Bug #513
open
BX
clear_memory() triggers null dereference exception when running coreboot in long (64-bit) mode
Bug #513: clear_memory() triggers null dereference exception when running coreboot in long (64-bit) mode
Added by Bill XIE almost 3 years ago. Updated almost 3 years ago.
New
Low
coreboot common code
11/17/2023
X200
Enabling CONFIG_USE_EXP_X86_64_SUPPORT and CONFIG_SECURITY_CLEAR_DRAM_ON_REGULAR_BOOT in the mean time on my X200 triggers null dereference exception. Register dump in attached log suggests that clearing DRAM 0000000100000000-0000000180000000 triggers the exception, and the used memset() implementation in src/arch/x86/memset.c seems unable to handle such usage when built against X86_64.
Files
clrmem-amd64-nulderef.log (5.21 KB) clrmem-amd64-nulderef.log Bill XIE, 11/17/2023 09:56 AM
PR Updated by Patrick Rudolph almost 3 years ago Actions #1
That's because the default page tables do not cover anything above 4GiB and the PAE mechanism used on x86_32 isn't used on x86_64.
