Bug #444
open
MR
Flaky gitconfig tests are breaking builds
Bug #444: Flaky gitconfig tests are breaking builds
Added by Martin Roth almost 4 years ago. Updated almost 3 years ago.
New
build system
12/20/2022
The gitconfig tests are failing when they can't delete a directory they created in /tmp, and this is causing builds to fail randomly.
Because it's not a part of the test itself, but part of the cleanup, the failure doesn't get captured, and jenkins appears to be failing for no good reason.
Someone should figure out what's causing the rm -rf to fail and fix it so that the builders stop failing.
MR Updated by Martin Roth almost 3 years ago Actions #1
  • Category set to build system
MR Updated by Martin Roth almost 3 years ago Actions #2
These tests are disabled and will be deleted unless fixed.
