y
CONFIG_RAMSTAGE_CBFS_CACHE_SIZE=0x4000
CONFIG_PC80_SYSTEM=y
CONFIG_HAVE_CMOS_DEFAULT=y
CONFIG_POSTCAR_STAGE=y
CONFIG_BOOTBLOCK_SIMPLE=y
CONFIG_COLLECT_TIMESTAMPS_TSC=y
CONFIG_HAVE_CF9_RESET=y
CONFIG_DEBUG_HW_BREAKPOINTS=y
CONFIG_DEBUG_NULL_DEREF_BREAKPOINTS=y
CONFIG_X86_BOOTBLOCK_EXTRA_PROGRAM_SZ=0
CONFIG_HAVE_VGA_TEXT_FRAMEBUFFER=y
CONFIG_HAVE_LINEAR_FRAMEBUFFER=y
CONFIG_MAINBOARD_HAS_LIBGFXINIT=y
CONFIG_MAINBOARD_USE_LIBGFXINIT=y
CONFIG_NO_EARLY_GFX_INIT=y
CONFIG_WANT_LINEAR_FRAMEBUFFER=y
CONFIG_VGA_TEXT_FRAMEBUFFER=y
CONFIG_PCI=y
CONFIG_ECAM_MMCONF_SUPPORT=y
CONFIG_PCIX_PLUGIN_SUPPORT=y
CONFIG_AZALIA_HDA_CODEC_SUPPORT=y
CONFIG_PCIEXP_PLUGIN_SUPPORT=y
CONFIG_ECAM_MMCONF_LENGTH=0x04000000
CONFIG_PCI_ALLOW_BUS_MASTER=y
CONFIG_PCI_SET_BUS_MASTER_PCI_BRIDGES=y
CONFIG_PCI_ALLOW_BUS_MASTER_ANY_DEVICE=y
CONFIG_PCIEXP_HOTPLUG_PREFETCH_MEM_ABOVE_4G=y
CONFIG_PCIEXP_HOTPLUG_IO=0x800
CONFIG_SUBSYSTEM_VENDOR_ID=0x0000
CONFIG_SUBSYSTEM_DEVICE_ID=0x0000
CONFIG_INTEL_GMA_HAVE_VBT=y
CONFIG_INTEL_GMA_ADD_VBT=y
CONFIG_I2C_TRANSFER_TIMEOUT_US=500000
CONFIG_USE_DDR3=y
CONFIG_USE_DDR2=y
CONFIG_CRB_TPM_BASE_ADDRESS=0xfed40000
CONFIG_DRIVERS_LENOVO_WACOM=y
CONFIG_DIGITIZER_AUTODETECT=y
CONFIG_SMMSTORE=y
CONFIG_SMMSTORE_V2=y
CONFIG_SMMSTORE_SIZE=0x40000
CONFIG_SPI_FLASH=y
CONFIG_BOOT_DEVICE_SPI_FLASH_RW_NOMMAP=y
CONFIG_BOOT_DEVICE_SPI_FLASH_RW_NOMMAP_EARLY=y
CONFIG_SPI_FLASH_SMM=y
CONFIG_SPI_FLASH_ADESTO=y
CONFIG_SPI_FLASH_AMIC=y
CONFIG_SPI_FLASH_ATMEL=y
CONFIG_SPI_FLASH_EON=y
CONFIG_SPI_FLASH_MACRONIX=y
CONFIG_SPI_FLASH_SPANSION=y
CONFIG_SPI_FLASH_SST=y
CONFIG_SPI_FLASH_ISSI=y
CONFIG_NO_UART_ON_SUPERIO=y
CONFIG_HAVE_USBDEBUG=y
CONFIG_HAVE_USBDEBUG_OPTIONS=y
CONFIG_INTEL_EDID=y
CONFIG_INTEL_INT15=y
CONFIG_INTEL_GMA_ACPI=y
CONFIG_INTEL_GMA_SSC_ALTERNATE_REF=y
CONFIG_VBT_CBFS_COMPRESSION_LZMA=y
CONFIG_VBT_CBFS_COMPRESSION_ALGORITHM="lzma"
CONFIG_GFX_GMA=y
CONFIG_GFX_GMA_PANEL_1_ON_LVDS=y
CONFIG_GFX_GMA_DYN_CPU=y
CONFIG_GFX_GMA_GENERATION="G45"
CONFIG_GFX_GMA_PCH="No_PCH"
CONFIG_GFX_GMA_PANEL_2_PORT="Disabled"
CONFIG_GFX_GMA_ANALOG_I2C_PORT="PCH_DAC"
CONFIG_DRIVERS_MC146818=y
CONFIG_PC_CMOS_BASE_PORT_BANK0=0x70
CONFIG_VGA=y
CONFIG_DRIVERS_WIFI_GENERIC=y
CONFIG_DRIVERS_MTK_WIFI=y
CONFIG_NO_TPM=y
CONFIG_PCR_BOOT_MODE=1
CONFIG_PCR_HWID=1
CONFIG_PCR_SRTM=2
CONFIG_PCR_FW_VER=10
CONFIG_PCR_RUNTIME_DATA=3
CONFIG_PLATFORM_HAS_DRAM_CLEAR=y
CONFIG_BOOTMEDIA_LOCK_NONE=y
CONFIG_ACPI_HAVE_PCAT_8259=y
