Feature #403
open
AG
Encapsulate interaction with flash access
Feature #403: Encapsulate interaction with flash access
Added by Alexander Goncharov over 4 years ago. Updated about 4 years ago.
New
Low
Programmer
07/15/2022
See the comment thread in the linked patch.
It's related to programmers mentioned in the parent task.
AG Updated by Alexander Goncharov over 4 years ago Actions #1
The first thing that came to my mind is something like that:
static int atahpt_toggle_flash_access(struct atahpt_data *data, int toggle)
	uint32_t reg32 = 0;
	if (toggle) {
		data->flash_access = pci_read_long(data->dev, REG_FLASH_ACCESS);
		reg32 = BIT(BIT_FLASH_ACCESS);
	reg32 |= data->flash_access;
	pci_write_long(data->dev, REG_FLASH_ACCESS, reg32);
	return 0;
AG Updated by Alexander Goncharov about 4 years ago Actions #2
  • Parent task deleted (#389)
The parent task is completed, so delete dependency.
