Support #442
open
HB
[$400 Bounty] Add 25N01GVZEIG Winbond WSON 8x6-mm support
Support #442:
11/30/2022
Hi,
if you can add 25N01GVZEIG Winbond WSON 8x6-mm support please. This can be great.
Regards
MF Updated by Mr. FF about 3 years ago
herman brule wrote:
Hi,
Regards
Hello,
Check here https://github.com/froloffw7/flashrom
The code based on Yangfl patch, which was rejected.
Implemented
Read with chip error correction. Tested OK with Winbond W25N01GV spi nand.
Raw read without error correction. Tested OK with Winbond W25N01GV spi nand.
Skeleton for software error correction. There are some different version of Micron, Atmel, Samsung etc. Details of how select and control this functions to be discussed.
Not implemented yet, need somebody to do testing on the real hardware.
Block and Chip erase.
Write Raw and with hardware error correction. Some code prepared but commented out as not tested yet.