CONFIG_ACPI_INTEL_HARDWARE_SLEEP_VALUES=y
CONFIG_ACPI_SOC_NVS=y
CONFIG_ACPI_NO_CUSTOM_MADT=y
CONFIG_ACPI_COMMON_MADT_LAPIC=y
CONFIG_ACPI_COMMON_MADT_IOAPIC=y
CONFIG_HAVE_ACPI_TABLES=y
CONFIG_BOOT_DEVICE_SPI_FLASH=y
CONFIG_BOOT_DEVICE_MEMORY_MAPPED=y
CONFIG_BOOT_DEVICE_SUPPORTS_WRITES=y
CONFIG_BOOTBLOCK_CONSOLE=y
CONFIG_POSTCAR_CONSOLE=y
CONFIG_SQUELCH_EARLY_SMP=y
CONFIG_CONSOLE_CBMEM=y
CONFIG_DEFAULT_CONSOLE_LOGLEVEL_7=y
CONFIG_DEFAULT_CONSOLE_LOGLEVEL=7
CONFIG_CONSOLE_USE_LOGLEVEL_PREFIX=y
CONFIG_CONSOLE_USE_ANSI_ESCAPES=y
CONFIG_POST_DEVICE_NONE=y
CONFIG_POST_IO_PORT=0x80
CONFIG_HWBASE_DEBUG_CB=y
CONFIG_HAVE_ACPI_RESUME=y
CONFIG_RESUME_PATH_SAME_AS_BOOT=y
CONFIG_HAVE_MONOTONIC_TIMER=y
CONFIG_HAVE_OPTION_TABLE=y
CONFIG_IOAPIC=y
CONFIG_USE_WATCHDOG_ON_BOOT=y
CONFIG_GENERATE_SMBIOS_TABLES=y
CONFIG_SMBIOS_PROVIDED_BY_MOBO=y
CONFIG_BIOS_VENDOR="coreboot"
CONFIG_MAINBOARD_SERIAL_NUMBER="123456789"
CONFIG_PAYLOAD_EDK2=y
CONFIG_PAYLOAD_FILE="build/ShimmedUniversalPayload.elf"
CONFIG_EDK2_UNIVERSAL_PAYLOAD=y
CONFIG_EDK2_REPO_OFFICIAL=y
CONFIG_EDK2_REPOSITORY="https://github.com/tianocore/edk2"
CONFIG_EDK2_TAG_OR_REV="origin/master"
CONFIG_EDK2_USE_EDK2_PLATFORMS=y
CONFIG_EDK2_PLATFORMS_REPOSITORY="https://github.com/tianocore/edk2-platforms"
CONFIG_EDK2_PLATFORMS_TAG_OR_REV="origin/master"
CONFIG_EDK2_RELEASE=y
CONFIG_EDK2_FULL_SCREEN_SETUP=y
CONFIG_EDK2_HAVE_EFI_SHELL=y
CONFIG_EDK2_PS2_SUPPORT=y
CONFIG_EDK2_SD_MMC_TIMEOUT=10
CONFIG_EDK2_USE_LAPIC_TIMER=y
CONFIG_EDK2_CUSTOM_BUILD_PARAMS=""
CONFIG_COMPRESSED_PAYLOAD_LZMA=y
CONFIG_COMPRESS_SECONDARY_PAYLOAD=y
CONFIG_HAVE_DEBUG_RAM_SETUP=y
CONFIG_HAVE_DEBUG_SMBUS=y
CONFIG_RAMSTAGE_ADA=y
CONFIG_RAMSTAGE_LIBHWBASE=y
CONFIG_HWBASE_DYNAMIC_MMIO=y
CONFIG_HWBASE_DEFAULT_MMCONF=0xf0000000
CONFIG_HWBASE_DIRECT_PCIDEV=y
CONFIG_DECOMPRESS_OFAST=y
CONFIG_WARNINGS_ARE_ERRORS=y
CONFIG_MAX_REBOOT_CNT=3
CONFIG_RELOCATABLE_MODULES=y
CONFIG_HAVE_BOOTBLOCK=y
CONFIG_HAVE_ROMSTAGE=y
CONFIG_HAVE_RAMSTAGE=y
MD Updated by Matt DeVillier over 2 years ago
You've selected a bunch of non-default options that don't play well together, and the result is a failed build.
The UniversalPayload edk2 option only works with Starlabs' fork.
Upstream edk2 is always in a state of flux and may or may not build (usually does) / may or may not boot.
The MrChromebox edk2 fork is the default for a good reason.
- Status changed from New to Rejected
