Feature #491
open
MF
spi nand support
Feature #491: spi nand support
Added by Mr. FF over 3 years ago. Updated almost 3 years ago.
New
05/25/2023
https://github.com/flashrom/flashrom/pull/294
This code based on Yangfl code
Implemented
Read with chip error correction. Tested OK with Winbond W25N01GV spi nand.
Raw read without error correction. Tested OK with Winbond W25N01GV spi nand.
Skeleton for software error correction. There are some different version of Micron, Atmel, Samsung etc. Details of how select and control this functions to be discussed.
Not implemented yet
Block and Chip erase
Write Raw and with hardware error correction. Some code prepared but commented out as not tested yet.
ET Updated by E T almost 3 years ago Actions #1
Thank you for your code, I successfully dumped a W25N01GV.
How to choose read with chip error correction or raw read without error correction?
