Bug #457
open
TL
Haswell (t440p): CAR memory region should not conflict with CBFS_SIZE > 8mb
Bug #457: Haswell (t440p): CAR memory region should not conflict with CBFS_SIZE > 8mb
Added by Thierry Laurion almost 4 years ago. Updated almost 4 years ago.
New
02/08/2023
When neutering ME to pass freed space to IFD BIOS region (and having CBFS_SIZE match maximized IFD region), booting of the platform was reported to take an additional 20 seconds.
A quick review at FOSDEM with a coreboot dev inspecting current Haswell code suggested that fixing DCACHE_RAM_BASE might fix the issue under src/northbridge/intel/haswell/Kconfig:
0xff7c0000 -> 0xfe7c0000
Unfortunately, I have no access to a t440p to test the fix.
It was also suggested that mrc.bin might need to be patched as well.
But 4.19 is bringing native raminit, so that might not be an issue?
Attached is the suggested change to be tested.
Files
haswell_car_20230205233221.patch (369 Bytes) haswell_car_20230205233221.patch Thierry Laurion, 02/08/2023 05:05 PM
AH Updated by Arthur Heymans almost 4 years ago Actions #1
It is quite hard to relocate a binary (mrc.bin). This was done for the sandybridge using a hexeditor, but that is quite errorprone.
Native init could use a different address but it is not as complete as the mrc.bin.
For instance I think dram clocks will not run as high, some power reducing trainings are skipped and S3 resume is not implemented.
