Project ideas #451
open
FS
Fix POST code handling
Project ideas #451: Fix POST code handling
Added by Felix Singer almost 4 years ago. Updated over 3 years ago.
New
01/29/2023
350.00 h
coreboot supports writing POST codes to I/O port 80. There are various Kconfigs that deal with POST codes, which don’t have effect on most platforms. The code to send POST codes is scattered in C and Assembly, some use functions, some use macros and others simply use the outb instruction. The POST codes are duplicated between stages and aren’t documented properly.
Tasks
  • Guard Kconfigs with a depends on to only show on supported platforms
  • Remove duplicated Kconfigs
  • Replace outb(0x80, ...) with calls to post_code(...)
  • Update Documentation/POSTCODES
  • Use defines from console/post_codes.h where possible
  • Drop duplicated POST codes
  • Make use of all possible 255 values
Requirements
  • Knowledge in the coreboot build system and the concept of stages
  • Other knowledge: Little experience with C and x86 Assembly
  • Hardware requirements: Nothing special
Mentors
Files
FS Updated by Felix Singer almost 4 years ago Actions #1
  • Tracker changed from Bug to Project ideas
FS Updated by Felix Singer almost 4 years ago Actions #2
  • Estimated time set to 350.00 h
Updated by Anonymous almost 4 years ago Actions #3
Martin started another discussion regarding POST codes with the "coreboot postcode cleanup proposal" thread.
(I'm not sure if this is the best link):
https://mail.coreboot.org/hyperkitty/list/coreboot@coreboot.org/thread/UQM7Y66KO3RVLJ2OFC7S6KJX7TKKHY3V/#UQM7Y66KO3RVLJ2OFC7S6KJX7TKKHY3V
AG Updated by Alexander Goncharov over 3 years ago Actions #4
Just in case, I attach my unselected GSoC project proposal on this topic
